<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/communities/other_communities/chinafirst/f/sacs-moses-maxsurf/217976/thread</link><description /><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/666038?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 12:55:21 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:d80cad36-2e5f-4e0b-8f58-ddce812f993f</guid><dc:creator>Jiwei Li</dc:creator><description>&lt;p&gt;&amp;nbsp;方工，经过测试，我们发现主要的问题在于SOIL TORSION的设置，如果将consider distributed torsion analysis 设置为N，并且附一个Torsional Linear Stiffness Value，计算就收敛了。&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665969?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 08:08:14 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:d38109b6-db57-42f7-bfd8-41a2d30f4c2d</guid><dc:creator>FunnyKing</dc:creator><description>&lt;p&gt;您好，已发送到您邮箱，麻烦您帮忙检查，谢谢&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665951?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 07:08:05 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:fd6ee4f1-e7e2-4a0e-b03c-fcaa071cad9c</guid><dc:creator>Jiwei Li</dc:creator><description>&lt;p&gt;方工，您好：1.关于&lt;span&gt;Available End Bearing Area一般根据桩端截面的全面积再考虑一定的比例，比如说8m直径的面积是50㎡，考虑50%的比例就是25㎡，当然这个具体的比例需要根据项目和土壤情况确定，我这里是一个大概的值；2.对于P-Y曲线中Static or Cyclical，主要针对砂土中静载和循环荷载P-Y曲线的计算参数有所不同，这个可以看下API规范中P-Y曲线部分的章节；3.关于模态分析，能否将计算文件传上来，在回复的对话框中有一个insert，可以直接上传文件，我们研究下有什么问题。&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665935?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 06:24:45 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:809ba31c-57ea-4f4d-be27-f9eb1cf809ca</guid><dc:creator>FunnyKing</dc:creator><description>&lt;p&gt;您好，我试着调整了一下，静力计算的warning消除了，但是模态计算还是会报warnning。请问你们是如何考虑&lt;span&gt;Available End Bearing Area的值？看你们填了一个25.还有我想请问，关于P-Y曲线命令中荷载条件Static or Cyclical有何区别，应该如何考虑？&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665916?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 05:36:19 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:4e7177b5-f7a8-4740-8c95-4c3d3108c2f0</guid><dc:creator>Jiwei Li</dc:creator><description>&lt;p&gt;&lt;a href="https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/343644/psiinp.datCZK05"&gt;communities.bentley.com/.../psiinp.datCZK05&lt;/a&gt;您好，经过我们测试，我们觉得应该要调整下泥面以下桩基础的尺寸设置，比如设置成3段，泥面和桩端位置的壁厚为85，中间段壁厚为80，这样桩基础的刚度分布更合理些，把迭代次数设置为30即可消除掉warning，可以试一下上传的桩土文件，如果还有问题，我们再保持沟通。&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665886?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 02:43:03 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:6e88543f-d855-4fde-a602-137dfeb4bac9</guid><dc:creator>FunnyKing</dc:creator><description>&lt;p&gt;已通过邮箱发送，麻烦您帮忙检查，谢谢&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665883?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 02:34:38 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:2236396d-f9d3-4fad-92cd-b695ac1c49d3</guid><dc:creator>Jiwei Li</dc:creator><description>&lt;p&gt;您好，可以发到我的邮箱：jiwei.li@bentley.com，我们研究下。&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665882?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 02:29:33 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:7541b9d9-ab8c-4acc-b69d-600ee3dc3f56</guid><dc:creator>FunnyKing</dc:creator><description>&lt;p&gt;您好，在设置&lt;span&gt;Available End Bearing Area后，计算又超过迭代次数了，麻烦您帮忙看看，请问如何发文件给您？&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665878?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 01:40:24 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:ceeccba1-8951-4471-bf9e-88b86fa58b09</guid><dc:creator>Jiwei Li</dc:creator><description>&lt;p&gt;您好，Driven Unplugged可以理解为不考虑土塞影响，我们建议设置为NO，并且在PLGRUP命令最后Available End Bearing Area中设置考虑土塞后的桩端面积，因为实际工程一般会考虑一定比例的土塞影响，主要影响桩端的承载力。&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665873?ContentTypeID=1</link><pubDate>Thu, 12 Aug 2021 01:18:03 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:3590885a-9829-4976-87d7-0c357ab975f2</guid><dc:creator>FunnyKing</dc:creator><description>&lt;p&gt;您好，我将桩土文件中PLGRUP命令的&amp;ldquo;Driven Unplugged&amp;rdquo;设置为NO后，这个警告就没有了，请问如何理解这个选项的含义？是否有必要设置？&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665778?ContentTypeID=1</link><pubDate>Wed, 11 Aug 2021 12:42:28 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:f1018f58-5698-4936-98cd-6d5f05597cc7</guid><dc:creator>Jiwei Li</dc:creator><description>&lt;p&gt;您好，最好是模型文件、海况文件以及桩土文件，输入文件即可，结果文件不用上传。&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665754?ContentTypeID=1</link><pubDate>Wed, 11 Aug 2021 10:02:56 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:09e6024e-c0eb-4dce-848c-ba27491a143f</guid><dc:creator>FunnyKing</dc:creator><description>&lt;p&gt;请问需要哪几个文件&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 静力计算出现这个警告如何解决？如不解决对计算结果有何影响？</title><link>https://communities.bentley.com/thread/665752?ContentTypeID=1</link><pubDate>Wed, 11 Aug 2021 09:56:52 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:fe981754-cc0d-406a-a1a0-d63434a1c8e7</guid><dc:creator>Jiwei Li</dc:creator><description>&lt;p&gt;您好，根据截图中信息，最大迭代次数已经是999了，我们判断可能是土壤参数有问题，或者您将静力计算的输入文件发上来，我们看看是什么问题。&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
