Member unit ratio check incorrect
Dear Sir,
I used SACS to calculate the static strength of crane boom. however, I found some members unit ratio is exceed 1.
 sacinp.inp.dat
I picked the one of these failure members, and found the ratio of the bending stress about y axial is not correct. And other failure members are the same error.
Could you help to check where is the problem with attached the input file?
