练习建了一个箱梁的变截面模板,翼板端部厚度变截面出错,变量调整同一数值可以生成。请教老师帮忙看看,不胜感激。
<?xml version="1.0" encoding="utf-8"?> <PowerBridgeTemplate xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Version="1.0" xmlns="http://www.example.org/NewXMLSchema"> <Category name="New Category" /> <Category name="Decks"> <SubCategory name="Standard Templates"> <SubCategory name="我的模板"> <SubCategory name="贾鲁河桥练习"> <Template name="4号墩3-3(右幅" description="" guid="8d9a1ac7-076b-4fcf-94a9-f5879dbbff59" lastRevisedDate="2020-07-01" lastRevisedBy="zlwwxc168" versionMajor="2" versionMinor="85"> <Points> <Point name="P_1" x="-9.7500000000000071" y="0.19499999999996417" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.19499999999996417" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Horizontal" value="-9.7500000000000071" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_8" x="-2.9103830456733705E-15" y="-1.6155871338926323E-31" isSuperelevationPI="false"> <Constraint type="None" /> <Constraint type="None" /> </Point> <Point name="P_6" x="9.7500000000000018" y="-0.19499999999999881" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="-0.19499999999999881" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Horizontal" value="9.75" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_0" x="9.7500000000000018" y="-0.37499999999999883" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="-0.18000000000000002" secondaryValue="0.0035992802159280014" lockTo="start" parent="P_6" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P0翼板厚度" /> <Constraint type="None" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="" /> </Point> <Point name="P_5" x="6.4999999999999956" y="-0.830139986002799" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="-0.4551399860028002" secondaryValue="6.5152998700259914" lockTo="start" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P5翼板厚度" /> <Constraint type="Horizontal" value="6.4999999999999956" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_2" x="6.4999999999999956" y="-2.4999999999999996" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Horizontal" value="6.4999999999999956" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_3" x="0" y="-2.5" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="-2.5" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Horizontal" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_4" x="-6.5" y="-2.5" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> <Constraint type="Horizontal" value="-6.5" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_7" x="-6.5000000000000044" y="-0.57013998600282279" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="-0.58513998600278694" secondaryValue="-6.4872998700259963" lockTo="end" parent="P_9" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P7翼板厚度" /> <Constraint type="Horizontal" value="-6.5000000000000044" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_9" x="-9.7500000000000071" y="0.014999999999964167" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="-0.18" secondaryValue="0.0035992802159273639" lockTo="start" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P9翼板厚度" /> <Constraint type="Horizontal" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="" /> </Point> <Point name="P_10" x="-0.25" y="-0.69505999400120055" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="9.515898210517836" lockTo="start" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P10顶板厚度" /> <Constraint type="Horizontal" value="-0.45" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P10中腹板宽度" /> </Point> <Point name="P_11" x="-0.25" y="-1.9000000000000001" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P11底板厚度" /> <Constraint type="Horizontal" value="-0.45" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P11中腹板宽度" /> </Point> <Point name="P_12" x="-0.55" y="-2.2" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P12底板厚度" /> <Constraint type="None" referenceP1="" referenceP2="" /> </Point> <Point name="P_13" x="-5.7" y="-2.2" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P13底板厚度" /> <Constraint type="Horizontal" value="0.79999999999999982" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_14" x="-6.0000000000000009" y="-1.9000000000000001" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P14底板厚度" /> <Constraint type="Horizontal" value="0.7" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P14左腹板宽度" /> </Point> <Point name="P_15" x="-6.0000000000000053" y="-0.580059994001221" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="3.7647483254948355" lockTo="start" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" /> <Constraint type="Horizontal" value="-4.4408920985006262E-15" parent="P_14" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="" /> </Point> <Point name="P_16" x="-4.8002399280239985" y="-0.20405519544073683" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="-4.795199880023997" lockTo="end" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P16顶板厚度" /> <Constraint type="None" referenceP1="" referenceP2="" /> </Point> <Point name="P_17" x="-1.4497600719760084" y="-0.2710647925616847" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="-1.4440499950009968" lockTo="end" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P17顶板厚度" /> <Constraint type="None" referenceP1="" referenceP2="" /> </Point> <Point name="P_18" x="1.4497600719760082" y="-0.32905519544071971" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="1.4560499950010022" lockTo="start" parent="L_0-1" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P18顶板厚度" /> <Constraint type="None" referenceP1="" referenceP2="" /> </Point> <Point name="P_19" x="4.8002399280239878" y="-0.39606479256167881" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="4.8071998800239921" lockTo="start" parent="L_0-1" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P19顶板厚度" /> <Constraint type="None" referenceP1="" referenceP2="" /> </Point> <Point name="P_20" x="5.9999999999999964" y="-0.82005999400119878" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="6.0151982805038333" lockTo="start" parent="L_0-1" referenceP1="L_0-0" referenceP2="L_0-0" /> <Constraint type="Horizontal" value="-0.7" parent="P_2" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P20右腹板宽度" /> </Point> <Point name="P_21" x="5.9999999999999956" y="-1.8999999999999997" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_2" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P21底板厚度" /> <Constraint type="Horizontal" parent="P_20" referenceP1="Working Point" referenceP2="Working Point" /> </Point> <Point name="P_22" x="5.6999999999999957" y="-2.1999999999999997" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_2" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P22底板厚度" /> <Constraint type="None" referenceP1="" referenceP2="" /> </Point> <Point name="P_23" x="0.54999999999999971" y="-2.2" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P23底板厚度内" /> <Constraint type="None" referenceP1="" referenceP2="" /> </Point> <Point name="P_24" x="0.24999999999999975" y="-1.9000000000000001" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P24底板厚度" /> <Constraint type="Horizontal" value="0.45" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P24中腹板宽度" /> </Point> <Point name="P_25" x="0.24999999999999989" y="-0.70505999400119979" isSuperelevationPI="false" doNotApplyRotation="false"> <Constraint type="Offset" value="0.7" secondaryValue="0.26404839548084069" lockTo="start" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" /> <Constraint type="Horizontal" value="0.45" parent="P_8" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P25中腹板宽度" /> </Point> </Points> <Lines> <Line name="L_0-0"> <PointRef name="P_1" /> <PointRef name="P_8" /> </Line> <Line name="L_0-1"> <PointRef name="P_8" /> <PointRef name="P_6" /> </Line> <Line name="L_0-2"> <PointRef name="P_6" /> <PointRef name="P_0" /> </Line> <Line name="L_0-3"> <PointRef name="P_0" /> <PointRef name="P_5" /> </Line> <Line name="L_0-4"> <PointRef name="P_5" /> <PointRef name="P_2" /> </Line> <Line name="L_0-5"> <PointRef name="P_2" /> <PointRef name="P_3" /> </Line> <Line name="L_0-6"> <PointRef name="P_3" /> <PointRef name="P_4" /> </Line> <Line name="L_0-7"> <PointRef name="P_4" /> <PointRef name="P_7" /> </Line> <Line name="L_0-8"> <PointRef name="P_7" /> <PointRef name="P_9" /> </Line> <Line name="L_0-9"> <PointRef name="P_9" /> <PointRef name="P_1" /> </Line> <Line name="L_1-0"> <PointRef name="P_10" /> <PointRef name="P_11" /> </Line> <Line name="L_1-1"> <PointRef name="P_11" /> <PointRef name="P_12" /> </Line> <Line name="L_1-2"> <PointRef name="P_12" /> <PointRef name="P_13" /> </Line> <Line name="L_1-3"> <PointRef name="P_13" /> <PointRef name="P_14" /> </Line> <Line name="L_1-4"> <PointRef name="P_14" /> <PointRef name="P_15" /> </Line> <Line name="L_1-5"> <PointRef name="P_15" /> <PointRef name="P_16" /> </Line> <Line name="L_1-6"> <PointRef name="P_16" /> <PointRef name="P_17" /> </Line> <Line name="L_1-7"> <PointRef name="P_17" /> <PointRef name="P_10" /> </Line> <Line name="L_2-0"> <PointRef name="P_18" /> <PointRef name="P_19" /> </Line> <Line name="L_2-1"> <PointRef name="P_19" /> <PointRef name="P_20" /> </Line> <Line name="L_2-2"> <PointRef name="P_20" /> <PointRef name="P_21" /> </Line> <Line name="L_2-3"> <PointRef name="P_21" /> <PointRef name="P_22" /> </Line> <Line name="L_2-4"> <PointRef name="P_22" /> <PointRef name="P_23" /> </Line> <Line name="L_2-5"> <PointRef name="P_23" /> <PointRef name="P_24" /> </Line> <Line name="L_2-6"> <PointRef name="P_24" /> <PointRef name="P_25" /> </Line> <Line name="L_2-7"> <PointRef name="P_25" /> <PointRef name="P_18" /> </Line> </Lines> <Arcs /> <Ellipses /> <Components> <Component name="COMP_0"> <LineRef name="L_0-0" /> <LineRef name="L_0-1" /> <LineRef name="L_0-2" /> <LineRef name="L_0-3" /> <LineRef name="L_0-4" /> <LineRef name="L_0-5" /> <LineRef name="L_0-6" /> <LineRef name="L_0-7" /> <LineRef name="L_0-8" /> <LineRef name="L_0-9" /> </Component> <Component name="COMP_1"> <LineRef name="L_1-0" /> <LineRef name="L_1-1" /> <LineRef name="L_1-2" /> <LineRef name="L_1-3" /> <LineRef name="L_1-4" /> <LineRef name="L_1-5" /> <LineRef name="L_1-6" /> <LineRef name="L_1-7" /> </Component> <Component name="COMP_2"> <LineRef name="L_2-0" /> <LineRef name="L_2-1" /> <LineRef name="L_2-2" /> <LineRef name="L_2-3" /> <LineRef name="L_2-4" /> <LineRef name="L_2-5" /> <LineRef name="L_2-6" /> <LineRef name="L_2-7" /> </Component> </Components> <KeyPoints> <TopLeft>P_1</TopLeft> <TopRight>P_6</TopRight> <BottomLeft>P_9</BottomLeft> <BottomRight>P_0</BottomRight> </KeyPoints> <WetJointKeyPoints /> </Template> </SubCategory> </SubCategory> </SubCategory> </Category> </PowerBridgeTemplate>
老师你好,又测试了几次,发现斜交的桥梁布跨线距离小了就出现错误,调大布跨线为30米以上就可以生成。老师这个问题是什么原因。
老师,你好把缓和类型选择成圆起点,就可以了。
老师,你好把缓和类型选择成圆起点,不提示出错,但模型没有发生变化。
好的,我们这边看下,您OBM是什么版本呢,还有把路线文件也同时发一下
老师,你好OBM版本是UPDATE8.0,文件在提问里有。谢谢
IfcAlignmentExport.ifc
老师,你好。还有问题需要请教,斜交变截面箱梁,变截面起点和终点的截面发生了变形,正交的没有问题,把布跨线调成斜交,起点和终点的截面下部就发生了扭曲。
您好,导入您的模板文件是空的,如果模板测试没问题的话,此类问题应该是以下两种情况造成的,一个一个检查下1、模板约束不成功2、是不是创建模型以后,重新添加的翼板厚度参数,如果是的话,需要重新创建模型,再进行约束(此原因比较常见)
Answer Verified By: liwei 张
