老师,我采用代码对一部分区域进行了填充,后续做了一个双击修改图案得功能,可是修改后将孔洞也填充了;麻烦老师帮忙看下
void AreaPatternTest(Dpoint3d point) { if (wcscmp(g_PartTernStrcut.m_wchCellFilePath,L"") == 0) { mdlDialog_openMessageBox(DIALOGID_MsgBoxOK, L"请浏览单元库文件并选择填充图案进行填充", MessageBoxIconType::Warning); return; } if (wcscmp(g_PartTernStrcut.m_wchGriaphicName, L"") == 0) { mdlDialog_openMessageBox(DIALOGID_MsgBoxOK, L"请先选择填充图案", MessageBoxIconType::Warning); return; } BeFileName outFileName, inFileName(g_PartTernStrcut.m_wchCellFilePath); // AreaPat.cel is under MS_CELL pointed folder mdlCell_attachLibrary(outFileName, &inFileName, NULL, 1); PatternParamsPtr params = PatternParams::Create(); params->SetCellName(g_PartTernStrcut.m_wchGriaphicName); params->SetPrimarySpacing(g_PartTernStrcut.m_dRowDistance * UOR_PER_MM); //设置角度 double iPartCount = 0.0; if (g_PartTernStrcut.m_dAngel != 0) { iPartCount = (double)180 /fmod(g_PartTernStrcut.m_dAngel,180); params->SetPrimaryAngle(PI / iPartCount); }//设置图案角度的45° else { params->SetPrimaryAngle(0); } params->SetSecondarySpacing(g_PartTernStrcut.m_dColumnDistance * UOR_PER_MM); // params->SetSecondaryAngle(PI / 3); params->SetScale(g_PartTernStrcut.m_dRatio); MSElementDescrP elementDesc = NULL; mdlRegion_floodFillWithHoles(&elementDesc, NULL, EleGraphics.m_AllboundaryElmsEdp, NULL, MASTERFILE, &point, 0xffff, true, 200, -1); //mdlRegion_floodFill(&elementDesc, NULL, EleGraphics.m_AllboundaryElmsEdp, NULL, &point, 200, NULL); if (elementDesc == NULL) { return; } EditElementHandle eeh(elementDesc,true,false,ACTIVEMODEL); /*IAreaFillPropertiesEdit * fillEditP = dynamic_cast<IAreaFillPropertiesEdit *>(&eeh.GetHandler()); if (fillEditP == NULL) { return; } fillEditP->AddPattern(eeh, *params, NULL);*/ eeh.AddToModel(); ElementRefP OldEehRef = eeh.GetElementRef(); bvector<DependencyRoot> boundaryRoots; ElementAgenda boundary; boundary.Insert(eeh); DependencyRoot depRoot; depRoot.elemid = eeh.GetElementId(); depRoot.refattid = 0; depRoot.ref = eeh.GetElementRef(); boundaryRoots.push_back(depRoot); RegionParams paramFill; paramFill.SetAssociative(false); paramFill.SetDirty(true); paramFill.SetInvisibleBoundary(true); paramFill.SetType(RegionType::Flood); paramFill.SetFloodParams(RegionLoops::Ignore, 0.0001); paramFill.SetFlattenBoundary(true, NULL); EditElementHandle eehRegion; if (SUCCESS != AssocRegionCellHeaderHandler::CreateAssocRegionElement(eehRegion, boundary, &boundaryRoots[0], 1, &point, 1, paramFill, L"MyAssocRegion")) { mdlDialog_dmsgsPrint(L"Error in creating AssocRegionElement"); return; } IAreaFillPropertiesEdit * fillEditP = dynamic_cast<IAreaFillPropertiesEdit *>(&eehRegion.GetHandler()); if (fillEditP == NULL) { return; } fillEditP->AddPattern(eehRegion, *params, NULL); //添加XAttribute属性 XAttributeHandlerId handler(Major, Minor); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_CELLPATH, sizeof(wchar_t)*(wcslen(g_PartTernStrcut.m_wchCellFilePath)+1), &g_PartTernStrcut.m_wchCellFilePath); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_ANGEL, sizeof(double), &g_PartTernStrcut.m_dAngel); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_Ratio, sizeof(double), &g_PartTernStrcut.m_dRatio); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_ROWDISTANCE, sizeof(double), &g_PartTernStrcut.m_dColumnDistance); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_COLUMNDISTANCE, sizeof(double), &g_PartTernStrcut.m_dColumnDistance); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_CELLNAME, sizeof(wchar_t)*(wcslen(g_PartTernStrcut.m_wchGriaphicName)+1), &g_PartTernStrcut.m_wchGriaphicName); //wchar_t name[256] = {0}; //void* voidPtr = NULL; eehRegion.AddToModel(); //XAttributeHandlerId handler('SR'/*Major*/, 503/*Minor*/); //if (XAttributeHandle::HasAttribute(eehRegion.GetElementDescrCP()->h.elementRef, handler, XATTRIBUTE_ID_CELLPATH)) // 通过查找xattribute类型来判断是否为门窗 //{ // XAttributeHandle xah(eehRegion.GetElementDescrCP()->h.elementRef, handler, XATTRIBUTE_ID_CELLPATH); // //voidPtr = const_cast<void*>(xah.PeekData()); // wcscpy_s(name, (wchar_t*)(xah.PeekData())); //} ElementPropertiesSetterPtr remapper = ElementPropertiesSetter::Create(); remapper->SetTransparency(90);//设置周边线框透明度,不能删除,删除后填充区域线条变成虚线 remapper->Apply(eeh); eeh.ReplaceInModel(OldEehRef); }
void ModifyFillGraphics() { BeFileName outFileName, inFileName(g_PartTernStrcutModify.m_wchCellFilePath); // AreaPat.cel is under MS_CELL pointed folder mdlCell_attachLibrary(outFileName, &inFileName, NULL, 1); PatternParamsPtr params = PatternParams::Create(); params->SetCellName(g_PartTernStrcutModify.m_wchGriaphicName); params->SetPrimarySpacing(g_PartTernStrcutModify.m_dRowDistance * UOR_PER_MM); //设置角度 double iPartCount = 0.0; if (g_PartTernStrcutModify.m_dAngel != 0) { iPartCount = (double)180 / fmod(g_PartTernStrcutModify.m_dAngel, 180); params->SetPrimaryAngle(PI / iPartCount); }//设置图案角度的45° else { params->SetPrimaryAngle(0); } params->SetSecondarySpacing(g_PartTernStrcutModify.m_dColumnDistance * UOR_PER_MM); // params->SetSecondaryAngle(PI / 3); params->SetScale(g_PartTernStrcutModify.m_dRatio); EditElementHandle eehRegion(g_iCurrentId, ACTIVEMODEL); ElementRefP odlRefP = eehRegion.GetElementRef(); IAreaFillPropertiesEdit * fillEditP = dynamic_cast<IAreaFillPropertiesEdit *>(&eehRegion.GetHandler()); if (fillEditP == NULL) { return; } //fillEditP->RemovePattern(eehRegion,0); fillEditP->AddPattern(eehRegion, *params, NULL); //添加XAttribute属性,先删再加 XAttributeHandlerId handler(Major, Minor); eehRegion.ScheduleDeleteXAttribute(handler, XATTRIBUTE_ID_CELLPATH); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_CELLPATH, sizeof(wchar_t)*(wcslen(g_PartTernStrcutModify.m_wchCellFilePath)+1), &g_PartTernStrcutModify.m_wchCellFilePath); eehRegion.ScheduleDeleteXAttribute(handler, XATTRIBUTE_ID_ANGEL); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_ANGEL, sizeof(double), &g_PartTernStrcutModify.m_dAngel); eehRegion.ScheduleDeleteXAttribute(handler, XATTRIBUTE_ID_Ratio); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_Ratio, sizeof(double), &g_PartTernStrcutModify.m_dRatio); eehRegion.ScheduleDeleteXAttribute(handler, XATTRIBUTE_ID_ROWDISTANCE); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_ROWDISTANCE, sizeof(double), &g_PartTernStrcutModify.m_dColumnDistance); eehRegion.ScheduleDeleteXAttribute(handler, XATTRIBUTE_ID_COLUMNDISTANCE); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_COLUMNDISTANCE, sizeof(double), &g_PartTernStrcutModify.m_dColumnDistance); eehRegion.ScheduleDeleteXAttribute(handler, XATTRIBUTE_ID_CELLNAME); eehRegion.ScheduleWriteXAttribute(handler, XATTRIBUTE_ID_CELLNAME, sizeof(wchar_t)*(wcslen(g_PartTernStrcutModify.m_wchGriaphicName)+1), &g_PartTernStrcutModify.m_wchGriaphicName); //eehRegion.AddToModel(); eehRegion.ReplaceInModel(odlRefP); }
请提供一下您的测试文件。
测试1.dgn
您在ModifyFillGraphics函数里边再重新创建这个eehRegion,不要通过ID获取现有的,然后对新创建的eehRegion进行填充,最后用这个新元素替换掉老元素再试试看。
好的,我尝试下,我现在尝试的是将eehRegion打散,修改打散后的元素是没有问题的。
