请问老师,如何通过C#读取路基、隧道的横断面模板并沿着廊道进行放置,有没有代码示例,谢谢!
请参考:
static void testTemplateDropEdit() { long myid = 1546; ElementId elId = new ElementId(ref myid); Bentley.DgnPlatformNET.Elements.Element el1 = Session.Instance.GetActiveDgnModel().FindElementById(elId); TemplateDropEdit templateDrop = null; if (el1 == null) return; Bentley.CifNET.SDK.Edit.ConsensusConnectionEdit con = Bentley.CifNET.SDK.Edit.ConsensusConnectionEdit.GetActive(); Bentley.CifNET.GeometryModel.SDK.Alignment alignment = Bentley.CifNET.GeometryModel.SDK.Alignment.CreateFromElement(con, el1); if (alignment == null && alignment.ActiveProfile == null) return; con.StartTransientMode(); //创建廊道 Bentley.CifNET.GeometryModel.SDK.Edit.CorridorEdit newCorridor = Bentley.CifNET.GeometryModel.SDK.Edit.CorridorEdit.CreateByAlignment(con, alignment.Name + "_Corridor", alignment); //创建templateDrop string strXmlXPath = @"路基\10米道路"; TemplateDefinition templateDefinition = GetTemplate(strXmlXPath); templateDrop = ApplyTemple(newCorridor, newCorridor.StartDistance, newCorridor.EndDistance, templateDefinition); if (templateDrop == null) { return; } System.Collections.Generic.List<double> station = new List<double>(); station.Add(50); station.Add(100); IList<TemplateDropEdit> newTemplateDrops = templateDrop.Split(station); foreach (var tmpDrop in newTemplateDrops) { TemplateDropEdit tmpDropEdit = tmpDrop as TemplateDropEdit; tmpDropEdit.Description = "123"; } con.PersistTransients(); } static TemplateDropEdit ApplyTemple(CorridorEdit corridor, double startStation, double endStation, TemplateDefinition tempDef) { TemplateDropParameters tempDropParams = new TemplateDropParameters(tempDef, startStation, endStation); tempDropParams.Interval = 5.0; tempDropParams.Desription = "Test Add TemplateDrop"; TemplateDropEdit templateDrop = corridor.AddTemplateDrop(tempDropParams); return templateDrop; } static TemplateDefinition GetTemplate(string strXmlXPath) { try { string strLib = TemplateLibrary.GetDefaultTemplateLibraryPath(); TemplateLibrary templateLibrary = TemplateLibrary.Load(strLib); //从模板库的根目录开始遍历。 //GetCategoryAllTemplate(templateLibrary.RootCategory); TemplateDefinition tempDef2 = templateLibrary.FindTemplateByPath(strXmlXPath); return tempDef2; } catch (Exception ex) { System.Windows.Forms.MessageBox.Show(ex.Message); return null; } }
Answer Verified By: sunday
很详细,谢谢老师!
