open roads concepstation 安装出现这个问题呢0X80070570
出现的安装日志如下所示呢,请老师帮忙解决呢!!!!有出现一个新的安装问题呢
[14C8:2BF0][2017-03-21T17:30:29]i001: Burn v3.10.2.2516, Windows v10.0 (Build 10240: Service Pack 0), path: C:\Users\Admin\AppData\Local\Temp\{5E0BC8A1-BEA0-4D6A-B417-D8EC2A06851F}\.cr\cnst10000445en.exe
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\OpenRoads ConceptStation CONNECT Edition'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BundleLog_BentleyConnectClient' to value '[TempFolder]BentleyConnectClient.log'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BundleLog_vc140' to value '[TempFolder]VC140redist.log'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]ConceptStation\ActivationWizard.exe'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'ConceptStationPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'FMEPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BeBundleCulture' to value ''
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BeBuildType' to value 'Release'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BeBundleShortName' to value 'OpenRoads ConceptStation CONNECT Edition'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[14C8:2BF0][2017-03-21T17:30:29]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[14C8:2BF0][2017-03-21T17:30:29]i009: Command Line: '-burn.clean.room=E:\Bentley软件\cnst10000445en.exe'
[14C8:2BF0][2017-03-21T17:30:29]i000: Setting string variable 'WixBundleOriginalSource' to value 'E:\Bentley软件\cnst10000445en.exe'
[14C8:2BF0][2017-03-21T17:30:29]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'E:\Bentley软件\'
[14C8:2BF0][2017-03-21T17:30:29]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Admin\AppData\Local\Temp\OpenRoads ConceptStation CONNECT Edition_20170321173029.log'
[14C8:2BF0][2017-03-21T17:30:29]i000: Setting string variable 'WixBundleName' to value 'OpenRoads ConceptStation CONNECT Edition'
[14C8:2BF0][2017-03-21T17:30:29]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[14C8:2BF0][2017-03-21T17:30:29]i000: Loading managed bootstrapper application.
[14C8:2BF0][2017-03-21T17:30:29]i000: Creating BA thread to run asynchronously.
[14C8:5EB4][2017-03-21T17:30:29]i000: BentleyBundle Version 10.00.00.09
[14C8:5EB4][2017-03-21T17:30:29]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\Admin\AppData\Local\Temp\{AD7D753A-E8B5-475D-8F17-BD1EC485049D}\.ba'
[14C8:5EB4][2017-03-21T17:30:29]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\Admin\AppData\Local\Temp\{5E0BC8A1-BEA0-4D6A-B417-D8EC2A06851F}\.cr'
[14C8:5EB4][2017-03-21T17:30:29]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\OpenRoads ConceptStation CONNECT Edition\'
[14C8:5EB4][2017-03-21T17:30:29]e000: Using Layout File : C:\Users\Admin\AppData\Local\Temp\{AD7D753A-E8B5-475D-8F17-BD1EC485049D}\.ba\Setup.lyt
[14C8:5EB4][2017-03-21T17:30:29]i000: ConceptStationPackageStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: ConceptStationPackageAnalyzeFeatureConditions: LaunchAction=Unknown
[14C8:5EB4][2017-03-21T17:30:29]i000: ConceptStationPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: ConceptStationPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: FMEPackageStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: FMEPackageAnalyzeFeatureConditions: LaunchAction=Unknown
[14C8:5EB4][2017-03-21T17:30:29]i000: FMEPackage RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: FMEPackage RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: NetFx451WebStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: NetFx451WebAnalyzeFeatureConditions: LaunchAction=Unknown
[14C8:5EB4][2017-03-21T17:30:29]i000: NetFx451Web RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: NetFx451Web RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: VC140redistStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: VC140redistAnalyzeFeatureConditions: LaunchAction=Unknown
[14C8:5EB4][2017-03-21T17:30:29]i000: VC140redist RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: VC140redist RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: DirectXStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: DirectXAnalyzeFeatureConditions: LaunchAction=Unknown
[14C8:5EB4][2017-03-21T17:30:29]i000: DirectX RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: DirectX RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: BentleyConnectClientStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Unknown
[14C8:5EB4][2017-03-21T17:30:29]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:5EB4][2017-03-21T17:30:29]i000: BOOTSTRAPPER Register DetectComplete
[14C8:5EB4][2017-03-21T17:30:29]i000: Display is set to Full
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeDialogInstallUserControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]i000: Register callbak=ProxySettingsPage
[14C8:5EB4][2017-03-21T17:30:30]i000: Display Page=ProxySettingsPage
[14C8:5EB4][2017-03-21T17:30:30]i000: Cannot Display Page=ProxySettingsPage
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[14C8:5EB4][2017-03-21T17:30:30]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[14C8:2BF0][2017-03-21T17:30:30]i100: Detect begin, 6 packages
[14C8:2BF0][2017-03-21T17:30:30]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent
[14C8:2BF0][2017-03-21T17:30:30]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
[14C8:2BF0][2017-03-21T17:30:30]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
[14C8:2BF0][2017-03-21T17:30:30]i000: DetectBegin: Installed State of Package DetectedAbsent
[14C8:2BF0][2017-03-21T17:30:30]i000: Setting string variable 'NETFRAMEWORK45' to value '393295'
[14C8:2BF0][2017-03-21T17:30:30]i000: Registry key not found. Key = 'SOFTWARE\Bentley\ConceptStation\{BFEDC9D7-03A2-473C-ABAB-13D2A9316FE7}'
[14C8:2BF0][2017-03-21T17:30:30]i000: Setting numeric variable 'PreviousDesktopShortcut' to value 2
[14C8:2BF0][2017-03-21T17:30:30]i052: Condition 'PreviousInstallDirectory' evaluates to false.
[14C8:2BF0][2017-03-21T17:30:30]i000: File search: wfsA75C5C2F42268E9D16DCEE26AFE19609, did not find path: C:\windows\system32\d3dx10_43.dll
[14C8:2BF0][2017-03-21T17:30:30]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.07.019'
[14C8:2BF0][2017-03-21T17:30:30]i000: Setting string variable 'VC14_vcredist_x64_Installed' to value '1'
[14C8:2BF0][2017-03-21T17:30:30]i000: Setting string variable 'VC140InstalledVersion' to value '14.0.23026'
[14C8:2BF0][2017-03-21T17:30:30]i052: Condition 'NETFRAMEWORK45 >= 378675' evaluates to true.
[14C8:2BF0][2017-03-21T17:30:30]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.6.34' evaluates to true.
[14C8:2BF0][2017-03-21T17:30:30]i052: Condition 'VC140InstalledVersion >= v14.0.23026.00' evaluates to true.
[14C8:2BF0][2017-03-21T17:30:30]i052: Condition 'DX10InstalledVersion >= v9.29.952.3111' evaluates to false.
[14C8:2BF0][2017-03-21T17:30:30]i101: Detected package: NetFx451Web, state: Present, cached: None
[14C8:2BF0][2017-03-21T17:30:30]i101: Detected package: BentleyConnectClient, state: Present, cached: None
[14C8:2BF0][2017-03-21T17:30:30]i101: Detected package: VC140redist, state: Present, cached: None
[14C8:2BF0][2017-03-21T17:30:30]i101: Detected package: ConceptStationPackage, state: Absent, cached: None
[14C8:2BF0][2017-03-21T17:30:30]i101: Detected package: FMEPackage, state: Absent, cached: None
[14C8:2BF0][2017-03-21T17:30:30]i101: Detected package: DirectX, state: Absent, cached: None
[14C8:2BF0][2017-03-21T17:30:30]i000: Setting string variable 'BePlannedAction' to value 'Install'
[14C8:2BF0][2017-03-21T17:30:30]i000: ConceptStationPackageAnalyzeFeatureConditions: LaunchAction=Install
[14C8:2BF0][2017-03-21T17:30:30]i000: ConceptStationPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: ConceptStationPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: FMEPackageAnalyzeFeatureConditions: LaunchAction=Install
[14C8:2BF0][2017-03-21T17:30:30]i000: FMEPackage RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: FMEPackage RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: NetFx451WebAnalyzeFeatureConditions: LaunchAction=Install
[14C8:2BF0][2017-03-21T17:30:30]i000: NetFx451Web RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: NetFx451Web RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: VC140redistAnalyzeFeatureConditions: LaunchAction=Install
[14C8:2BF0][2017-03-21T17:30:30]i000: VC140redist RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: VC140redist RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: DirectXAnalyzeFeatureConditions: LaunchAction=Install
[14C8:2BF0][2017-03-21T17:30:30]i000: DirectX RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: DirectX RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Install
[14C8:2BF0][2017-03-21T17:30:30]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[14C8:2BF0][2017-03-21T17:30:30]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
[14C8:5EB4][2017-03-21T17:30:30]i052: Condition 'NOT BeUpgradingProductCodes' evaluates to true.
[14C8:2BF0][2017-03-21T17:30:30]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[14C8:2BF0][2017-03-21T17:30:30]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles
[14C8:2BF0][2017-03-21T17:30:30]i000: SessionMutex: Creating new SessionMutex
[14C8:2BF0][2017-03-21T17:30:30]i000: SessionMutex: Creating Mutex with Name={b4b58bb3-0f3a-4b94-9588-219f5918821c}-InstallMutex
[14C8:2BF0][2017-03-21T17:30:30]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
[14C8:2BF0][2017-03-21T17:30:30]i000: WixInstallBA::SilentPlan
[14C8:2BF0][2017-03-21T17:30:30]i000: Setting string variable 'BeEulaFileName' to value 'zh-cn\Eula.htm'
[14C8:2BF0][2017-03-21T17:30:30]i199: Detect complete, result: 0x0
[14C8:5EB4][2017-03-21T17:30:32]i000: Setting string variable 'InstallDesktopShortcut' to value '1'
[14C8:5EB4][2017-03-21T17:30:35]i000: Setting string variable 'BeSkipFeatureConfigDialog' to value '1'
[14C8:5EB4][2017-03-21T17:30:35]i052: Condition 'BeUpgradingProductCodes' evaluates to false.
[14C8:5EB4][2017-03-21T17:30:35]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair"' evaluates to true.
[14C8:5EB4][2017-03-21T17:30:35]i000: WixInstallBA::Plan
[14C8:5EB4][2017-03-21T17:30:35]i000: WixInstallBA::SetupModel Plan
[14C8:5EB4][2017-03-21T17:30:35]i000: SetupModel::Before Plan
[14C8:4974][2017-03-21T17:30:35]i000: Before Plan Async
[14C8:4974][2017-03-21T17:30:35]i000: SetupViewModel::Before Plan
[14C8:4974][2017-03-21T17:30:35]i000: WixInstallBA::Before Plan Complete
[14C8:4974][2017-03-21T17:30:35]i000: WixInstallBA::Engine Plan
[14C8:2BF0][2017-03-21T17:30:35]i200: Plan begin, 6 packages, action: Install
[14C8:2BF0][2017-03-21T17:30:35]w321: Skipping dependency registration on package with no dependency providers: NetFx451Web
[14C8:2BF0][2017-03-21T17:30:35]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClient
[14C8:2BF0][2017-03-21T17:30:35]w321: Skipping dependency registration on package with no dependency providers: VC140redist
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'WixBundleRollbackLog_ConceptStationPackage' to value 'C:\Users\Admin\AppData\Local\Temp\OpenRoads ConceptStation CONNECT Edition_20170321173029_000_ConceptStationPackage_rollback.log'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'WixBundleLog_ConceptStationPackage' to value 'C:\Users\Admin\AppData\Local\Temp\OpenRoads ConceptStation CONNECT Edition_20170321173029_000_ConceptStationPackage.log'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'WixBundleRollbackLog_FMEPackage' to value 'C:\Users\Admin\AppData\Local\Temp\OpenRoads ConceptStation CONNECT Edition_20170321173029_001_FMEPackage_rollback.log'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'WixBundleLog_FMEPackage' to value 'C:\Users\Admin\AppData\Local\Temp\OpenRoads ConceptStation CONNECT Edition_20170321173029_001_FMEPackage.log'
[14C8:2BF0][2017-03-21T17:30:35]w321: Skipping dependency registration on package with no dependency providers: DirectX
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'WixBundleLog_DirectX' to value 'C:\Users\Admin\AppData\Local\Temp\OpenRoads ConceptStation CONNECT Edition_20170321173029_002_DirectX.log'
[14C8:2BF0][2017-03-21T17:30:35]i201: Planned package: NetFx451Web, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14C8:2BF0][2017-03-21T17:30:35]i201: Planned package: BentleyConnectClient, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14C8:2BF0][2017-03-21T17:30:35]i201: Planned package: VC140redist, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[14C8:2BF0][2017-03-21T17:30:35]i201: Planned package: ConceptStationPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[14C8:2BF0][2017-03-21T17:30:35]i201: Planned package: FMEPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[14C8:2BF0][2017-03-21T17:30:35]i201: Planned package: DirectX, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[14C8:2BF0][2017-03-21T17:30:35]i000: GetWindowsRootDriveName (): winRoot=C:\
[14C8:2BF0][2017-03-21T17:30:35]i000: IsPathRooted (C:\): true
[14C8:2BF0][2017-03-21T17:30:35]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=1568440
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1568440
[14C8:2BF0][2017-03-21T17:30:35]i000: GetDriveName (C:\): DriveInfo.Name=C:\
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): DriveName=C:\, Path=C:\Program Files\Bentley\OpenRoads ConceptStation CONNECT Edition
[14C8:2BF0][2017-03-21T17:30:35]i000: Warning : Install root drive C:\ is same as windows root drive C:\. Only C:\ will be check for available disk space.
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=3123686867, NewSize=3125255307
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3125255307
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=1470640811, NewSize=4595896118
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.5.1. Next
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23026. Next
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4595896118
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=0, NewSize=4595896118
[14C8:2BF0][2017-03-21T17:30:35]i000: getUsedDriveNamesForInstall (): Feature already installed = CONNECTION Client. Next
[14C8:2BF0][2017-03-21T17:30:35]i000: checkInstallSize (): Checking for drive C:\
[14C8:2BF0][2017-03-21T17:30:35]i000: checkInstallSize (): Requested Drive-List contains drive C:\
[14C8:2BF0][2017-03-21T17:30:35]i000: checkInstallSize (): Checking for drive D:\
[14C8:2BF0][2017-03-21T17:30:35]i000: checkInstallSize (): Checking for drive E:\
[14C8:2BF0][2017-03-21T17:30:35]i000: checkInstallSize (): Checking for drive F:\
[14C8:2BF0][2017-03-21T17:30:35]i000: checkInstallSize (): Checking for drive G:\
[14C8:2BF0][2017-03-21T17:30:35]i000: validateInstallSize (): Result=True
[14C8:2BF0][2017-03-21T17:30:35]i000: PlanComplete: Called
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'ConceptStationPackage_RequestedState' to value '1'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'FMEPackage_RequestedState' to value '1'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'NetFx451Web_RequestedState' to value '1'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'VC140redist_RequestedState' to value '1'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'DirectX_RequestedState' to value '1'
[14C8:2BF0][2017-03-21T17:30:35]i000: Setting string variable 'BentleyConnectClient_RequestedState' to value '1'
[14C8:2BF0][2017-03-21T17:30:35]i000: WixInstallBA::Apply
[14C8:2BF0][2017-03-21T17:30:35]i000: WixInstallBA::Engine Apply
[14C8:2BF0][2017-03-21T17:30:35]i299: Plan complete, result: 0x0
[14C8:2BF0][2017-03-21T17:30:35]i300: Apply begin
[14C8:2BF0][2017-03-21T17:30:35]i000: DisplayMessage (正在安装 OpenRoads ConceptStation CONNECT Edition)
[14C8:2BF0][2017-03-21T17:30:35]i010: Launching elevated engine process.
[14C8:2BF0][2017-03-21T17:30:35]i011: Launched elevated engine process.
[14C8:2BF0][2017-03-21T17:30:35]i012: Connected to elevated engine.
[5A84:4F48][2017-03-21T17:30:35]i358: Pausing automatic updates.
[5A84:4F48][2017-03-21T17:30:35]i359: Paused automatic updates.
[5A84:4F48][2017-03-21T17:30:35]i360: Creating a system restore point.
[5A84:4F48][2017-03-21T17:30:35]w363: Could not create system restore point, error: 0x80070422. Continuing...
[5A84:4F48][2017-03-21T17:30:35]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b4b58bb3-0f3a-4b94-9588-219f5918821c}, options: 0x7, disable resume: No
[5A84:4F48][2017-03-21T17:30:36]i000: Caching bundle from: 'C:\Users\Admin\AppData\Local\Temp\{AD7D753A-E8B5-475D-8F17-BD1EC485049D}\.be\Setup_ConceptStationx64_10.00.04.45.exe' to: 'C:\ProgramData\Package Cache\{b4b58bb3-0f3a-4b94-9588-219f5918821c}\Setup_ConceptStationx64_10.00.04.45.exe'
[5A84:4F48][2017-03-21T17:30:36]i320: Registering bundle dependency provider: {b4b58bb3-0f3a-4b94-9588-219f5918821c}, version: 10.0.4.45
[5A84:4F48][2017-03-21T17:30:36]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b4b58bb3-0f3a-4b94-9588-219f5918821c}, resume: Active, restart initiated: No, disable resume: No
[14C8:2BF0][2017-03-21T17:30:36]i000: Installation chain initiated package from
[14C8:40A4][2017-03-21T17:30:36]i336: Acquiring container: WixAttachedContainer, copy from: E:\Bentley软件\cnst10000445en.exe
[14C8:40A4][2017-03-21T17:30:37]i000: Setting string variable 'WixBundleLastUsedSource' to value 'E:\Bentley软件\'
[14C8:4960][2017-03-21T17:30:39]e000: Error 0x80070570: Failed to extract all files from container, erf: 1:4:0
[14C8:40A4][2017-03-21T17:30:39]e000: Error 0x80070570: Failed to begin and wait for operation.
[14C8:40A4][2017-03-21T17:30:39]e000: Error 0x80070570: Failed to extract payload: a32 from container: WixAttachedContainer
[14C8:40A4][2017-03-21T17:30:39]e312: Failed to extract payloads from container: WixAttachedContainer to working path: C:\Users\Admin\AppData\Local\Temp\{AD7D753A-E8B5-475D-8F17-BD1EC485049D}\8325B0F75E2253FE7AF3255CE7337F61630B4244, error: 0x80070570.
[14C8:40A4][2017-03-21T17:30:39]e000: Caching failed for ConceptStationPackage
[14C8:40A4][2017-03-21T17:30:39]i000: DisplayMessage (安装失败,错误代码 0x80070570。)
[14C8:40A4][2017-03-21T17:30:39]i000: DisplayMessage (提取 OpenRoads ConceptStation CONNECT Edition 失败)
[14C8:2BF0][2017-03-21T17:30:39]e000: Error 0x80070570: Cache thread exited unexpectedly.
[14C8:2BF0][2017-03-21T17:30:39]i000: Installation chain finished package from
[5A84:4F48][2017-03-21T17:30:39]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b4b58bb3-0f3a-4b94-9588-219f5918821c}, resume: None, restart: None, disable resume: No
[5A84:4F48][2017-03-21T17:30:39]i330: Removed bundle dependency provider: {b4b58bb3-0f3a-4b94-9588-219f5918821c}
[5A84:4F48][2017-03-21T17:30:39]i352: Removing cached bundle: {b4b58bb3-0f3a-4b94-9588-219f5918821c}, from path: C:\ProgramData\Package Cache\{b4b58bb3-0f3a-4b94-9588-219f5918821c}\
[5A84:4F48][2017-03-21T17:30:39]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{b4b58bb3-0f3a-4b94-9588-219f5918821c}, resume: None, restart initiated: No, disable resume: No
[14C8:2BF0][2017-03-21T17:30:39]i000: C:\Program Files\Bentley\OpenRoads ConceptStation CONNECT EditionConceptStation\ActivationWizard.exe application is set for launch after installation
[14C8:2BF0][2017-03-21T17:30:39]i000:  application not found to launch after installation
[14C8:2BF0][2017-03-21T17:30:39]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\Admin\AppData\Local\Temp\OpenRoads ConceptStation CONNECT Edition_20170321173029.zip'
[14C8:2BF0][2017-03-21T17:30:39]i399: Apply complete, result: 0x80070570, restart: None, ba requested restart:  No
