我想老师帮忙看下我这个路线文件,我用的obm是最新的10.07.03,昨天用ord创建的路线,平面,纵断都没问题。桥面板模板也没有问题。为什么就是放不上去?我添加桥梁的类型是beam slab,改成CONCRET BOX 倒是能在这个路线上方放高级桥面板。但是我要放置的桥梁类型是小箱梁的。路线3.dgn
<?xml version="1.0" encoding="utf-8"?> <PowerBridgeTemplate xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Version="1.0" xmlns="http://www.example.org/NewXMLSchema"> <Category name="New Category" /> <Category name="Decks"> <SubCategory name="五和大道"> <SubCategory name="桥面板"> <Template name="南坪快速路-左幅" description="" guid="98325982-6304-4419-8187-24834dc3222a" lastRevisedDate="2019-11-29" lastRevisedBy="dzg" versionMajor="1" versionMinor="13"> <Points> <Point name="P_0" x="-1.9809889745571652" y="-83.06085782378176" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Vertical" value="-0.09" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_1" x="276.57848207062324" y="-95.811174609188967" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="8" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Slope" value="-0.015" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_2" x="274.7870870011011" y="-122.38747735844015" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="0" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Vertical" value="-0.04" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_3" x="-268.96727469492436" y="-85.73531803575888" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="-8" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Slope" value="-0.015" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_4" x="-267.58024195690746" y="-65.157946468862988" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Vertical" value="0.04" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> </Point> </Points> <Lines> <Line name="L_0-0"> <PointRef name="P_0" /> <PointRef name="P_1" /> </Line> <Line name="L_0-1"> <PointRef name="P_1" /> <PointRef name="P_2" /> </Line> <Line name="L_0-2"> <PointRef name="P_2" /> <PointRef name="P_3" /> </Line> <Line name="L_0-3"> <PointRef name="P_3" /> <PointRef name="P_4" /> </Line> <Line name="L_0-4"> <PointRef name="P_4" /> <PointRef name="P_0" /> </Line> </Lines> <Arcs /> <Ellipses /> <Components> <Component name="COMP_0"> <LineRef name="L_0-0" /> <LineRef name="L_0-1" /> <LineRef name="L_0-2" /> <LineRef name="L_0-3" /> <LineRef name="L_0-4" /> </Component> </Components> <KeyPoints> <TopLeft>P_4</TopLeft> <TopRight>P_1</TopRight> <BottomLeft>P_3</BottomLeft> <BottomRight>P_2</BottomRight> </KeyPoints> <WetJointKeyPoints /> </Template> <Template name="南坪快速路右幅1号桥" description="" guid="f6cbbb59-5b1b-45a9-a8fd-8a92167d462a" lastRevisedDate="2019-11-29" lastRevisedBy="dzg" versionMajor="1" versionMinor="11"> <Points> <Point name="P_0" x="0" y="0" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="0" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Vertical" value="-0.09" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_1" x="152.24751132041285" y="-19.13295558720904" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="8" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Slope" value="-0.015" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_2" x="149.31648110183014" y="-39.465245671730464" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="0" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Vertical" value="-0.04" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_3" x="-159.8954341728996" y="5.10963811403804" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="-8" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Slope" value="-0.015" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_4" x="-157.3618725451031" y="22.68472472924185" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Horizontal" value="0" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Vertical" value="0.04" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> </Point> </Points> <Lines> <Line name="L_0-0"> <PointRef name="P_0" /> <PointRef name="P_1" /> </Line> <Line name="L_0-1"> <PointRef name="P_1" /> <PointRef name="P_2" /> </Line> <Line name="L_0-2"> <PointRef name="P_2" /> <PointRef name="P_3" /> </Line> <Line name="L_0-3"> <PointRef name="P_3" /> <PointRef name="P_4" /> </Line> <Line name="L_0-4"> <PointRef name="P_4" /> <PointRef name="P_0" /> </Line> </Lines> <Arcs /> <Ellipses /> <Components> <Component name="COMP_0"> <LineRef name="L_0-0" /> <LineRef name="L_0-1" /> <LineRef name="L_0-2" /> <LineRef name="L_0-3" /> <LineRef name="L_0-4" /> </Component> </Components> <KeyPoints> <TopLeft>P_4</TopLeft> <TopRight>P_1</TopRight> <BottomLeft>P_3</BottomLeft> <BottomRight>P_2</BottomRight> </KeyPoints> <WetJointKeyPoints /> </Template> </SubCategory> </SubCategory> </Category> </PowerBridgeTemplate>
您好,我们这边测试一下,测试后给您答复
您好,我们这边用您的路线创建的beam slab,放置出来没问题呢。另外放模板跟桥梁类型应该是没关系的。您可以检查下工作空间,单位设置是否有误
好的,感谢您!
