1、当我已有上图所示一条管线编号,名称为COG-1511-0001-CL01-300;
2、我想通过代码创建一条管线编号,名称为COG-1511-0001-CL01-350,相对上条管线编号只修改了管径。这时打印出来的名称还是第一条的管线编号,没有创建出第二条管线编号。
ItemStatus status = NetworkSystem.CreatePipingNetworkSystem(out pipeline, namedItems, specification, nominalDiameter, number.ToString(), null); MessageBox.Show(pipeline.Name.ToString(), "Name");
请问该如何成功创建第二条管线编号?
建议你可以看看返回的status是什么值
创建第二条管线编号时返回的是Duplicate
如果文件已有某管线编号,新管线编号只修改了管径。此时用程序创建是不成功的,但手动是可以的,这种情况只能用手动创建么?
符老师,我这两天刚好也在用这个接口,看一下opm sdk,感觉是sdk封装有bug,软件本身是可以创建的,用sdk的接口不行,里面只判断了等级库和number,这个显然是不合理的
管线号由那几位属性拼接成,是可以在schema中定义的,判断管线号是否重复,应该判断NAME属性值是否重复
两位好!SDK中提供的API函数往往不是软件界面中工具的直接对应。一个工具的后台代码往往由很多行代码组成。这样做当然是为了SDK的灵活性。
所以,是否可以推断工具的做法是:①先判断该管线号是否存在?②如果存在就删除它;③用新的管线参数创建该管线号。
private static ItemStatus CreateNetworkSystem(out NetworkSystem networkSystem, NetworkSystemType networkSystemType, List<NamedItem> namedItems, string specification, string number, Dictionary<string, string> properties) { networkSystem = null; if (namedItems == null) { return ItemStatus.Failed; } if (NetworkSystemExists(networkSystemType, namedItems, specification, number, out string name)) { networkSystem = new NetworkSystem(); networkSystem.m_name = name; networkSystem.m_type = networkSystemType; ComponentBase.SetActiveNetworkSystem(networkSystem); return ItemStatus.Duplicate; } try { BMECApi instance = BMECApi.Instance; string networkSystem2 = GetNetworkSystem(networkSystemType); IECInstance iECInstance = instance.InstanceManager.CreateECInstance(networkSystem2); iECInstance.InstanceId = "mechanical"; if (!string.IsNullOrEmpty(specification)) { iECInstance["SPECIFICATION"].StringValue = specification; } if (!string.IsNullOrEmpty(specification)) { iECInstance["NUMBER"].StringValue = number; } SetNamedItemsAsProperties(iECInstance, networkSystemType, namedItems); DgnUtilities instance2 = DgnUtilities.GetInstance(); instance2.WriteECInstanceToDgn(iECInstance, instance2.GetDGNConnection()); SetNamedItems(iECInstance, networkSystemType, namedItems); SetProperties(iECInstance, properties); instance2.SaveModifiedInstance(iECInstance, instance2.GetDGNConnection()); networkSystem = new NetworkSystem(); networkSystem.m_specification = specification; networkSystem.m_number = number; networkSystem.m_namedItems = namedItems; networkSystem.m_name = iECInstance["NAME"].StringValue; networkSystem.m_type = networkSystemType; networkSystem.m_instance = iECInstance; ComponentBase.SetActiveNetworkSystem(networkSystem); } catch { return ItemStatus.Failed; } return ItemStatus.Success; }
这个是SDK中创建管线号的逻辑,本质上是创建了ECInstance,然后设置相关属性,可以手动创建。
但是如果想要正常使用SDK,必须设置ComponentBase的s_networkSystem,而对应的方法是internal static void SetActiveNetworkSystem(NetworkSystem networkSystem),可以考虑使用反射调用
Type type = typeof(ComponentBase); MethodInfo methodInfo = type.GetMethod("SetActiveNetworkSystem", BindingFlags.Public | BindingFlags.NonPublic | BindingFlags.Static); methodInfo?.Invoke(null, new object[] { networkSystem }); hvacIdentificationCode = networkSystem.Name; StandardPreferencesUtilities.SetActiveHVACNetworkSystem(networkSystem);
SDK中很多非常有用的函数都是internal,不知道是为什么没有公开
