ORD旗舰版:CIMManagedSurface例子中CreateSurfaceBySweepAlongPathTool运行崩溃
 MSBsplineCurve SectionCurve1 = GetMSBsplineCurveFromElement(ElementAgenda.GetEntry(0));  // start profile section curve
            MSBsplineCurve SectionCurve2 = GetMSBsplineCurveFromElement(ElementAgenda.GetEntry(1));  // end profile section curve
            MSBsplineCurve PathCurve1 = GetMSBsplineCurveFromElement(ElementAgenda.GetEntry(2)); // path 1
            MSBsplineCurve PathCurve2 = GetMSBsplineCurveFromElement(ElementAgenda.GetEntry(3)); // path 2
            BCIMNETGMesh.SurfaceTraceSweepParam param;
            param.scale = 0;
            param.scaleHeight = 0;
            param.firstConstraint = 0;
            param.lastConstraint = 0;
            param.alignment = 1; //0 normal 1 parallel
            param.selfRepair = 1;
            param.unused = 0;
            List<MSBsplineCurve> sectionCurves = new List<MSBsplineCurve>();
            List<MSBsplineCurve> pathCurves = new List<MSBsplineCurve>();
            sectionCurves.Add(SectionCurve1);
            sectionCurves.Add(SectionCurve2);
            pathCurves.Add(PathCurve1);
            pathCurves.Add(PathCurve2);
            int mode = 2; // Sweep mode   0:  2Profile+1Path  1: 1Profile+2Path  2: 2Profile+2Path
            MSBsplineSurface bsurface = null;
            if (!BCIMNETGMesh.MeshSDKNET.CreateSurfaceBySweepAlongPath(ref bsurface, sectionCurves, pathCurves, mode, param, model) )
                return StatusInt.Error;
            AddSurfaceToModel(bsurface);
            return StatusInt.Success;
35745.test.dgn
  • 问题在于这个
    因为例子里面是获取BSpline的曲线的,但您给我发的截面是一个shape,所以获取的是空值,我将您模型的shape转成BSPline后就可以了:
    您可以稍微修改一下代码,可以支持shape的选取,然后再测试一下。
