using Bentley.Building.Mechanical.ComponentLibrary.Common.DrawGeometry;using Bentley.Building.Mechanical.ComponentLibrary.Equipment;using Bentley.Building.Mechanical.Components;using System.Collections.Generic;
namespace Wisdri.Building.Mechanical.ComponentLibrary.Equipment{ class EQUIPTEST : BaseEquipment { protected double Length; protected double Height; protected double Thickness; public EQUIPTEST() { _app = new BMApplication(); _fluidPorts = new List<Port>(); _placementPoints = new List<PlacementPoint>(); }
public override List<ElementHolder> Create3DElements() { List<ElementHolder> elements = new List<ElementHolder>(); Plate plate = new Plate(Length, Height, Thickness); elements.AddRange(plate.Create3DElements()); BaseGeometry.SetSymbologyForElementTypes(elements, 0, -1, BMSymbolBasisType.EquipmentSymbology, _bmECObject); return elements; }
public override void Setup() { Length = _bmECObject.Instance["LEN"].DoubleValue; Height = _bmECObject.Instance["HEI"].DoubleValue; Thickness = _bmECObject.Instance["THK"].DoubleValue; } }
类设置与设备定义示例程序如上所示,但插入设备时,无法调用元件库中数据,而是直接以默认值0.0来绘制模型,可在绘制界面修改尺寸,但无法调用定义好的等级库
您好~
看到您提到的问题应该是涉及到二次开发的,建议您去二次开发模块提问
