OPPA CE6 10.06.00.23中的Catalog Editor 无法导入excel文件
OpenPlant Specification Generator 10.06.00.23版本只要选择Import from Excel,选中了excel文件继续就会报以下的错误。
这个问题在OPPA CE5的版本中不存在。已经在多台电脑上尝试,问题依旧。
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Resources.MissingManifestResourceException: Could not find any resources appropriate for the specified culture or the neutral culture. Make sure "Bentley.Plant.SpecGen.CE.UI.FieldsMappingForm.resources" was correctly embedded or linked into assembly "Bentley.Catalog.SpecGen" at compile time, or that all the satellite assemblies required are loadable and fully signed.
at System.Resources.ManifestBasedResourceGroveler.HandleResourceStreamMissing(String fileName)
at System.Resources.ManifestBasedResourceGroveler.GrovelForResourceSet(CultureInfo culture, Dictionary`2 localResourceSets, Boolean tryParents, Boolean createIfNotExists, StackCrawlMark& stackMark)
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo requestedCulture, Boolean createIfNotExists, Boolean tryParents, StackCrawlMark& stackMark)
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
at System.Resources.ResourceManager.GetObject(String name, CultureInfo culture, Boolean wrapUnmanagedMemStream)
at Bentley.Plant.SpecGen.CE.UI.FieldsMappingForm.InitializeComponent()
at Bentley.Plant.SpecGen.CE.UI.FieldsMappingForm..ctor(CatalogModel model, List`1 selectedSheets, CatalogEditController catEditController, String excelFileName)
at Bentley.Plant.SpecGen.CE.UI.EditDataBaseSchemaForm.ImportExceltoolStripBtn_Click(Object sender, EventArgs e)
at Bentley.Plant.SpecGen.CE.CatalogEditor.ImportFromExcelToolStripMenuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4042.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Version: 10.6.0.23
Win32 Version: 10.06.00.23
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Catalog.SpecGen.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Telerik.WinControls.UI
Assembly Version: 2017.2.613.40
Win32 Version: 2017.2.613.40
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/Telerik/Telerik.WinControls.UI.DLL
Telerik.WinControls
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/Telerik/Telerik.WinControls.DLL
Bentley.Plant.Core.UI
Assembly Version: 1.0.0.0
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Plant.Core.UI.DLL
Bentley.Plant.ProductUtilities
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Plant.ProductUtilities.DLL
Bentley.ECObjects3
Win32 Version: 09.18.02.46
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/ECFramework/Bentley.ECObjects3.DLL
Bentley.Plant.Core.ConfigurationManager
Assembly Version: 0.0.0.0
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Plant.Core.ConfigurationManager.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
TelerikCommon
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/Telerik/TelerikCommon.DLL
Microsoft.GeneratedCode
Telerik.WinControls.Themes.VisualStudio2012Light
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/Telerik/Telerik.WinControls.Themes.VisualStudio2012Light.DLL
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
mscorlib.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_zh-Hans_b77a5c561934e089/mscorlib.resources.dll
Bentley.Plant.Core.DgnwsManager
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Plant.Core.DgnwsManager.DLL
Bentley.Plant.Core.Utilities
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Plant.Core.Utilities.DLL
Bentley.Platform
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Platform.DLL
Bentley.GeometryNET.Common
Win32 Version: 02.18.02.47
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.GeometryNET.Common.DLL
Bentley.GeometryNET.Structs
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.GeometryNET.Structs.DLL
Bentley.Exceptions
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Exceptions.DLL
Bentley.logging-2.0
Assembly Version: 2.0.0.0
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/ECFramework/Bentley.logging-2.0.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Telerik.WinControls.GridView
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/Telerik/Telerik.WinControls.GridView.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Bentley.Data.XDb.Provider
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Data.XDb.Provider.DLL
Bentley.General.1.0
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.General.1.0.DLL
System.Runtime.Serialization
Win32 Version: 4.8.3825.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Bentley.logging.log4net-2.0
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Assemblies/ECFramework/Bentley.logging.log4net-2.0.DLL
System.Data.SQLite
Assembly Version: 1.0.104.0
Win32 Version: 1.0.104.0
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
SMDiagnostics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Internals
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Bentley.Data.XDb.Wrapper
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Data.XDb.Wrapper.DLL
Bentley.Plant.ProjectResources
Assembly Version: 8.11.0.0
CodeBase: file:///D:/Program%20Files/Bentley/OpenPlant%20CONNECT%20Edition/ProjectAdministrator/Bentley.Plant.ProjectResources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
