求一个Openrai 国标道岔库,turnouts-GB
求一个Openrai 国标道岔库,turnouts-GB.xml
谢谢!
  • 您好,收到您的问题,核实后尽快回复您。
  • 抱歉回复迟了。
    道岔库:
    5706.turnouts-GB.xml
    <?xml version="1.0" encoding="iso-8859-1"?>
    <TurnoutsFile><Turnouts><Units linear="meters" angular="radians"/><Turnout name="#18 60 kg/m" description="#18 60 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="60.000000" length0To2="37.256000" length0To3="37.256000" ratioAt0="18.000000" ratioAt1="0.000000"><Elements><Element length="0.539700" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="44.397300" entranceRadius="800.000000" exitRadius="800.000000"/><Element length="15.051700" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#18 50 kg/m" description="#18 50 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="54.000000" length0To2="31.255000" length0To3="31.255000" ratioAt0="18.000000" ratioAt1="0.000000"><Elements><Element length="0.539899" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="44.398803" entranceRadius="800.000000" exitRadius="800.000000"/><Element length="9.049899" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 75 kg/m" description="#12 75 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="36.600000" length0To2="21.208000" length0To3="21.208000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="0.833897" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.649897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (4228)" description="#12 60 kg/m (4228)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.800000" length0To2="21.208000" length0To3="21.208000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.033898" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.649897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (001,002)" description="#12 60 kg/m (001,002)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="43.200000" length0To2="26.608000" length0To3="26.608000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.033898" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="12.049898" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (003, 4249)" description="#12 60 kg/m (003, 4249)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.800000" length0To2="21.208000" length0To3="21.208000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.033898" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.649897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 60 kg/m (4190)" description="#12 60 kg/m (4190)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.907000" length0To2="21.054000" length0To3="21.054000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.294897" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.495897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 50 kg/m (4147, 4198)" description="#12 50 kg/m (4147, 4198)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="37.907000" length0To2="21.054000" length0To3="21.054000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="2.294897" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="29.099431" entranceRadius="350.000000" exitRadius="350.000000"/><Element length="6.495897" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 50 kg/m (4144)" description="#12 50 kg/m (4144)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="36.815000" length0To2="19.962000" length0To3="19.962000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="3.126789" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="27.436606" entranceRadius="330.000000" exitRadius="330.000000"/><Element length="6.235789" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#12 43 kg/m (TB399-1975)" description="#12 43 kg/m (TB399-1975)" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="36.815000" length0To2="19.962000" length0To3="19.962000" ratioAt0="12.000000" ratioAt1="0.000000"><Elements><Element length="3.126789" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="27.436606" entranceRadius="330.000000" exitRadius="330.000000"/><Element length="6.235789" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#9 60 kg/m" description="#9 60 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="29.569000" length0To2="15.730000" length0To3="15.730000" ratioAt0="9.000000" ratioAt1="0.000000"><Elements><Element length="3.869675" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.918300" entranceRadius="180.000000" exitRadius="180.000000"/><Element length="5.760675" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#9 50/43 kg/m" description="#9 50/43 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="28.848000" length0To2="15.009000" length0To3="15.009000" ratioAt0="9.000000" ratioAt1="0.000000"><Elements><Element length="3.869675" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.918300" entranceRadius="180.000000" exitRadius="180.000000"/><Element length="5.039675" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#7 50/43 kg/m" description="#7 50/43 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="22.967000" length0To2="12.070000" length0To3="12.070000" ratioAt0="7.000000" ratioAt1="0.000000"><Elements><Element length="0.236830" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="21.284560" entranceRadius="150.000000" exitRadius="150.000000"/><Element length="1.409830" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#6 50/42 kg/m" description="#6 50/42 kg/m" bendingMethod="Swiss" type="single"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="18.485000" length0To2="9.103878" length0To3="9.103878" ratioAt0="6.000000" ratioAt1="0.000000"><Elements><Element length="0.277244" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="18.166355" entranceRadius="110.000000" exitRadius="110.000000"/></Elements></Branch></Branches></Turnout><Turnout name="#9 50/43 kg/m (5812, 5810)" description="#9 50/43 kg/m (5812, 5810)" bendingMethod="Swiss" type="double"><Miscellaneous/><Branches lengthAlong="centerline"><Branch theoreticalToActual="0.000000" lengthAlongMainline="28.847999" length0To2="15.009000" length0To3="15.009000" ratioAt0="18.055140" ratioAt1="0.000000"><Elements><Element length="4.015532" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.641923" entranceRadius="355.000000" exitRadius="355.000000"/><Element length="5.185532" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch><Branch theoreticalToActual="0.000000" lengthAlongMainline="28.847999" length0To2="15.009000" length0To3="15.009000" ratioAt0="18.055140" ratioAt1="0.000000"><Elements><Element length="4.015532" entranceRadius="0.000000" exitRadius="0.000000"/><Element length="19.641923" entranceRadius="355.000000" exitRadius="355.000000"/><Element length="5.185532" entranceRadius="0.000000" exitRadius="0.000000"/></Elements></Branch></Branches></Turnout></Turnouts></TurnoutsFile>
    更多内容请看下面的文章:
