您好,可以参考一下的帖子进行处理第一个报警:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/29742/structural-modeling-components-initialization-error-in-openplant-modeler
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/47534/to-resolve-smc-issue-through-regional-setting-in-openplant-modeler-connect-edition
对于第二个报警,可以能该文件损坏,可以重新安装进行修复。也有可能是电脑安装了防火墙,加密等软件造成,需要一一排查。
