请教一下,win10还原后,安装Connection Client和ORD软件显示失败,错误代码0x80070643;
这个该怎么解决?(下面是Connection Client 安装错误后生成的日志)
[1008:1504][2019-07-05T08:22:48]i001: Burn v3.10.3.3007, Windows v10.0 (Build 17763: Service Pack 0), path: C:\Users\YF-BIM~1\AppData\Local\Temp\{5D064067-8CDE-4523-BDCB-99F7A5EFC06D}\.cr\Setup_CONNECTIONClientx64_10.00.10.019.exe [1008:1504][2019-07-05T08:22:48]i000: Initializing numeric variable 'IsDesktopShortcutAvailable' to value '1' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeBundleProductName' to value 'CONNECTION Client' [1008:1504][2019-07-05T08:22:48]i000: Initializing numeric variable 'BeARPDisableModify' to value '1' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'PostInstallLaunchApplication' to value '[InstallDirectory]\Bentley.Connect.Client.exe' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeWarningOnUninstall' to value 'Removing CONNECTION Client may result in CONNECT Edition product capabilities from working correctly. If the CONNECTION Client is running, it will be shut down.' [1008:1504][2019-07-05T08:22:48]i000: Initializing numeric variable 'BeCheckUpdateIsEnabled' to value '1' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'InstallDirectory' to value '[CommonFiles64Folder]Bentley Shared\[BeBundleProductName]\' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;InstallDesktopShortcut' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BentleyClientPackage_DiskSpaceCheckPath' to value '[InstallDirectory]' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeMultiLanguages' to value 'en,cs,de,es,fi,fr,it,ja,ko,nl,pl,pt-br,ru,tr,zh-cn,zh-tw' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeMultilingualRegistryKey' to value 'SOFTWARE\Bentley\Installed_Products\{FA95DCB2-7F5F-4B5C-AD0B-5E8B7E87A557}\Languages' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeSelectedLanguage' to value '' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeBundleCulture' to value '' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeBuildType' to value 'Release' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeNotBuildType' to value 'Beta' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeBundleShortName' to value 'CONNECTIONClient' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeWin64Bundle' to value 'yes' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0' [1008:1504][2019-07-05T08:22:48]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm' [1008:1504][2019-07-05T08:22:48]i009: Command Line: '"-burn.clean.room=E:\Package\0_道路、市政\OpenRoads\OpenRoads_安装\【1-安装包】CNCCBIMORD10.04.01.005 zh\Setup_CONNECTIONClientx64_10.00.10.019.exe" -burn.filehandle.attached=624 -burn.filehandle.self=688' [1008:1504][2019-07-05T08:22:48]i000: Setting string variable 'WixBundleOriginalSource' to value 'E:\Package\0_道路、市政\OpenRoads\OpenRoads_安装\【1-安装包】CNCCBIMORD10.04.01.005 zh\Setup_CONNECTIONClientx64_10.00.10.019.exe' [1008:1504][2019-07-05T08:22:48]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'E:\Package\0_道路、市政\OpenRoads\OpenRoads_安装\【1-安装包】CNCCBIMORD10.04.01.005 zh\' [1008:1504][2019-07-05T08:22:48]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\YF-BIM~1\AppData\Local\Temp\CONNECTION_Client_20190705082248.log' [1008:1504][2019-07-05T08:22:48]i052: Condition 'VersionNT >= v6.1' evaluates to true. [1008:1504][2019-07-05T08:22:48]i000: Setting string variable 'WixBundleName' to value 'CONNECTION Client' [1008:1504][2019-07-05T08:22:48]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated' [1008:1504][2019-07-05T08:22:48]i000: Loading managed bootstrapper application. [1008:1504][2019-07-05T08:22:48]i000: Creating BA thread to run asynchronously. [1008:1450][2019-07-05T08:22:48]i000: GetInstalledLanguage (): No value is found for HKLM registry key SOFTWARE\Bentley\Installed_Products\{FA95DCB2-7F5F-4B5C-AD0B-5E8B7E87A557}\Languages\BundleCulture [1008:1450][2019-07-05T08:22:48]i000: GetUserDefaultUILanguage (): Language Id 2052 [1008:1450][2019-07-05T08:22:48]i000: Setting string variable 'BeBundleCulture' to value 'zh-cn' [1008:1450][2019-07-05T08:22:48]i000: Setting user default langauge = zh-CN, as, this is a multi-lingual package [1008:1450][2019-07-05T08:22:48]i000: Setting Culture Info to zh-cn [1008:1450][2019-07-05T08:22:48]i000: Setting string variable 'BeSelectedLanguage' to value 'zh-cn' [1008:1450][2019-07-05T08:22:48]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value '' [1008:1450][2019-07-05T08:22:48]i000: BentleyBundle Version 11.03.00.58 [1008:1450][2019-07-05T08:22:48]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\YF-BIM001\AppData\Local\Temp\{1EF950B9-9B3E-4575-8A1F-9BDFACC8E1FF}\.ba' [1008:1450][2019-07-05T08:22:48]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\YF-BIM001\AppData\Local\Temp\{5D064067-8CDE-4523-BDCB-99F7A5EFC06D}\.cr' [1008:1450][2019-07-05T08:22:48]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'E:\Package\0_道路、市政\OpenRoads\OpenRoads_安装\【1-安装包】CNCCBIMORD10.04.01.005 zh\' [1008:1450][2019-07-05T08:22:48]e000: Using Layout File : C:\Users\YF-BIM001\AppData\Local\Temp\{1EF950B9-9B3E-4575-8A1F-9BDFACC8E1FF}\.ba\Setup.lyt [1008:1450][2019-07-05T08:22:48]i000: Setting BentleyClientPackage InstallLevel to 1 [1008:1450][2019-07-05T08:22:48]i000: Setting string variable 'BentleyClientPackage.AddLocal' to value 'DefaultFeature' [1008:1450][2019-07-05T08:22:48]i000: Setting DotNet461Full InstallLevel to 1 [1008:1450][2019-07-05T08:22:49]e000: LoadTestAutomationApp(): Failed to load test dll with error 未将对象引用设置到对象的实例。 [1008:1450][2019-07-05T08:22:49]i000: BeDesktopClientInstallerExtension - BENTLEY BOOTSTRAPPER REGISTER [1008:1450][2019-07-05T08:22:49]i000: BeDesktopClientInstallerExtension - Setting BeBundleUIlevel=4 (Full) [1008:1450][2019-07-05T08:22:49]i000: Setting string variable 'BeBundleUIlevel' to value '4' [1008:1450][2019-07-05T08:22:49]i000: Setting string variable 'BeInstallTime' to value '636979117690101955' [1008:1450][2019-07-05T08:22:49]i000: Display is set to Full [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/BasicInstallDirectorySelectionUserControl.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml [1008:1450][2019-07-05T08:22:50]i000: Register callbak=ProxySettingsPage [1008:1450][2019-07-05T08:22:50]i000: Display Page=ProxySettingsPage [1008:1450][2019-07-05T08:22:50]i000: Cannot Display Page=ProxySettingsPage [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml [1008:1450][2019-07-05T08:22:50]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RunningProcessesUserControl.xaml [1008:1504][2019-07-05T08:22:51]i100: Detect begin, 2 packages [1008:1504][2019-07-05T08:22:51]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent [1008:1504][2019-07-05T08:22:51]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [1008:1504][2019-07-05T08:22:51]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [1008:1504][2019-07-05T08:22:51]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [1008:1504][2019-07-05T08:22:51]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [1008:1504][2019-07-05T08:22:51]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [1008:1504][2019-07-05T08:22:51]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [1008:1504][2019-07-05T08:22:51]i000: DetectBegin: Installed State of Package DetectedAbsent [1008:1504][2019-07-05T08:22:51]i000: Setting string variable 'NetFramework46Version' to value '461814' [1008:1504][2019-07-05T08:22:51]i052: Condition '(NetFramework46Version >= 394271 AND VersionNT < v10.0.0.0) OR (NetFramework46Version >= 394254 AND VersionNT >= v10.0.0.0) OR (BeEmbeddedDisplay)' evaluates to true. [1008:1504][2019-07-05T08:22:51]i101: Detected package: BentleyClientPackage, state: Absent, cached: None [1008:1504][2019-07-05T08:22:51]i104: Detected package: BentleyClientPackage, feature: DefaultFeature, state: Absent [1008:1504][2019-07-05T08:22:51]i101: Detected package: DotNet461Full, state: Present, cached: None [1008:1504][2019-07-05T08:22:51]i000: Detect complete Start [1008:1504][2019-07-05T08:22:51]i000: Setting string variable 'BePlannedAction' to value 'Install' [1008:1504][2019-07-05T08:22:51]i000: BentleyClientPackage AnalyzeFeatureConditions: LaunchAction=Install [1008:1504][2019-07-05T08:22:51]i000: BentleyClientPackage AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [1008:1504][2019-07-05T08:22:51]i000: BentleyClientPackage AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [1008:1504][2019-07-05T08:22:51]i000: DotNet461Full AnalyzeFeatureConditions: LaunchAction=Install [1008:1504][2019-07-05T08:22:51]i000: DotNet461Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [1008:1504][2019-07-05T08:22:51]i000: DotNet461Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [1008:1504][2019-07-05T08:22:51]i000: Detection complete planned action: Install [1008:1504][2019-07-05T08:22:51]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle [1008:1504][2019-07-05T08:22:51]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0 [1008:1504][2019-07-05T08:22:51]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles [1008:1504][2019-07-05T08:22:51]i052: Condition 'Privileged OR BePlannedAction~="Layout" OR SkipPrivilegeCheck' evaluates to true. [1008:1504][2019-07-05T08:22:51]i052: Condition 'VersionNT64' evaluates to true. [1008:1504][2019-07-05T08:22:51]i000: SessionMutex: Creating new SessionMutex [1008:1504][2019-07-05T08:22:51]i000: SessionMutex: Creating Mutex with Name={440acd85-4ab2-4633-8863-745e71ac3ad0}-InstallMutex [1008:1504][2019-07-05T08:22:51]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True [1008:1504][2019-07-05T08:22:51]i000: Setting string variable 'BeBundleVersion' to value '[WixBundleVersion]' [1008:1504][2019-07-05T08:22:51]i000: WixInstallBA::SilentPlan [1008:1504][2019-07-05T08:22:51]i000: [1008:1504][2019-07-05T08:22:51]i000: Checking ADDLOCAL and REMOVE... [1008:1504][2019-07-05T08:22:51]i199: Detect complete, result: 0x0 [1008:1450][2019-07-05T08:22:58]i000: Setting string variable 'InstallDirectory' to value 'D:\Program Files\Common Files\Bentley Shared\CONNECTION Client\' [1008:1450][2019-07-05T08:25:00]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair"' evaluates to true. [1008:1450][2019-07-05T08:25:02]i000: WixInstallBA::Plan [1008:1450][2019-07-05T08:25:02]i000: WixInstallBA::SetupModel Plan [1008:1450][2019-07-05T08:25:02]i000: SetupModel::Before Plan [1008:2164][2019-07-05T08:25:02]i000: Before Plan Async [1008:2164][2019-07-05T08:25:02]i000: SetupViewModel::Before Plan [1008:2164][2019-07-05T08:25:02]i000: Is Compressed in Container yes [1008:2164][2019-07-05T08:25:02]i000: FeatureNodeMachineState.Present True [1008:2164][2019-07-05T08:25:02]i000: WixInstallBA::Before Plan Complete [1008:2164][2019-07-05T08:25:02]i000: WixInstallBA::Engine Plan [1008:1504][2019-07-05T08:25:02]i200: Plan begin, 2 packages, action: Install [1008:1504][2019-07-05T08:25:02]i204: Plan 1 msi features for package: BentleyClientPackage [1008:1504][2019-07-05T08:25:02]i000: Setting string variable 'BentleyClientPackage_DefaultFeature_IsInstalling' to value '1' [1008:1504][2019-07-05T08:25:02]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove [1008:1504][2019-07-05T08:25:02]i000: Setting string variable 'WixBundleRollbackLog_BentleyClientPackage' to value 'C:\Users\YF-BIM~1\AppData\Local\Temp\CONNECTION_Client_20190705082248_000_BentleyClientPackage_rollback.log' [1008:1504][2019-07-05T08:25:02]i000: Setting string variable 'WixBundleLog_BentleyClientPackage' to value 'C:\Users\YF-BIM~1\AppData\Local\Temp\CONNECTION_Client_20190705082248_000_BentleyClientPackage.log' [1008:1504][2019-07-05T08:25:02]w321: Skipping dependency registration on package with no dependency providers: DotNet461Full [1008:1504][2019-07-05T08:25:02]i201: Planned package: BentleyClientPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register [1008:1504][2019-07-05T08:25:02]i201: Planned package: DotNet461Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None [1008:1504][2019-07-05T08:25:02]i000: GetWindowsRootDriveName (): winRoot=C:\ [1008:1504][2019-07-05T08:25:02]i000: IsPathRooted (C:\): true [1008:1504][2019-07-05T08:25:02]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\ [1008:1504][2019-07-05T08:25:02]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\ [1008:1504][2019-07-05T08:25:02]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=44006544, FileName=E:\Package\0_道路、市政\OpenRoads\OpenRoads_安装\【1-安装包】CNCCBIMORD10.04.01.005 zh\Setup_CONNECTIONClientx64_10.00.10.019.exe [1008:1504][2019-07-05T08:25:02]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=44006544 [1008:1504][2019-07-05T08:25:02]i000: IsPathRooted (D:\): true [1008:1504][2019-07-05T08:25:02]i000: GetDriveName (D:\): DriveInfo.Name=D:\ [1008:1504][2019-07-05T08:25:02]i000: getUsedDriveNamesForInstall (): DriveName=D:\, Path=D:\Program Files\Common Files\Bentley Shared\CONNECTION Client\ [1008:1504][2019-07-05T08:25:02]i000: getUsedDriveNamesForInstall (): Adding DriveName=D:\, Size=133676513, NewSize=133676513 [1008:1504][2019-07-05T08:25:02]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.6.1. Next [1008:1504][2019-07-05T08:25:02]i000: checkInstallSize (): Checking for drive C:\ [1008:1504][2019-07-05T08:25:02]i000: checkInstallSize (): Requested Drive-List contains drive C:\ [1008:1504][2019-07-05T08:25:02]i000: checkInstallSize (): Checking for drive D:\ [1008:1504][2019-07-05T08:25:02]i000: checkInstallSize (): Requested Drive-List contains drive D:\ [1008:1504][2019-07-05T08:25:02]i000: checkInstallSize (): Checking for drive E:\ [1008:1504][2019-07-05T08:25:02]i000: validateInstallSize (): Result=True [1008:1504][2019-07-05T08:25:02]i000: PlanComplete: Called [1008:1504][2019-07-05T08:25:02]i000: Setting string variable 'BentleyClientPackage_RequestedState' to value '1' [1008:1504][2019-07-05T08:25:02]i000: Setting string variable 'DotNet461Full_RequestedState' to value '1' [1008:1504][2019-07-05T08:25:02]i000: WixInstallBA::Apply [1008:1504][2019-07-05T08:25:02]i000: WixInstallBA::Engine Apply [1008:1504][2019-07-05T08:25:02]i299: Plan complete, result: 0x0 [1008:1504][2019-07-05T08:25:02]i300: Apply begin [1008:1504][2019-07-05T08:25:02]i000: DisplayMessage (正在安装 CONNECTION Client) [1008:1504][2019-07-05T08:25:02]i000: BeDesktopClientInstallerExtension - Attempting to Close CC in Application_ApplyBegin [1008:1504][2019-07-05T08:25:02]i000: BeDesktopClientInstallerExtension - Starting CloseCC Action [1008:1504][2019-07-05T08:25:02]i000: BeDesktopClientInstallerExtension - Finished CloseCC Action [1008:1504][2019-07-05T08:25:02]i000: BeDesktopClientInstallerExtension - Attempting to Kill CC in Application_ApplyBegin [1008:1504][2019-07-05T08:25:02]i000: BeDesktopClientInstallerExtension - Starting KillCC Action [1008:1504][2019-07-05T08:25:02]i000: BeDesktopClientInstallerExtension - Finished KillCC Action [1008:1504][2019-07-05T08:25:02]i010: Launching elevated engine process. [1008:1504][2019-07-05T08:25:02]i011: Launched elevated engine process. [1008:1504][2019-07-05T08:25:02]i012: Connected to elevated engine. [2F34:2024][2019-07-05T08:25:02]i358: Pausing automatic updates. [2F34:2024][2019-07-05T08:25:02]i359: Paused automatic updates. [2F34:2024][2019-07-05T08:25:02]i360: Creating a system restore point. [2F34:2024][2019-07-05T08:25:02]w363: Could not create system restore point, error: 0x80070422. Continuing... [2F34:2024][2019-07-05T08:25:02]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, options: 0x7, disable resume: No [2F34:2024][2019-07-05T08:25:02]i000: Caching bundle from: 'C:\Users\YF-BIM~1\AppData\Local\Temp\{1EF950B9-9B3E-4575-8A1F-9BDFACC8E1FF}\.be\Setup_CONNECTIONClientx64_10.00.10.019.exe' to: 'C:\ProgramData\Package Cache\{440acd85-4ab2-4633-8863-745e71ac3ad0}\Setup_CONNECTIONClientx64_10.00.10.019.exe' [2F34:2024][2019-07-05T08:25:02]i320: Registering bundle dependency provider: {440acd85-4ab2-4633-8863-745e71ac3ad0}, version: 10.0.10.19 [2F34:2024][2019-07-05T08:25:02]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: Active, restart initiated: No, disable resume: No [1008:1504][2019-07-05T08:25:02]i000: Installation chain initiated package from [2F34:2F38][2019-07-05T08:25:02]i305: Verified acquired payload: BentleyClientPackage at path: C:\ProgramData\Package Cache\.unverified\BentleyClientPackage, moving to: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\CONNECTIONClientx64.msi. [2F34:2024][2019-07-05T08:25:02]i323: Registering package dependency provider: {E5473513-7FDA-3730-9A35-71AB8F7F918E}, version: 10.00.10.019, package: BentleyClientPackage [1008:1504][2019-07-05T08:25:02]i000: Installing BentleyClientPackage [1008:1504][2019-07-05T08:25:02]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;bentleyclientpackage' [2F34:2024][2019-07-05T08:25:02]i301: Applying execute package: BentleyClientPackage, action: Install, path: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\CONNECTIONClientx64.msi, arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" FROMLAUNCHSETUP="1" INSTALLDIR="D:\Program Files\Common Files\Bentley Shared\CONNECTION Client\" CCINSTALL_DESKTOPSHORTCUTCHOICE="" PARENTINSTALL_DESKTOPSHORTCUTCHOICE="" LAUNCHINSTALLEDAPP="" BE_BUNDLE_NAME="CONNECTION Client" BE_BUNDLE_VERSION="10.0.10.19" BE_BUNDLE_UILEVEL="4" UC_CHECK_UPDATE_OPTION="" UC_CHECK_UPDATE_IS_ENABLED="1" UC_INSTALL_TIME="636979117690101955" DEFAULT_LANGUAGE="zh-cn" BUNDLE_UI_CULTURE="zh-cn" ADDLOCAL="DefaultFeature"' [2F34:2024][2019-07-05T08:25:09]e000: Error 0x80070643: Failed to install MSI package. [2F34:2024][2019-07-05T08:25:09]e000: Error 0x80070643: Failed to execute MSI package. [1008:1504][2019-07-05T08:25:09]e000: Error 0x80070643: Failed to configure per-machine MSI package. [1008:1504][2019-07-05T08:25:09]i000: Installed package BentleyClientPackage [1008:1504][2019-07-05T08:25:09]i000: DisplayMessage (安装 CONNECTION Client 失败,错误代码为 0x80070643. 安装时发生严重错误) [1008:1504][2019-07-05T08:25:09]i319: Applied execute package: BentleyClientPackage, result: 0x80070643, restart: None [1008:1504][2019-07-05T08:25:09]e000: Error 0x80070643: Failed to execute MSI package. [1008:1504][2019-07-05T08:25:09]i000: Installing BentleyClientPackage [2F34:2024][2019-07-05T08:25:09]i318: Skipped rollback of package: BentleyClientPackage, action: Uninstall, already: Absent [1008:1504][2019-07-05T08:25:09]i000: Installed package BentleyClientPackage [1008:1504][2019-07-05T08:25:09]i319: Applied rollback package: BentleyClientPackage, result: 0x0, restart: None [2F34:2024][2019-07-05T08:25:09]i329: Removed package dependency provider: {E5473513-7FDA-3730-9A35-71AB8F7F918E}, package: BentleyClientPackage [2F34:2024][2019-07-05T08:25:09]i351: Removing cached package: BentleyClientPackage, from path: C:\ProgramData\Package Cache\{E5473513-7FDA-3730-9A35-71AB8F7F918E}v10.00.10.019\ [1008:1504][2019-07-05T08:25:09]i000: Installation chain finished package from [2F34:2024][2019-07-05T08:25:09]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: None, restart: None, disable resume: No [2F34:2024][2019-07-05T08:25:09]i330: Removed bundle dependency provider: {440acd85-4ab2-4633-8863-745e71ac3ad0} [2F34:2024][2019-07-05T08:25:09]i352: Removing cached bundle: {440acd85-4ab2-4633-8863-745e71ac3ad0}, from path: C:\ProgramData\Package Cache\{440acd85-4ab2-4633-8863-745e71ac3ad0}\ [2F34:2024][2019-07-05T08:25:09]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{440acd85-4ab2-4633-8863-745e71ac3ad0}, resume: None, restart initiated: No, disable resume: No [1008:1504][2019-07-05T08:25:09]i000: No application is set for launch after installation [1008:1504][2019-07-05T08:25:09]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\YF-BIM001\AppData\Local\Temp\CONNECTION_Client_20190705082248.zip' [1008:1504][2019-07-05T08:25:09]i000: BeDesktopClientInstallerExtension - BENTLEY BOOTSTRAPPER COMPLETE [1008:1504][2019-07-05T08:25:09]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
您好,您的问题具有通用性,请参照下面的帖子处理:
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/41717/microstation-ce-0x80070643
您好,按您的链接试过了还是不行,还有其他的解决方法吗
重装之前需要完全卸载,请参考下面的帖子:
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/39625/ord
您好,这是电脑的目前状态,是否缺少必要的系统组件呢?
您好,看上去是您的win系统所致。建议尝试安装visual c++2008和2013版本。
为了给其他用户提供帮助或有用的信息,如果您得到了满意的答复,请点击下方的“更多—验证答案”,谢谢! (●'◡'●)
Answer Verified By: ZHR
您好,
根据您的提示,已经解决完问题了;
感谢您
