關於connection client?
您好,
請問 connection client是連接哪一個網址?
因為server本身不對外網路, 必須特別開啟此網址
謝謝
  • 非常抱歉漏看了您的问题,关于CONNECTION Client需要链接哪些网址,您可以参考如下帖子中的 Which domains does the CONNECTION Client access? 部分查看,目前为止列出了如下网址,需要加入访问白名单,谢谢:
    Whitelist *.Bentley.com AND *.signalr.net, or the following. A description of each domain's purpose is provided below:
    • buddi.bentley.com – Provides current URLs for services so that addresses need not be hard-coded into client products. HTTPS – Simple post / get requests asking for a URL by name and returning the latest location URI
    • ims.bentley.com – Authenticates a Bentley user to utilize Bentley online services.  OAUTH Protocols over HTTPS
    • usermanagement.bentley.com – Bentley’s IMS User Management portal, Used to administer IMS logins.  HTTPS Traffic
    • waz-search.bentley.com – Search service that Bentley applications use to retrieve user profile data and notifications.  HTTPS traffic, simple POSTS and GETS
    • connect-agreement.bentley.com – Confirms whether a user has accepted the EULA yet.  HTTPS traffic, simple POSTS and GETS
    • connect-ulastm.bentley.com – Various web services used for activating products and tracking product usage. Mandatory for using SES software.  HTTPS, POSTS, GETS,   Details of what software was used when, by what machine and user
    • connect.bentley.com – Suggests helpful blogs and guides for the products used   HTTPS
    • connect-updateservicev1.bentley.com - Delivers updates for the CONNECTION Client and other Bentley products   HTTPS Web Services
    • cdnllnw.bentley.com – CDN file services used to host update files for downloading/installing
    • connect-contextregistry.bentley.com – Provides APIs for project and asset information (version 10.00.12.xx and later)  HTTPS Web Services
    • connect-evaluationentitlementservice.bentley.com – Provides evaluation licenses created in the Subscription Entitlement Service   HTTPS Web Services
    • connect-notificationservice.bentley.com -- Provides focused notifications to users  HTTPS Web Services
    • *.signalr.net -- Microsoft hub for real-time information – Provides notifications inside of CONNECTION Client.  HTTPS
    • connect-contextservices.bentley.com – Provides a key necessary to load background maps
    NOTES:
    We do not give IP addresses as they are not static and could change at any time. IP range is also not available, also see IP Address Hosted Server.
    The web services above may not have web pages for display in a browser since their intended audience is a Bentley product, not an end user. The list provided is to ensure any outgoing web traffic to these addresses is not blocked.
    This is a test
