您好,我想追问是否能实现与原元素属性同样的属性(隐藏/显示)的方法?(如下图所示)
上图是想要实现的效果;
上图为现在实现的效果;
参照帖子:
https://communities.bentley.com/communities/other_communities/chinafirst/f/microstation-projectwise/188940/ec/556173#556173
https://communities.bentley.com/communities/other_communities/chinafirst/f/microstation-projectwise/207218/msce-c
测试代码:
1. 添加代码:
var specification = new InstanceLabelSpecification("false").CreatePopulatedCustomAttributeInstance(); ecClass.SetCustomAttribute(specification);
相关函数:
public static void CreateECDataTable(ECSchema ecSchema, IECClass iecClass) { ECSchema ecSchema = new ECSchema(TestSchema, 1, 0, "Cjxjy"); IECClass iecClass = ecSchema.AddClass(TestClass); iecClass.DisplayLabel = "测试属性表名"; var specification = new InstanceLabelSpecification("false").CreatePopulatedCustomAttributeInstance(); iecClass.SetCustomAttribute(specification); InitializeDataTable(); foreach (DataRow item in dataTable.Rows) { string propertyName = item["column1"].ToString() + "_" + item["column2"].ToString() + "(" + item["column3"].ToString() + ")"; string validName = propertyName; ECNameValidation.EncodeToValidName(ref validName); IECProperty iecProperty = iecClass.AddProperty(validName, ECObjects.StringType); iecProperty.DisplayLabel = propertyName; } SchemaImportStatus schemaImportStatus = DgnECManager.Manager.ImportSchema(ecSchema, Session.Instance.GetActiveDgnFile(), new ImportSchemaOptions()); if (schemaImportStatus != SchemaImportStatus.Success) { return; } } public void AddInstanceToElement(Element element, Dictionary<string, string> dictionary) { IECSchema iecSchema = GetECSchemaForDgnFile(TestSchema); IECClass iecClass = iecSchema.GetClass(TestClass); FindInstancesScope scope = FindInstancesScope.CreateScope(element, new FindInstancesScopeOption(DgnECHostType.Element, true)); ECQuery query = new ECQuery(iecClass); using (DgnECInstanceCollection ecInstances = DgnECManager.Manager.FindInstances(scope, query)) { if (ecInstances.Count() > 0) { foreach (IDgnECInstance dgnECInstance in ecInstances) { dgnECInstance.Delete(); } } DgnECInstanceEnabler instanceEnabler = DgnECManager.Manager.ObtainInstanceEnabler(Session.Instance.GetActiveDgnFile(), iecClass); StandaloneECDInstance instance = instanceEnabler.SharedWipInstance; foreach (var item in dictionary) { string validName = item.Key; ECNameValidation.EncodeToValidName(ref validName); if (item.Value != null) { string value = item.Value; instance.SetString(validName, value); } } instanceEnabler.CreateInstanceOnElement(element, instance, false); } }
实现效果:
2. 添加代码:
var specification = new DisplayOptions(true).CreatePopulatedCustomAttributeInstance(); iecClass.SetCustomAttribute(specification);
public static void CreateECDataTable(ECSchema ecSchema, IECClass iecClass) { ECSchema ecSchema = new ECSchema(TestSchema, 1, 0, "Cjxjy"); IECClass iecClass = ecSchema.AddClass(TestClass); iecClass.DisplayLabel = "测试属性表名"; var specification = new DisplayOptions(true).CreatePopulatedCustomAttributeInstance(); iecClass.SetCustomAttribute(specification); InitializeDataTable(); foreach (DataRow item in dataTable.Rows) { string propertyName = item["column1"].ToString() + "_" + item["column2"].ToString() + "(" + item["column3"].ToString() + ")"; string validName = propertyName; ECNameValidation.EncodeToValidName(ref validName); IECProperty iecProperty = iecClass.AddProperty(validName, ECObjects.StringType); iecProperty.DisplayLabel = propertyName; } SchemaImportStatus schemaImportStatus = DgnECManager.Manager.ImportSchema(ecSchema, Session.Instance.GetActiveDgnFile(), new ImportSchemaOptions()); if (schemaImportStatus != SchemaImportStatus.Success) { return; } } public void AddInstanceToElement(Element element, Dictionary<string, string> dictionary) { IECSchema iecSchema = GetECSchemaForDgnFile(TestSchema); IECClass iecClass = iecSchema.GetClass(TestClass); FindInstancesScope scope = FindInstancesScope.CreateScope(element, new FindInstancesScopeOption(DgnECHostType.Element, true)); ECQuery query = new ECQuery(iecClass); using (DgnECInstanceCollection ecInstances = DgnECManager.Manager.FindInstances(scope, query)) { if (ecInstances.Count() > 0) { foreach (IDgnECInstance dgnECInstance in ecInstances) { dgnECInstance.Delete(); } } DgnECInstanceEnabler instanceEnabler = DgnECManager.Manager.ObtainInstanceEnabler(Session.Instance.GetActiveDgnFile(), iecClass); StandaloneECDInstance instance = instanceEnabler.SharedWipInstance; foreach (var item in dictionary) { string validName = item.Key; ECNameValidation.EncodeToValidName(ref validName); if (item.Value != null) { string value = item.Value; instance.SetString(validName, value); } } instanceEnabler.CreateInstanceOnElement(element, instance, false); } }
3. 添加代码:
IECProperty iecProperty = iecClass.AddProperty(validName, ECObjects.StringType); iecProperty.DisplayLabel = propertyName; iecProperty.SetCustomAttribute(Bentley.ECObjects.UI.ECPropertyPane.CreateHidePropertyAttribute(true, true));
public static void CreateECDataTable(ECSchema ecSchema, IECClass iecClass) { ECSchema ecSchema = new ECSchema(TestSchema, 1, 0, "Cjxjy"); IECClass iecClass = ecSchema.AddClass(TestClass); iecClass.DisplayLabel = "测试属性表名"; InitializeDataTable(); foreach (DataRow item in dataTable.Rows) { string propertyName = item["column1"].ToString() + "_" + item["column2"].ToString() + "(" + item["column3"].ToString() + ")"; string validName = propertyName; ECNameValidation.EncodeToValidName(ref validName); IECProperty iecProperty = iecClass.AddProperty(validName, ECObjects.StringType); iecProperty.DisplayLabel = propertyName; } SchemaImportStatus schemaImportStatus = DgnECManager.Manager.ImportSchema(ecSchema, Session.Instance.GetActiveDgnFile(), new ImportSchemaOptions()); if (schemaImportStatus != SchemaImportStatus.Success) { return; } } public void AddInstanceToElement(Element element, Dictionary<string, string> dictionary) { IECSchema iecSchema = GetECSchemaForDgnFile(TestSchema); IECClass iecClass = iecSchema.GetClass(TestClass); FindInstancesScope scope = FindInstancesScope.CreateScope(element, new FindInstancesScopeOption(DgnECHostType.Element, true)); ECQuery query = new ECQuery(iecClass); using (DgnECInstanceCollection ecInstances = DgnECManager.Manager.FindInstances(scope, query)) { if (ecInstances.Count() > 0) { foreach (IDgnECInstance dgnECInstance in ecInstances) { dgnECInstance.Delete(); } } DgnECInstanceEnabler instanceEnabler = DgnECManager.Manager.ObtainInstanceEnabler(Session.Instance.GetActiveDgnFile(), iecClass); StandaloneECDInstance instance = instanceEnabler.SharedWipInstance; foreach (var item in dictionary) { string validName = item.Key; ECNameValidation.EncodeToValidName(ref validName); if (item.Value != null) { string value = item.Value; instance.SetString(validName, value); } } IEnumerator<IECProperty> propertyEnum = instance.ClassDefinition.GetEnumerator(); while (propertyEnum.MoveNext()) { IECPropertyValue propertyValue = instance.GetPropertyValue(propertyEnum.Current.Name); if (propertyValue != null) { string strVal; propertyValue.TryGetStringValue(out strVal); propertyEnum.Current.SetCustomAttribute(ECPropertyPane.CreateHidePropertyAttribute(false, false)); } else { propertyEnum.Current.SetCustomAttribute(ECPropertyPane.CreateHidePropertyAttribute(true, true)); } } instanceEnabler.CreateInstanceOnElement(element, instance, false); } }
1. 程序运行完的效果:
2. 再次打开DGN文件的效果
如果想实现随意隐藏和显示某个属性,需要您升级到最新版MSCE-U15,在C++函数中新增了
IsHiddenProperty, SetIsHiddenProperty, IsReadOnlyProperty, SetIsReadOnlyProperty四个函数。
请看如下文章中的说明:
communities.bentley.com/.../microstation-ce-sdk-update-15
您好,我使用的版本是:OBD Update5 版本,培训期间未涉及ClassEditor软件,是否能实现您所说的功能?
符老师说的是EditorCustomAttributes这个ECSchema里边的DontShowNullProperties这个ECClass,这是一个给其他ECClass添加CustomAttribute的ECClass,您在程序里边Load到DontShowNullProperties这个ECClass后,创建一个ECInstance,然后调用ECClass的对象实例的SetCustomAttribute可以设置这个ECClass下如果某个属性的值是空的话可以不显示。
您好,我在 ECObjects API 中查找到 ECPropertyPane Class 中 CreateDontShowNullPropertiesAttribute 函数
public static void CreateECDataTable(ECSchema ecSchema, IECClass iecClass) { ECSchema ecSchema = new ECSchema(TestSchema, 1, 0, "Cjxjy"); IECClass iecClass = ecSchema.AddClass(TestClass); iecClass.DisplayLabel = "测试属性表名"; var specification = ECPropertyPane.CreateDontShowNullPropertiesAttribute(); iecClass.SetCustomAttribute(specification); InitializeDataTable(); foreach (DataRow item in dataTable.Rows) { string propertyName = item["column1"].ToString() + "_" + item["column2"].ToString() + "(" + item["column3"].ToString() + ")"; string validName = propertyName; ECNameValidation.EncodeToValidName(ref validName); iecProperty.DisplayLabel = propertyName; } SchemaImportStatus schemaImportStatus = DgnECManager.Manager.ImportSchema(ecSchema, Session.Instance.GetActiveDgnFile(), new ImportSchemaOptions()); if (schemaImportStatus != SchemaImportStatus.Success) { return; } }
<?xml version="1.0" encoding="utf-8"?> <ECSchema schemaName="SchemaTest" nameSpacePrefix="Cjxjy" version="1.0" xmlns="http://www.bentley.com/schemas/Bentley.ECXML.2.0"> <ECSchemaReference name="Bentley_Standard_CustomAttributes" version="01.13" prefix="bsca" /> <ECClass typeName="ClassTest" displayLabel="测试属性表名" isDomainClass="True"> <ECCustomAttributes> <DisplayOptions xmlns="Bentley_Standard_CustomAttributes.01.13"> <Hidden>True</Hidden> <HideInstances>True</HideInstances> <HideRelated>False</HideRelated> </DisplayOptions> </ECCustomAttributes> <ECProperty propertyName="__x5c5e____x6027____x540d__1___x6570____x636e____x540d__1__x0028____x6570____x636e____x5355____x4f4d__1__x0029__" typeName="string" displayLabel="属性名1_数据名1(数据单位1)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__1___x6570____x636e____x540d__2__x0028____x6570____x636e____x5355____x4f4d__2__x0029__" typeName="string" displayLabel="属性名1_数据名2(数据单位2)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__1___x6570____x636e____x540d__3__x0028____x6570____x636e____x5355____x4f4d__3__x0029__" typeName="string" displayLabel="属性名1_数据名3(数据单位3)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__1___x6570____x636e____x540d__4__x0028____x6570____x636e____x5355____x4f4d__4__x0029__" typeName="string" displayLabel="属性名1_数据名4(数据单位4)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__1___x6570____x636e____x540d__5__x0028____x6570____x636e____x5355____x4f4d__5__x0029__" typeName="string" displayLabel="属性名1_数据名5(数据单位5)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__2___x6570____x636e____x540d__6__x0028____x6570____x636e____x5355____x4f4d__6__x0029__" typeName="string" displayLabel="属性名2_数据名6(数据单位6)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__2___x6570____x636e____x540d__7__x0028____x6570____x636e____x5355____x4f4d__7__x0029__" typeName="string" displayLabel="属性名2_数据名7(数据单位7)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__2___x6570____x636e____x540d__8__x0028____x6570____x636e____x5355____x4f4d__8__x0029__" typeName="string" displayLabel="属性名2_数据名8(数据单位8)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__2___x6570____x636e____x540d__9__x0028____x6570____x636e____x5355____x4f4d__9__x0029__" typeName="string" displayLabel="属性名2_数据名9(数据单位9)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__2___x6570____x636e____x540d__10__x0028____x6570____x636e____x5355____x4f4d__10__x0029__" typeName="string" displayLabel="属性名2_数据名10(数据单位10)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__3___x6570____x636e____x540d__11__x0028____x6570____x636e____x5355____x4f4d__11__x0029__" typeName="string" displayLabel="属性名3_数据名11(数据单位11)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__3___x6570____x636e____x540d__12__x0028____x6570____x636e____x5355____x4f4d__12__x0029__" typeName="string" displayLabel="属性名3_数据名12(数据单位12)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__3___x6570____x636e____x540d__13__x0028____x6570____x636e____x5355____x4f4d__13__x0029__" typeName="string" displayLabel="属性名3_数据名13(数据单位13)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__3___x6570____x636e____x540d__14__x0028____x6570____x636e____x5355____x4f4d__14__x0029__" typeName="string" displayLabel="属性名3_数据名14(数据单位14)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__3___x6570____x636e____x540d__15__x0028____x6570____x636e____x5355____x4f4d__15__x0029__" typeName="string" displayLabel="属性名3_数据名15(数据单位15)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__4___x6570____x636e____x540d__16__x0028____x6570____x636e____x5355____x4f4d__16__x0029__" typeName="string" displayLabel="属性名4_数据名16(数据单位16)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__4___x6570____x636e____x540d__17__x0028____x6570____x636e____x5355____x4f4d__17__x0029__" typeName="string" displayLabel="属性名4_数据名17(数据单位17)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__4___x6570____x636e____x540d__18__x0028____x6570____x636e____x5355____x4f4d__18__x0029__" typeName="string" displayLabel="属性名4_数据名18(数据单位18)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__4___x6570____x636e____x540d__19__x0028____x6570____x636e____x5355____x4f4d__19__x0029__" typeName="string" displayLabel="属性名4_数据名19(数据单位19)" /> <ECProperty propertyName="__x5c5e____x6027____x540d__4___x6570____x636e____x540d__20__x0028____x6570____x636e____x5355____x4f4d__20__x0029__" typeName="string" displayLabel="属性名4_数据名20(数据单位20)" /> </ECClass> </ECSchema>
问题还是存在于再次打开DGN文件的无值属性无法隐藏,
FindInstancesScope scopeTemp = FindInstancesScope.CreateScope(Session.Instance.GetActiveDgnFile(), new FindInstancesScopeOption()); int verMaj = 1, verMin = 3; IECSchema schemaCustomAtt = DgnECManager.Manager.LocateSchemaInScope(scopeTemp, "EditorCustomAttributes", verMaj, verMin, SchemaMatchType.LatestCompatible); if (schemaCustomAtt != null) { IECClass ecClassCate= schemaCustomAtt.GetClass("DontShowNullProperties"); IECInstance ecInsCate = ecClassCate.CreateInstance(); ecClass.SetCustomAttribute(ecInsCate); }
创建ECClass的时候添加这个属性
Answer Verified By: 明昊 刘
您好,郭老师。添加隐藏无值属性后,选取多个元素,属性栏显示时,只显示共有有值属性。如下图:
元素1,有两个附加属性:
元素2,有六个附加属性:
如何显示取并集的有值属性?
