箱梁建模模板问题
练习建了一个箱梁的变截面模板,翼板端部厚度变截面出错,变量调整同一数值可以生成。请教老师帮忙看看,不胜感激。
<?xml version="1.0" encoding="utf-8"?>
<PowerBridgeTemplate xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Version="1.0" xmlns="http://www.example.org/NewXMLSchema">
  <Category name="New Category" />
  <Category name="Decks">
    <SubCategory name="Standard Templates">
      <SubCategory name="我的模板">
        <SubCategory name="贾鲁河桥练习">
          <Template name="4号墩3-3(右幅" description="" guid="8d9a1ac7-076b-4fcf-94a9-f5879dbbff59" lastRevisedDate="2020-07-01" lastRevisedBy="zlwwxc168" versionMajor="2" versionMinor="85">
            <Points>
              <Point name="P_1" x="-9.7500000000000071" y="0.19499999999996417" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.19499999999996417" referenceP1="Working Point" referenceP2="Working Point" />
                <Constraint type="Horizontal" value="-9.7500000000000071" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_8" x="-2.9103830456733705E-15" y="-1.6155871338926323E-31" isSuperelevationPI="false">
                <Constraint type="None" />
              </Point>
              <Point name="P_6" x="9.7500000000000018" y="-0.19499999999999881" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="-0.19499999999999881" referenceP1="Working Point" referenceP2="Working Point" />
                <Constraint type="Horizontal" value="9.75" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_0" x="9.7500000000000018" y="-0.37499999999999883" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="-0.18000000000000002" secondaryValue="0.0035992802159280014" lockTo="start" parent="P_6" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P0翼板厚度" />
                <Constraint type="None" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="" />
              </Point>
              <Point name="P_5" x="6.4999999999999956" y="-0.830139986002799" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="-0.4551399860028002" secondaryValue="6.5152998700259914" lockTo="start" parent="P_0" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P5翼板厚度" />
                <Constraint type="Horizontal" value="6.4999999999999956" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_2" x="6.4999999999999956" y="-2.4999999999999996" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" />
                <Constraint type="Horizontal" value="6.4999999999999956" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_3" x="0" y="-2.5" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="-2.5" referenceP1="Working Point" referenceP2="Working Point" />
                <Constraint type="Horizontal" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_4" x="-6.5" y="-2.5" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Horizontal" value="-6.5" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_7" x="-6.5000000000000044" y="-0.57013998600282279" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="-0.58513998600278694" secondaryValue="-6.4872998700259963" lockTo="end" parent="P_9" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P7翼板厚度" />
                <Constraint type="Horizontal" value="-6.5000000000000044" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_9" x="-9.7500000000000071" y="0.014999999999964167" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="-0.18" secondaryValue="0.0035992802159273639" lockTo="start" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P9翼板厚度" />
                <Constraint type="Horizontal" parent="P_1" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="" />
              </Point>
              <Point name="P_10" x="-0.25" y="-0.69505999400120055" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="9.515898210517836" lockTo="start" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P10顶板厚度" />
                <Constraint type="Horizontal" value="-0.45" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P10中腹板宽度" />
              </Point>
              <Point name="P_11" x="-0.25" y="-1.9000000000000001" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P11底板厚度" />
                <Constraint type="Horizontal" value="-0.45" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P11中腹板宽度" />
              </Point>
              <Point name="P_12" x="-0.55" y="-2.2" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P12底板厚度" />
                <Constraint type="None" referenceP1="" referenceP2="" />
              </Point>
              <Point name="P_13" x="-5.7" y="-2.2" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P13底板厚度" />
                <Constraint type="Horizontal" value="0.79999999999999982" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_14" x="-6.0000000000000009" y="-1.9000000000000001" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P14底板厚度" />
                <Constraint type="Horizontal" value="0.7" parent="P_4" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P14左腹板宽度" />
              </Point>
              <Point name="P_15" x="-6.0000000000000053" y="-0.580059994001221" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="3.7647483254948355" lockTo="start" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" />
                <Constraint type="Horizontal" value="-4.4408920985006262E-15" parent="P_14" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="" />
              </Point>
              <Point name="P_16" x="-4.8002399280239985" y="-0.20405519544073683" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="-4.795199880023997" lockTo="end" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P16顶板厚度" />
              </Point>
              <Point name="P_17" x="-1.4497600719760084" y="-0.2710647925616847" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="-1.4440499950009968" lockTo="end" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P17顶板厚度" />
              </Point>
              <Point name="P_18" x="1.4497600719760082" y="-0.32905519544071971" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="1.4560499950010022" lockTo="start" parent="L_0-1" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P18顶板厚度" />
              </Point>
              <Point name="P_19" x="4.8002399280239878" y="-0.39606479256167881" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="4.8071998800239921" lockTo="start" parent="L_0-1" referenceP1="L_0-0" referenceP2="L_0-0" parametricLabel="P19顶板厚度" />
              </Point>
              <Point name="P_20" x="5.9999999999999964" y="-0.82005999400119878" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="6.0151982805038333" lockTo="start" parent="L_0-1" referenceP1="L_0-0" referenceP2="L_0-0" />
                <Constraint type="Horizontal" value="-0.7" parent="P_2" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P20右腹板宽度" />
              </Point>
              <Point name="P_21" x="5.9999999999999956" y="-1.8999999999999997" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_2" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P21底板厚度" />
                <Constraint type="Horizontal" parent="P_20" referenceP1="Working Point" referenceP2="Working Point" />
              </Point>
              <Point name="P_22" x="5.6999999999999957" y="-2.1999999999999997" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_2" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P22底板厚度" />
              </Point>
              <Point name="P_23" x="0.54999999999999971" y="-2.2" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P23底板厚度内" />
              </Point>
              <Point name="P_24" x="0.24999999999999975" y="-1.9000000000000001" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Vertical" value="0.7" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P24底板厚度" />
                <Constraint type="Horizontal" value="0.45" parent="P_3" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P24中腹板宽度" />
              </Point>
              <Point name="P_25" x="0.24999999999999989" y="-0.70505999400119979" isSuperelevationPI="false" doNotApplyRotation="false">
                <Constraint type="Offset" value="0.7" secondaryValue="0.26404839548084069" lockTo="start" parent="L_0-0" referenceP1="L_0-0" referenceP2="L_0-0" />
                <Constraint type="Horizontal" value="0.45" parent="P_8" referenceP1="Working Point" referenceP2="Working Point" parametricLabel="P25中腹板宽度" />
              </Point>
            </Points>
            <Lines>
              <Line name="L_0-0">
                <PointRef name="P_1" />
                <PointRef name="P_8" />
              </Line>
              <Line name="L_0-1">
                <PointRef name="P_6" />
              </Line>
              <Line name="L_0-2">
                <PointRef name="P_0" />
              </Line>
              <Line name="L_0-3">
                <PointRef name="P_5" />
              </Line>
              <Line name="L_0-4">
                <PointRef name="P_2" />
              </Line>
              <Line name="L_0-5">
                <PointRef name="P_3" />
              </Line>
              <Line name="L_0-6">
                <PointRef name="P_4" />
              </Line>
              <Line name="L_0-7">
                <PointRef name="P_7" />
              </Line>
              <Line name="L_0-8">
                <PointRef name="P_9" />
              </Line>
              <Line name="L_0-9">
              </Line>
              <Line name="L_1-0">
                <PointRef name="P_10" />
                <PointRef name="P_11" />
              </Line>
              <Line name="L_1-1">
                <PointRef name="P_12" />
              </Line>
              <Line name="L_1-2">
                <PointRef name="P_13" />
              </Line>
              <Line name="L_1-3">
                <PointRef name="P_14" />
              </Line>
              <Line name="L_1-4">
                <PointRef name="P_15" />
              </Line>
              <Line name="L_1-5">
                <PointRef name="P_16" />
              </Line>
              <Line name="L_1-6">
                <PointRef name="P_17" />
              </Line>
              <Line name="L_1-7">
              </Line>
              <Line name="L_2-0">
                <PointRef name="P_18" />
                <PointRef name="P_19" />
              </Line>
              <Line name="L_2-1">
                <PointRef name="P_20" />
              </Line>
              <Line name="L_2-2">
                <PointRef name="P_21" />
              </Line>
              <Line name="L_2-3">
                <PointRef name="P_22" />
              </Line>
              <Line name="L_2-4">
                <PointRef name="P_23" />
              </Line>
              <Line name="L_2-5">
                <PointRef name="P_24" />
              </Line>
              <Line name="L_2-6">
                <PointRef name="P_25" />
              </Line>
              <Line name="L_2-7">
              </Line>
            </Lines>
            <Arcs />
            <Ellipses />
            <Components>
              <Component name="COMP_0">
                <LineRef name="L_0-0" />
                <LineRef name="L_0-1" />
                <LineRef name="L_0-2" />
                <LineRef name="L_0-3" />
                <LineRef name="L_0-4" />
                <LineRef name="L_0-5" />
                <LineRef name="L_0-6" />
                <LineRef name="L_0-7" />
                <LineRef name="L_0-8" />
                <LineRef name="L_0-9" />
              </Component>
              <Component name="COMP_1">
                <LineRef name="L_1-0" />
                <LineRef name="L_1-1" />
                <LineRef name="L_1-2" />
                <LineRef name="L_1-3" />
                <LineRef name="L_1-4" />
                <LineRef name="L_1-5" />
                <LineRef name="L_1-6" />
                <LineRef name="L_1-7" />
              </Component>
              <Component name="COMP_2">
                <LineRef name="L_2-0" />
                <LineRef name="L_2-1" />
                <LineRef name="L_2-2" />
                <LineRef name="L_2-3" />
                <LineRef name="L_2-4" />
                <LineRef name="L_2-5" />
                <LineRef name="L_2-6" />
                <LineRef name="L_2-7" />
              </Component>
            </Components>
            <KeyPoints>
              <TopLeft>P_1</TopLeft>
              <TopRight>P_6</TopRight>
              <BottomLeft>P_9</BottomLeft>
              <BottomRight>P_0</BottomRight>
            </KeyPoints>
            <WetJointKeyPoints />
          </Template>
        </SubCategory>
      </SubCategory>
    </SubCategory>
  </Category>
</PowerBridgeTemplate>
贾鲁河桥练习.dgn
Parents Reply Children
