在道岔区域附近,由于两个铁路线间距还不大,所以在两条铁路线上创建的轨枕会有交叉,如何设置此处的轨枕实现像道岔区区域轨枕那样一个轨枕可以跨两条铁路线?
刘工您好,看您的截图,小桩号方向的应该是利用道岔布置后,再创建的轨枕。您可以尝试自定义道岔,定义道岔的各段长度,直到满足要求,参考链接:communities.bentley.com/.../openrail-designer(xml文件参考附件)。由于OpenRail中创建轨枕没有道岔的情况,路线两侧是等值的,如果想要放置特殊的,也可以在MS中建模后放进来。
<?xml version="1.0" encoding="iso-8859-1"?> <TurnoutsFile><Turnouts><Units linear="meters" angular="radians"/><Turnout name="#18 60 kg/m" description="#18 60 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="60.000000" length0To2="37.256000" length0To3="37.256000" ratioAt0="18.000000" ratioAt1="0.000000"><Elements><Element length="0.539700" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="44.397300" entranceRadius="800.000000" exitRadius="800.000000"/><Element length="15.051700" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#18 50 kg/m" description="#18 50 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="54.000000" length0To2="31.255000" length0To3="31.255000" ratioAt0="18.000000" ratioAt1="0.000000"><Elements><Element length="0.539899" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="44.398803" entranceRadius="800.000000" exitRadius="800.000000"/><Element length="9.049899" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 75 kg/m" description="#12 75 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="36.600000" length0To2="21.208000" length0To3="21.208000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="0.833897" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.649897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (4228)" description="#12 60 kg/m (4228)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.800000" length0To2="21.208000" length0To3="21.208000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.033898" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.649897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (001,002)" description="#12 60 kg/m (001,002)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="43.200000" length0To2="26.608000" length0To3="26.608000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.033898" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="12.049898" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (003, 4249)" description="#12 60 kg/m (003, 4249)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.800000" length0To2="21.208000" length0To3="21.208000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.033898" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.649897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (4190)" description="#12 60 kg/m (4190)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.907000" length0To2="21.054000" length0To3="21.054000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.294897" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.495897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 50 kg/m (4147, 4198)" description="#12 50 kg/m (4147, 4198)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.907000" length0To2="21.054000" length0To3="21.054000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.294897" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.495897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 50 kg/m (4144)" description="#12 50 kg/m (4144)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="36.815000" length0To2="19.962000" length0To3="19.962000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="3.126789" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="27.436606" entranceRadius="330.000000" exitRadius="330.000000"/><Element length="6.235789" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 43 kg/m (TB399-1975)" description="#12 43 kg/m (TB399-1975)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="36.815000" length0To2="19.962000" length0To3="19.962000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="3.126789" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="27.436606" entranceRadius="330.000000" exitRadius="330.000000"/><Element length="6.235789" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#9 60 kg/m" description="#9 60 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="29.569000" length0To2="15.730000" length0To3="15.730000" ratioAt0="9.000000" ratioAt1="0.000000"><Elements><Element length="3.869675" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.918300" entranceRadius="180.000000" exitRadius="180.000000"/><Element length="5.760675" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#9 50/43 kg/m" description="#9 50/43 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="28.848000" length0To2="15.009000" length0To3="15.009000" ratioAt0="9.000000" ratioAt1="0.000000"><Elements><Element length="3.869675" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.918300" entranceRadius="180.000000" exitRadius="180.000000"/><Element length="5.039675" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#7 50/43 kg/m" description="#7 50/43 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="22.967000" length0To2="12.070000" length0To3="12.070000" ratioAt0="7.000000" ratioAt1="0.000000"><Elements><Element length="0.236830" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="21.284560" entranceRadius="150.000000" exitRadius="150.000000"/><Element length="1.409830" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#6 50/42 kg/m" description="#6 50/42 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="18.485000" length0To2="9.103878" length0To3="9.103878" ratioAt0="6.000000" ratioAt1="0.000000"><Elements><Element length="0.277244" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="18.166355" entranceRadius="110.000000" exitRadius="110.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#9 50/43 kg/m (5812, 5810)" description="#9 50/43 kg/m (5812, 5810)" bendingMethod="Swiss" type="double"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="28.847999" length0To2="15.009000" length0To3="15.009000" ratioAt0="18.055140" ratioAt1="0.000000"><Elements><Element length="4.015532" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.641923" entranceRadius="355.000000" exitRadius="355.000000"/><Element length="5.185532" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch><Branch theoreticalToActual="0.000000" lengthAlongMainline="28.847999" length0To2="15.009000" length0To3="15.009000" ratioAt0="18.055140" ratioAt1="0.000000"><Elements><Element length="4.015532" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.641923" entranceRadius="355.000000" exitRadius="355.000000"/><Element length="5.185532" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout></Turnouts></TurnoutsFile>
参考链接可不可以再发一遍,显示不全,谢谢
