环境:OPM UP7
语言:C#
问题:OPM SDK生成半径接头HVACRadiusTakeOffComponent,生成位置异常,如图所示,SDK生成的模型出现了碰撞,但是MAIN_PORT和BRANCH_PORT位置是正确的
生成接头代码如下:
//Specification string specification = "mEX-OPM"; //Main Width, Height of HVAC Rectangular/Oval component. double mainWidth = 450; double mainHeight = 300; //Length of HVAC Duct component. This is a property of the HVAC component. double ductLength = 2000; DPoint3d origin = new DPoint3d(0, 0, 0); if (PrepareForHVAC(specification)) { //Take off component with Rectangular duct. HVACRectangularDuctComponentData duct1Data = new HVACRectangularDuctComponentData(specification, mainWidth, mainHeight); duct1Data.SetProperty("LENGTH", ductLength.ToString()); HVACRectangularDuctComponent duct1 = new HVACRectangularDuctComponent(origin, duct1Data, 0, DrawingView.ViewTop, true); duct1.Create(); origin.X = 1000; HVACRadiusTakeOffComponentData takeoff1Data = new HVACRadiusTakeOffComponentData(specification, mainWidth, mainHeight); HVACRadiusTakeOffComponent takeoff1 = new HVACRadiusTakeOffComponent(origin, takeoff1Data, 0, DrawingView.ViewTop, true); takeoff1.AddComponentToBranch(duct1); takeoff1.Create(); }
在看,很复杂。
把HVAC_RADIUS_TAKEOFF的WIDTH_OFFSET的定义截一下图。
武老师,没有看到
Bob.Wu said:WIDTH_OFFSET
请问这个是在Design Conditions中吗
EC Class Editor 中看,例如我的:
截一下你的。
HVACRadiusTakeOffComponentData takeoff1Data = new HVACRadiusTakeOffComponentData(specification, mainWidth, mainHeight); takeoff1Data.Properties["WIDTH_OFFSET"] = "True";
我这里这样就对了。
您需要结合具体情况判断这个值什么时候为True,什么时候为False,推测和你将TakeOff添加到Duct的宽面还是高面有关。
Answer Verified By: Liaoyuan Zhang
