OBM版本为 “Setup_OpenBridgeModelerx64_10.04.00.047_zh-CN_Full”,离线安装包已经制作完成,安装时出现错误
日志如下
[27B0:4140][2018-12-11T08:55:15]i001: Burn v3.10.3.3007, Windows v10.0 (Build 17134: Service Pack 0), path: C:\Users\LW\AppData\Local\Temp\{BC4C9934-9D68-4BF6-92D9-C1EB77CE0381}\.cr\Setup_OpenBridgeModelerx64_10.04.00.047_zh-CN_Full.exe[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeExeName' to value 'OpenBridgeModeler'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'CHS'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]OpenBridgeModeler\ActivationWizard.exe'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'NotODPackageIdExtractionList' to value 'NDP462-KB3151800-x86-x64-AllOS-ENU;UsersAddedPackageInstaller'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\OpenBridge Modeler CONNECT Edition\'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\OpenBridge Modeler CONNECT Edition\'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'ConfigurationDirectory_V1' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'Custom_ConfigurationDirectory_Path' to value '[CommonAppDataFolder]Bentley\OpenBridge Modeler CONNECT Edition\Configuration'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;LumenRTInstallDirectory;LumenRTUserName;LumenRTCompanyName;SharedConfigurationDirectory'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;LumenRTInstallDirectory'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeKBList' to value 'KB2999226;KB2919355'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'PackageCacheHtmlHelpPageGuid' to value 'GUID-F0AAA55A-598A-408E-B326-342DA76E049D.html'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BundleHelpConfigurationWhatsNewChildHtml' to value 'GUID-47192D89-C83C-49EF-9398-599ECDA8F97E.html'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{345CC395-FC89-4AA9-BAD8-B2FF615212B2}'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeBundleCulture' to value 'zh-CN'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeBuildType' to value 'Release'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeBundleShortName' to value 'OpenBridgeModeler'[27B0:4140][2018-12-11T08:55:15]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
另外,离线安装包无法选择安装路径,只能安装在默认C盘
你好,我也出现了这个问题,请问你解决了吗
多次尝试后发现需要先卸载2个软件再装需要装的Bentley软件,分别是connection client,bentley dgndb imodel importer,卸载后重启计算机再安装就可以了
好的,谢谢
您好,我按照你的方式但还是会这种情况,请问方便加下你的联系方式吗,指导下我如何解决这个问题
忘记说了还要清理下注册表,把上面的2个软件的注册表信息清理下
