STFLinearMemberList myMemberList = new STFLinearMemberList(); STFLinearMember myMember; Bentley.Interop.MicroStationDGN.Point3d pPt=new Bentley.Interop.MicroStationDGN.Point3d(); Bentley.Interop.MicroStationDGN.Point3d qPt = new Bentley.Interop.MicroStationDGN.Point3d(); STFSectionList sectionList = new STFSectionList(); STFSection section; section = sectionList.AsSTFSection; section.SetName("CAO5"); pPt.X = 0; qPt.X = 1000; pPt.Y = qPt.Y= 0; pPt.Z = qPt.Z = 0; myMember = myMemberList.AsSTFLinearMember; myMember.SetPQPoints(ref pPt,ref qPt); myMember.SetSTFSection(section); myMember.SetPlacementPoint(5); myMember.SetCrossSectionReflection(true); myMember.CreateTFFormRecipeList(); myMember.Save(false);
各位老师好,我正在摸索通过C#创建梁柱,查阅了以往的帖子写了如上代码,发现在CreateTFFormRecipeList处OBD会崩溃掉,请问应该如何修改,如有相关代码实例不胜感激,谢谢!
https://communities.bentley.com/communities/other_communities/chinafirst/f/microstation-projectwise/220001/abd-v8i-c
参考此用户代码,按理说C#是能创建梁的吧,想找到自己错误的原因
OpenBuildingsDesignerSDK\OBDSDK\examples\buildingelement
这个例子下的生成柱代码应该是可以正确执行的。
BIM.Application app = Bentley.MstnPlatformNET.InteropServices.Utilities.ComApp; STFApplicationList stfAppList = new STFApplicationList(); STFApplication stfApp = stfAppList.AsSTFApplication; STFLinearMemberList lstFrame = stfApp.GetAllLinearMembers(app.ActiveModelReference); STFSectionList lstSection = stfApp.GetSectionListFromTFSecMgr(); //STFSectionList lstSection = stfApp.GetSection(); ; int scount = lstSection.GetCount(); List<string> Ls = new List<string>(); for (int i = 0; i < lstSection.GetCount(); ++i) { STFSectionList Sect = lstSection.GetNode(i); STFSection Section = Sect.AsSTFSection; Ls.Add(Section.GetName()); }
这样应该能导出界面名字了
