我电脑上装了MSCE,OPD等engine。请问怎么指定具体的engine?
如下代码所示:
Process p = new Process(); p.StartInfo.FileName = @"C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\OpenBuildingsDesigner.exe"; p.StartInfo.Arguments = "-automation"; p.Start(); Bentley.Interop.MicroStationDGN.Application msApp = null; for (; ; ) { try { //获取到之前启动的MSTN进程对象,这里加了异常处理是因为MSTN进程启动需要相应的时间。在这段时间里获取msApp会发生异常。所以在这里一直执行 //直到不发生异常才跳出循环 msApp = (Bentley.Interop.MicroStationDGN.Application)Interaction.GetObject(null, "MicroStationDGN.Application"); break; } catch (Exception) { continue; } } if (null == msApp) return; msApp.Visible = false; string seedFile = @"D:\CETest.DGN"; msApp.OpenDesignFile(seedFile, false); Point3d[] ptArr = new Point3d[2]; ptArr[0] = msApp.Point3dZero(); ptArr[1] = msApp.Point3dFromXYZ(10, 0, 0); LineElement lineEle = msApp.CreateLineElement1(null, ptArr); msApp.ActiveModelReference.AddElement(lineEle); MessageBox.Show("Success"); msApp.Quit();
Answer Verified By: fan yang
好的,谢谢老师。
