[MSCE C#]获取控件中平面图案的顶点坐标
各位老师,假如三位空间中有这样一个平面图案(cell),该如何去获取它的四个顶点坐标?
  • 您指的是元素的包围盒还是下图中箭头所指的四个点的坐标,请注意元素旋转到不同方位时,这两组坐标是不一样的,如果是包围盒的话,有专门的函数DisplayableElement.CalcElementRange可以拿到。如果是箭头所指的点的坐标的话,需要将元素变换到局部坐标系下,然后获取其包围盒的四个点的左边,再变换回全局坐标系下。
  • 郭老师,是指的箭头所指的顶点坐标,对于变换过程,我是这样算的,画出的矩形与这个图案重合,就算对了,但是结果不对额
     cell.CalcElementRange(out DRange3d range);
    DPoint3d lb = range.Low; //左下角
    DPoint3d rt = range.High; //右上角
    cell.GetTransformOrigin(out DPoint3d origin); //原点
    cell.GetOrientation(out DMatrix3d orientation); //旋转矩阵
    DTransform3d tran = DTransform3d.FromMatrixAndFixedPoint(orientation, origin);
    DTransform3d tranMoveToZero = DTransform3d.FromTranslation(origin * -1);
    tran = tranMoveToZero * tran;
    tran.Multiply(out DPoint3d lb0, lb);
    tran.Multiply(out DPoint3d rt0, rt);
    lb0.Z = 0;
    rt0.Z = 0;
    DPoint3d[] pos = new DPoint3d[] {
            new DPoint3d(lb0.X, rt0.Y, 0),
            rt0,
            new DPoint3d(rt0.X, lb0.Y, 0),
            lb0,
    ShapeElement eleRect = new ShapeElement(dgnModel, null, pos);
    orientation.TryInvert(out DMatrix3d rot);
    var tranToOrg = DTransform3d.FromMatrixAndTranslation(rot, origin);
    eleRect.ApplyTransform(new TransformInfo(tranToOrg));
    eleRect.AddToModel();
  • 请看如下代码:
    CellHeaderElement cellEle = ele1 as CellHeaderElement;
                    cellEle.GetOrientation(out DMatrix3d orientation);
                    orientation.TryInvert(out DMatrix3d oriInvert);
                    cellEle.GetTransformOrigin(out DPoint3d origin);
                    DTransform3d dtran = DTransform3d.FromMatrixAndFixedPoint(oriInvert, origin);
                    cellEle.ApplyTransform(new TransformInfo(dtran));
                    cellEle.CalcElementRange(out DRange3d range);
                    DPoint3d[] ptArr = new DPoint3d[4] { range.Low,new DPoint3d(range.High.X,range.Low.Y,range.Low.Z), range.High,
                    new DPoint3d(range.Low.X,range.High.Y,range.Low.Z)};
                    dtran = DTransform3d.FromMatrixAndFixedPoint(orientation, origin);
                    dtran.MultiplyArrayInPlace(ptArr);
                    CurvePrimitive cvePri = CurvePrimitive.CreateLineString(ptArr);
                    DraftingElementSchema.ToElement(Session.Instance.GetActiveDgnModel(), cvePri, null).AddToModel();
  • 郭老师,这里有个问题,就是我把现有的线条组合成一个cell,那它的旋转矩阵是单位矩阵,上面的方法计算不出顶点坐标
  • 例如我图里的cell,它的旋转矩阵是单位矩阵,但是它实际在XOZ平面上
