我想查找出一个Model中Element的个数,然后通过循环的方式(其他方式也可以),遍历每一个Element,然后执行相关的函数。
class Convert : ElementGraphicsProcessor { public static void Material2(string unparsed) { Bentley.DgnPlatformNET.DgnModel dgnModel = Session.Instance.GetActiveDgnModel(); Bentley.DgnPlatformNET.DgnFile dgnFile = Session.Instance.GetActiveDgnFile(); //读取model if (0 == dgnModel.GetElementCount(DgnModelSections.Model)) { MessageCenter.Instance.ShowInfoMessage("未找到可读取元素!", null, true); return; } uint i,j; Element ele = null; j = dgnModel.GetElementCount(DgnModelSections.Model); for (i = 0; i < j; i++) { // 返回数组的第i的个元素 ele =;//不知如何获取 Material3(dgnModel,dgnFile,ele); }
现在的问题是我不知道用什么函数来调用模型的Element中的element顺序
DgnModel下有GetElements、GetControlElements、GetGraphicElements可以获取到所有元素、控制元素、图形元素的集合,迭代返回的这个集合就行了。
可以用ScanCriteria类来扫描模型里的元素:
int elemNo = 1; private StatusInt Scan(Element element, DgnModelRef modelRef) { string myStr = elemNo++.ToString() + " -- " + element.TypeName.ToString(); MessageCenter.Instance.ShowMessage(MessageType.Info, myStr, myStr, MessageAlert.None); return StatusInt.Success; } private void ScanTest() { ScanCriteria sc = new ScanCriteria(); sc.SetModelRef(Session.Instance.GetActiveDgnModel()); sc.SetModelSections(DgnModelSections.GraphicElements); sc.Scan(new ScanDelegate(Scan)); }
谢谢老师解答,不过我通过这种方法调试,读取element始终显示为空。
public static void Material2(string unparsed) { Bentley.DgnPlatformNET.DgnModel dgnModel = Session.Instance.GetActiveDgnModel(); Bentley.DgnPlatformNET.DgnFile dgnFile = Session.Instance.GetActiveDgnFile(); //读取model if (0 == dgnModel.GetElementCount(DgnModelSections.Model)) { MessageCenter.Instance.ShowInfoMessage("未找到可读取元素!", null, true); return; } uint j; Element ele = null; j = dgnModel.GetElementCount(DgnModelSections.Model); ModelElementsCollection eles =dgnModel.GetControlElements(); eles.GetEnumerator().Reset(); eles.GetEnumerator().MoveNext(); eles.GetEnumerator().MoveNext(); var i=0; while (i < j) { // 返回数组的第i的个元素 ele = eles.GetEnumerator().Current; Material3(dgnModel,dgnFile, ele); eles.GetEnumerator().MoveNext(); } }
就是后面那个ele
请用如下代码框架来试一下:
ModelElementsCollection elemCol = Session.Instance.GetActiveDgnModel().GetElements(); foreach (Element ele in elemCol) { }
Answer Verified By: xz h
谢谢老师解答
