在元素属性面板中,对于自定义EC属性,可不可以实现鼠标悬浮(或点击)某个属性,出现一些相关提示信息。EC shcema文件自定义属性时有“description”属性的定义,能否通过这个实现。就比方说鼠标放在构件类型属性处,会出现一些提示。
悬浮应该是没办法的,点击的话,可以在输入焦点进入到属性后的输入框时,触发某个函数,详细用法可参考这篇wiki里边用到的ECPropertyUITypeEditor,communities.bentley.com/.../ec---ecpropertyuitypeeditor
我理解是可以通过对属性面板的自定义,添加某些控件来实现类似功能。就像上图类似,点击Text时,下面面板就会出现提示。是可以这样理解的吧?提示信息是不是可以从EC shcema文件里面进行提取呢,就比方说提取“description”属性
这个实现起来挺麻烦的:
var ecProp = ecclass.FindProperty("PropDou"); IECInstance customExtendedType = ECPropertyPane.CreateExtendedType("CustomType"); ECPropertyPane.SetExtendedTypePropertyValueUIHandler(customExtendedType, new System.Drawing.Design.PropertyValueUIHandler(MyPropertyValueUIHandler)); ECPropertyPane.SetExtendedType(ecProp, customExtendedType);
其中MyPropertyValueUIHandler如下所示:
static bool is_init = true; public static void MyPropertyValueUIHandler(ITypeDescriptorContext context, PropertyDescriptor propDesc, ArrayList valueUIItemList) { if(!is_init) { return; } is_init = false; Type t = context.GetType(); System.Reflection.PropertyInfo propertyInfo = t.GetProperty("OwnerGrid"); object labelTxtColor = propertyInfo.GetValue(context, null); MultiPropertyGrid muPropGrid = labelTxtColor as MultiPropertyGrid; var type = labelTxtColor.GetType(); var propInfo = type.GetProperty("Controls"); var controls = propInfo.GetValue(labelTxtColor) as Control.ControlCollection; propInfo = propInfo = type.GetProperty("Container"); var container = propInfo.GetValue(labelTxtColor) as IContainer; if (null != controls) { foreach (var curVar in controls) { if (curVar.GetType().Name != "PropertyGridView") continue; Control curCtl = curVar as Control; foreach (var curSubCtl in curCtl.Controls) { if (null != curSubCtl) { if (((System.Windows.Forms.Control)curSubCtl).AccessibleName == "PropDou") { ToolTip toolTip1 = new ToolTip(); toolTip1.SetToolTip(curSubCtl as Control, "My double value"); } } } } } }
效果如下所示:
