NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
老师您好
常规静力计算中,psilst文件中 results for load case下,有很多提示,占据极大版面。下面仅截取一小段。
但计算中没有这个warning,计算结果也可以查看。
这个大量提示,不知是什么意思?会不会影响结果准确性?
多谢老师!
*** AREA   1 WITH GROUP ID WG HAS A CENTROID ELEVATION OF    90.260 FT.
         THIS IS ABOVE THE SURFACE ELEVATION OF    57.543 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    60.810 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    58.972 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    61.613 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    60.139 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    62.060 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    61.273 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    62.076 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    61.795 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    61.628 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    62.243 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
         THIS IS ABOVE THE SURFACE ELEVATION OF    60.849 FT.  NO DRAG OR INERTIA LOAD WILL BE CALCULATED FOR THIS AREA
