我使用自己的代码创建批注时,尺寸标注以及批注不是关联的。但是使用OBD自带的批注创建的是关联的。如何让这2个关联呢?
代码如下
EditElementHandle dimElemnote; bvector<DPoint3d> m_dimPoints; //mdlArc_extract(NULL,NULL,NULL,NULL,NULL,NULL, ¢erpoint, msArcelemcp); if (SUCCESS != CreateNoteDimension(dimElemnote, 0, modelref)) { return ERROR; } double witLength1; DVec3d delta1, corner1, yvec1; RotMatrix rMatrix1; DPoint3d* startPoint1 = ¢erpoint; DPoint3d endPoint1; endPoint1.x = centerpoint.x + 2000000; endPoint1.y = centerpoint.y + 2000000; DPoint3d point1 = centerpoint; m_dimPoints.push_back(*startPoint1); m_dimPoints.push_back(endPoint1); //计算两个点或向量之间的分量差 mdlVec_subtractPoint(&delta1, &point1, startPoint1); //计算两个输入点或向量的分量之和。 mdlVec_addPoint(&corner1, &m_dimPoints.front(), &delta1); //Creates Rotation matrix mdlDim_defineRotMatrix(&rMatrix1, dimElemnote.GetElementP(), &m_dimPoints.front(), &corner1, &m_dimPoints.back()); mdlRMatrix_getColumnVector(&yvec1, &rMatrix1, 1); //Gets witness length mdlVec_subtractPoint(&delta1, &point1, &m_dimPoints.front()); witLength1 = mdlVec_dotProduct(&yvec1, &delta1); //Inserts points for dimension element InsertPoints(dimElemnote, m_dimPoints); //IDimensionEdit required to set the dimension element height IDimensionEdit* dimEdit1 = dynamic_cast <IDimensionEdit*> (&dimElemnote.GetHandler()); if (nullptr == dimEdit1) return ERROR; RotMatrix rMatrix2 = { 0,1,0 }; dimEdit1->SetRotationMatrix(dimElemnote, rMatrix2); dimEdit1->SetHeight(dimElemnote, 2000000); //Apply active settings to dimension element ElementPropertyUtils::ApplyActiveSettings(dimElemnote); //Adds dimension element to the model dimElemnote.AddToModel(); //设置文本内容 EditElementHandle eeh; TextBlockPtr textBlock = CreateText(L"", endPoint1,text,0); if (textBlock.IsValid()) { if (TEXTBLOCK_TO_ELEMENT_RESULT_Success != TextHandlerBase::CreateElement(eeh, NULL,modelref, *textBlock)) { return ERROR; } } eeh.AddToModel(); EditElementHandle eehnote; EditElementHandle eehlead; //CreateNote(EditElementHandleR noteElem, EditElementHandleCR leaderElement, TextBlockCR text, bool is3d, DgnModelRefR modelRef, DPoint3dCR leaderCellOrigin BentleyStatus bstatus; StatusInt sint; DimensionStylePtr textStyle = nullptr; textStyle = textStyle->GetActive(); //NoteCellHeaderHandler::AddToModel(eehnote, dimElemnote, modelref->GetDgnModelP); bstatus = NoteCellHeaderHandler::CreateNote(eehnote, eehlead, *textBlock, *textStyle,false, *modelref, m_dimPoints); //bstatus = NoteCellHeaderHandler::CreateNote(eehnote, dimElemnote, *textBlock, false, *modelref, endPoint1); eehlead.AddToModel(); //eehnote.AppendElementLinkage(); sint = eehnote.AddToModel();
附上我的完整代码
int CreateNoteDim(DgnModelRefP modelref, DPoint3d centerpoint,WCharCP text) { BentleyStatus bstatus; DPoint3d startPoint = centerpoint; DPoint3d endPoint = {0,0,0}; endPoint.x = centerpoint.x + 2000000; endPoint.y = centerpoint.y + 2000000; DgnFilePtr pActiveDgnFile = ISessionMgr::GetActiveDgnFile(); DimensionStylePtr pDimStyle = DimensionStyle::GetSettings(*pActiveDgnFile); DgnTextStylePtr textStyle = DgnTextStyle::GetSettings(*pActiveDgnFile); EditElementHandle noteElem, leaderElement; TextBlockPropertiesPtr txtBlockProp = TextBlockProperties::Create(*textStyle, *(ACTIVEMODEL->AsDgnModelP())); ParagraphPropertiesPtr paragraphProperties = ParagraphProperties::Create(*textStyle, *(ACTIVEMODEL->AsDgnModelP())); RunPropertiesPtr runProp = RunProperties::Create(*textStyle, *(ACTIVEMODEL->AsDgnModelP())); TextBlockPtr textbock = TextBlock::Create(*txtBlockProp, *paragraphProperties, *runProp, *(ACTIVEMODEL->AsDgnModelP())); textbock->AppendText(text); NoteCellHeaderHandler::StdDPointVector noteLeaderPoints; noteLeaderPoints.push_back(startPoint); noteLeaderPoints.push_back(endPoint); bstatus = NoteCellHeaderHandler::CreateNote(noteElem, leaderElement, *textbock, *pDimStyle, false, *ACTIVEMODEL, noteLeaderPoints); IDimensionEdit* iDimEdit = dynamic_cast<IDimensionEdit*>(&leaderElement.GetHandler()); EditElementHandle lineEeh; DPoint3d ptArr[2] = { startPoint,startPoint }; bstatus = LineStringHandler::CreateLineStringElement(lineEeh, NULL, ptArr,2, false, *ACTIVEMODEL); lineEeh.AddToModel(); AssocPoint assocPt1; AssociativePoint::InitKeypoint(assocPt1, 1, 2, 0, 1); bstatus = AssociativePoint::SetRoot(assocPt1, lineEeh.GetElementId(), 0); if (SUCCESS != iDimEdit->SetPoint(leaderElement, nullptr, &assocPt1, 0)) { return ERROR; } if (iDimEdit->GetNumPoints(leaderElement) > 0) { iDimEdit->DeletePoint(leaderElement, 0); iDimEdit->InsertPoint(leaderElement, &startPoint, nullptr, *pDimStyle, 0); } iDimEdit->SetRotationMatrix(leaderElement, RotMatrix::FromIdentity()); bstatus = NoteCellHeaderHandler::AddToModel(noteElem, leaderElement, *(ACTIVEMODEL->AsDgnModelP())); lineEeh.DeleteFromModel(); return SUCCESS; }
