Starting site PW TransmittalSite PW Transmittal is started.Application pool Bentley Transmittal App Pool already existsAdding IIS APPPOOL\Bentley Transmittal App Pool as a server login.Application pool Bentley Transmittal App Pool is started.Created machine key container BentleyNetFrameworkConfigurationKeyApplication AuditService already exists.Application AuditService.svc has endpoint http://**.**.COM:8009/AuditService/AuditService.svcAdding mex endpoint http://**.**.COM:8009/AuditService/AuditService.svc/mexWaiting and retrying mex endpoint http://**.**.COM:8009/AuditService/AuditService.svc/mexWaiting and retrying mex endpoint http://**.**.COM:8009/AuditService/AuditService.svc/mexException thrown while adding mex endpoint http://**.**.COM:8009/AuditService/AuditService.svc/mex Metadata contains a reference that cannot be resolved: 'http://**.**.com:8009/AuditService/AuditService.svc/mex'.- The requested service, 'http://**.**.com:8009/AuditService/AuditService.svc/mex' could not be activated. See the server's diagnostic trace logs for more information.Deployment cancelledRolling backRoll back completeDeployment cancelledRolling backRoll back complete
您好,您是安装的哪个版本的transmittal?可以将server的日志发给我吗?
日志在什么位置?
根据报错,可以尝试重新创建一个IIS站点,再安装收发文服务试试。IIS站点设置可以参考操作手册。
