写了一个函数测试道岔模型的导入,但是在导入的时候ORD会异常崩溃,代码如下:
/// <summary> /// 测试道岔建模 /// </summary> public static void TestTurnoutModeling() { try { Bentley.Interop.MicroStationDGN.Application msApp = Bentley.MstnPlatformNET.InteropServices.Utilities.ComApp; // 读取设备配置信息 XmlNode rootNode = XmlTools.GetFacilityRootNode(); //XmlNode turnoutNodeLeft = XmlTools.GetFacilityByName(rootNode, NameResources.ItemType_ATF_NO18TurnOutLeftInformation); //XmlNode turnoutNodeRight = XmlTools.GetFacilityByName(rootNode, NameResources.ItemType_ATF_NO18TurnOutRightInformation); BIM.Point3d position1 = new BIM.Point3d(); position1.X = 0; position1.Y = 469450; position1.Z = 3455; BIM.Point3d position2 = new BIM.Point3d(); position2.X = 0; position2.Y = 469600; position2.Z = 3455; BIM.Point3d scalePoint = new BIM.Point3d(); scalePoint.X = 1; scalePoint.Y = 1; scalePoint.Z = 1; // 需要根据角度设置道岔旋转角,包括水平与垂直转角,Matrix3d为旋转矩阵 BIM.Matrix3d matrizIdentidad = msApp.Matrix3dIdentity(); // 无任何旋转 // 构建三维模型 Element element1 = CreateNormalCell("F:\\18号单开道岔单开道岔道床组装图-左开.dgn", "18号左开道岔", position1, scalePoint, matrizIdentidad); // 构建三维模型 Element element2 = CellTCreateNormalCell("F:\\18号单开道岔单开道岔道床组装图-右开.dgn", "18号右开道岔", position2, scalePoint, matrizIdentidad); } catch (Exception ex) { MessageBox.Show("股道建模错误:" + ex.ToString()); } } /// <summary> /// 将一个dgn文件中的构建模板导入到指定坐标点位置 /// </summary> /// <param name="dgnPath"></param> /// <param name="cellName"></param> /// <param name="point">指定坐标点</param> /// <param name="scalePoint"></param> /// <param name="matrizIdentidad"></param> public static Element CreateNormalCell(string dgnPath, string cellName, BIM.Point3d point, BIM.Point3d scalePoint, BIM.Matrix3d matrizIdentidad) { Bentley.Interop.MicroStationDGN.Application msApp = Bentley.MstnPlatformNET.InteropServices.Utilities.ComApp; msApp.AttachCellLibrary(dgnPath); BIM.CellElement cellEle = msApp.CreateCellElement2(cellName, ref point, ref scalePoint, true, ref matrizIdentidad); // cellElement转普通element long cellElePtr = cellEle.MdlElementDescrP(); Element elem = ORDCellTools.ConvertToDgnNetEle(cellEle); elem.AddToModel(); return elem; }
CreateNormalCell这个函数是根据选择的Cell文件将模型插入到固定的位置上。这个函数被调用了两次,分别导入两种道岔模型。
目前经过调试,发现是在第二个CreateNormalCell这一句会导致ORD崩溃,崩溃的时候ORD没有任何报错,这个异常同时也捕获不到,ORD就直接自动关闭了。
经过调试,程序崩溃在CreateNormalCell函数的elem.AddToModel()这一句。
但是如果让两个CreateNormalCell都调用同一个dgn文件(F:\\18号单开道岔单开道岔道床组装图-左开.dgn)的时候,代码就可以正常执行且导入文件。
此外,我在MicroStation上也测试了上述代码,能够同时导入两种道岔不会报错。
我所用的dgn文件如下。9号单开道岔-右开.dgn 9号单开道岔-左开.dgn
为何第二次调用的函数名又换成了CellTCreateNormalCell而不是CreateNormalCell呢?
对了,我使用的ORD版本是:
不好意思,付老师,是笔误,两次调用都是CreateNormalCell。
另外,我刚刚又测试了一下,我使用MicroStation和ORD 2019 Release 1这两个版本都可以正常运行。
但是使用ORD Ultimate For China版就会报错。
我在如下版本测试是没有问题的,唯一区别是ORDCellTools.ConvertToDgnNetEle我用的是这个链接里边封装好的函数,您试试改成引用这里的函数看能否正常运行:https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/60848/addin
