在安装Staad 22.07到Setup_iTwinAnalyticalSynchronizerx64_12.00.01.019这个阶段时,发生断电。
重新继续安装或者卸载,均显示错误
[3694:3698][2021-10-07T10:23:27]i001: Burn v3.11.1.2318, Windows v10.0 (Build 19042: Service Pack 0), path: C:\Users\yingx\AppData\Local\Temp\{4076390D-09F9-41A6-BD45-95FE8371D071}\.cr\Setup_StaadProx64_22.07.00.160_zh-CN_Full.exe [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeBundleProductName' to value 'STAAD.Pro CONNECT Edition V22 Update 7 SChinese-Language Pack' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\Engineering\STAAD.Pro CONNECT Edition\' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'SamplesDirectory' to value '' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BentleyClientPackage_DiskSpaceCheckPath' to value '[InstallDirectory]' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeBundleCulture' to value 'zh-CN' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeBuildType' to value 'Release' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeNotBuildType' to value 'Beta' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeBundleShortName' to value 'StaadPro' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeWin64Bundle' to value 'yes' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BundleHelpDocument' to value 'STAAD.Pro_Readme.zip' [3694:3698][2021-10-07T10:23:27]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html' [3694:3698][2021-10-07T10:23:27]i009: Command Line: '-burn.clean.room=G:\Download\Setup_StaadProx64_22.07.00.160\Setup_StaadProx64_22.07.00.160_zh-CN_Full.exe -burn.filehandle.attached=684 -burn.filehandle.self=792' [3694:3698][2021-10-07T10:23:27]i000: Setting string variable 'WixBundleOriginalSource' to value 'G:\Download\Setup_StaadProx64_22.07.00.160\Setup_StaadProx64_22.07.00.160_zh-CN_Full.exe' [3694:3698][2021-10-07T10:23:27]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'G:\Download\Setup_StaadProx64_22.07.00.160\' [3694:3698][2021-10-07T10:23:27]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\yingx\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_7_20211007102327.log' [3694:3698][2021-10-07T10:23:27]i052: Condition 'VersionNT >= v6.1' evaluates to true. [3694:3698][2021-10-07T10:23:27]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated' [3694:3698][2021-10-07T10:23:27]i000: Loading managed bootstrapper application. [3694:3698][2021-10-07T10:23:27]i000: Creating BA thread to run asynchronously. [3694:2E24][2021-10-07T10:23:27]i000: Setting Culture Info to zh-CN [3694:2E24][2021-10-07T10:23:27]i000: Setting string variable 'BeSelectedLanguage' to value 'zh-CN' [3694:2E24][2021-10-07T10:23:27]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value '' [3694:2E24][2021-10-07T10:23:27]i000: BentleyBundle Version 13.00.00.14 [3694:2E24][2021-10-07T10:23:27]i000: TRY Set TLS 1.2 [3694:2E24][2021-10-07T10:23:27]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\yingx\AppData\Local\Temp\{C041815B-BBAE-4D47-9CA4-3B9B1AAE9E8F}\.ba' [3694:2E24][2021-10-07T10:23:27]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\yingx\AppData\Local\Temp\{4076390D-09F9-41A6-BD45-95FE8371D071}\.cr' [3694:2E24][2021-10-07T10:23:27]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'G:\Download\Setup_StaadProx64_22.07.00.160\' [3694:2E24][2021-10-07T10:23:27]e000: Using Layout File : C:\Users\yingx\AppData\Local\Temp\{C041815B-BBAE-4D47-9CA4-3B9B1AAE9E8F}\.ba\Setup.lyt [3694:2E24][2021-10-07T10:23:27]i000: Setting DotNet462Full InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting VC14RedistX64 InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting VC14RedistX86 InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting BentleyConnectClient InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting iTwinServicesAddIn InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting SqlCE35SP2_x86 InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting SqlCE35SP2_x64 InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting SpcCatalog InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting SpcServer InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting StaadProPackage InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting string variable 'StaadProPackage.AddLocal' to value 'DefaultFeature,StaadProDesktopShortcut,StaadProShortcuts,StaadProStartMenuShortcut,StaadProSampleModels' [3694:2E24][2021-10-07T10:23:27]i000: Setting StaadProLanguagePack InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting RCDC InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting VC10RedistX86 InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting BuildingPlanner InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting StructuralSynchronizer InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting STAADFoundationAdvanced_x86 InstallLevel to 1 [3694:2E24][2021-10-07T10:23:27]i000: Setting string variable 'BePrimaryProductName' to value 'STAAD.Pro CONNECT Edition V22 Update 7 (22.07.00.160)' [3694:2E24][2021-10-07T10:23:31]i000: Running with UI [3694:2E24][2021-10-07T10:23:31]i000: Display is set to Full [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/BasicInstallDirectorySelectionUserControl.xaml [3694:2E24][2021-10-07T10:23:31]i000: Setting string variable 'BeSelectedLanguage' to value '' [3694:2E24][2021-10-07T10:23:31]i000: Value for WixBundleSourceProcessPath is G:\Download\Setup_StaadProx64_22.07.00.160\Setup_StaadProx64_22.07.00.160_zh-CN_Full.exe [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml [3694:2E24][2021-10-07T10:23:31]i000: Register callbak=ProxySettingsPage [3694:2E24][2021-10-07T10:23:31]i000: Display Page=ProxySettingsPage [3694:2E24][2021-10-07T10:23:31]i000: Cannot Display Page=ProxySettingsPage [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml [3694:2E24][2021-10-07T10:23:31]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml [3694:3698][2021-10-07T10:23:31]i100: Detect begin, 16 packages [3694:3698][2021-10-07T10:23:31]i000: DetectBegin: e.Install=true, PlannedAction=Unknown, Setting InstallState=DetectedPresent [3694:3698][2021-10-07T10:23:31]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [3694:3698][2021-10-07T10:23:31]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [3694:3698][2021-10-07T10:23:31]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay [3694:3698][2021-10-07T10:23:31]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [3694:3698][2021-10-07T10:23:31]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [3694:3698][2021-10-07T10:23:31]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck [3694:3698][2021-10-07T10:23:31]i000: DetectBegin: Installed State of Package DetectedPresent [3694:3698][2021-10-07T10:23:31]i000: Setting version variable 'ConnectAdvisorInstalledVersion' to value '10.1.0.287' [3694:3698][2021-10-07T10:23:31]i000: Setting string variable 'ConnectClient_InstalledVersion_x64' to value '11.00.03.25' [3694:3698][2021-10-07T10:23:31]i000: Setting version variable 'iTwinServicesAddInInstalledVersion' to value '1.1.0.93' [3694:3698][2021-10-07T10:23:31]i000: Setting string variable 'LanguagePackRegistry' to value '22.07.00.160' [3694:3698][2021-10-07T10:23:31]i000: Setting string variable 'NetFramework46_InstalledVersion' to value '528372' [3694:3698][2021-10-07T10:23:31]i000: Setting string variable 'SqlCE35SP2_x64InstalledVersion' to value '3.5.8080.0' [3694:3698][2021-10-07T10:23:31]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\D30CF9A3586C138449FCE4FD3D474979\InstallProperties' [3694:3698][2021-10-07T10:23:31]i000: Setting version variable 'STAADAdvancedConcreteDesignRCDCVersion' to value '11.0.0.143' [3694:3698][2021-10-07T10:23:31]i000: Product or related product not found: {F52A2A12-4E1F-43FD-8847-914B6C4F2BB3} [3694:3698][2021-10-07T10:23:31]i000: Setting version variable 'STAADFoundationAdvancedInstalledVersion' to value '0.0.0.0' [3694:3698][2021-10-07T10:23:31]i000: Product or related product not found: {74322187-0D4D-4B4E-948B-EF61E96691DA} [3694:3698][2021-10-07T10:23:31]i000: Setting numeric variable 'STAADPro_QAnR_Build_Install_State' to value 2 [3694:3698][2021-10-07T10:23:31]i000: Registry key not found. Key = 'SOFTWARE\Bentley\ISM' [3694:3698][2021-10-07T10:23:31]i000: Setting string variable 'VC10Runtime_InstalledVersion_x86' to value 'v10.0.40219.473' [3694:3698][2021-10-07T10:23:31]i000: Setting version variable 'VCRedist2017x64' to value '14.29.30129.0' [3694:3698][2021-10-07T10:23:31]i000: Setting version variable 'VCRedist2017x86' to value '14.29.30129.0' [3694:3698][2021-10-07T10:23:31]i102: Detected related bundle: {aace989c-fbb7-41c9-9096-95d5e0ccfe3c}, type: Addon, scope: PerMachine, version: 22.7.0.160, operation: Install [3694:3698][2021-10-07T10:23:31]i000: Upgrading: RelatedOperation=Install; RelationType=Addon [3694:3698][2021-10-07T10:23:31]i052: Condition 'NetFramework46_InstalledVersion >= 394802' evaluates to true. [3694:3698][2021-10-07T10:23:31]i052: Condition '(VCRedist2017x64 >= v14.16.27027.1)' evaluates to true. [3694:3698][2021-10-07T10:23:31]i052: Condition '(VCRedist2017x86 >= v14.16.27027.1)' evaluates to true. [3694:3698][2021-10-07T10:23:31]i052: Condition '(ConnectClient_InstalledVersion_x64 >= v11.00.03.25)' evaluates to true. [3694:3698][2021-10-07T10:23:31]i052: Condition '(iTwinServicesAddInInstalledVersion >= v01.01.00.093)' evaluates to true. [3694:2E24][2021-10-07T10:23:31]i000: ErrorPage Code: 0 [3694:3698][2021-10-07T10:23:33]i052: Condition 'LanguagePackRegistry = v22.07.00.160' evaluates to true. [3694:3698][2021-10-07T10:23:33]i052: Condition '(STAADAdvancedConcreteDesignRCDCVersion >= v11.00.00.143)' evaluates to true. [3694:3698][2021-10-07T10:23:33]i052: Condition '"10.0.40219.1" <= VC10Runtime_InstalledVersion_x86' evaluates to true. [3694:3698][2021-10-07T10:23:33]i052: Condition '(StructuralSynchronizer_InstalledVersion_x64 >= v12.0.1.019)' evaluates to false. [3694:3698][2021-10-07T10:23:33]i052: Condition '(STAADFoundationAdvancedInstalledVersion >= v09.06.00.062)' evaluates to false. [3694:3698][2021-10-07T10:23:33]i101: Detected package: DotNet462Full, state: Present, cached: None [3694:3698][2021-10-07T10:23:33]i101: Detected package: VC14RedistX64, state: Present, cached: None [3694:3698][2021-10-07T10:23:33]i101: Detected package: VC14RedistX86, state: Present, cached: None [3694:3698][2021-10-07T10:23:33]i101: Detected package: BentleyConnectClient, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: iTwinServicesAddIn, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: SqlCE35SP2_x86, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: SqlCE35SP2_x64, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: SpcCatalog, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: SpcServer, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: StaadProPackage, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i104: Detected package: StaadProPackage, feature: DefaultFeature, state: Local [3694:3698][2021-10-07T10:23:33]i104: Detected package: StaadProPackage, feature: StaadProDesktopShortcut, state: Local [3694:3698][2021-10-07T10:23:33]i104: Detected package: StaadProPackage, feature: StaadProShortcuts, state: Local [3694:3698][2021-10-07T10:23:33]i104: Detected package: StaadProPackage, feature: StaadProStartMenuShortcut, state: Local [3694:3698][2021-10-07T10:23:33]i104: Detected package: StaadProPackage, feature: StaadProSampleModels, state: Local [3694:3698][2021-10-07T10:23:33]i101: Detected package: StaadProLanguagePack, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: RCDC, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: VC10RedistX86, state: Present, cached: None [3694:3698][2021-10-07T10:23:33]i101: Detected package: BuildingPlanner, state: Present, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: StructuralSynchronizer, state: Absent, cached: Complete [3694:3698][2021-10-07T10:23:33]i101: Detected package: STAADFoundationAdvanced_x86, state: Absent, cached: Complete [3694:3698][2021-10-07T10:23:33]i000: Detect complete Start [3694:3698][2021-10-07T10:23:33]i000: SessionMutex: Creating new SessionMutex [3694:3698][2021-10-07T10:23:33]i000: SessionMutex: Creating Mutex with Name={00f500fd-c51a-4c91-949c-13fef54210c8}-InstallMutex [3694:3698][2021-10-07T10:23:33]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True [3694:3698][2021-10-07T10:23:33]i000: KBDetect: Current action is allowed to executed for KB check. ActionName=Install [3694:3698][2021-10-07T10:23:33]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1 [3694:2E24][2021-10-07T10:23:34]i000: Setting string variable 'BePlannedAction' to value 'Modify' [3694:2E24][2021-10-07T10:23:34]i000: DotNet462Full AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: DotNet462Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: DotNet462Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: VC14RedistX64 AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: VC14RedistX64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: VC14RedistX64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: VC14RedistX86 AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: VC14RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: VC14RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: iTwinServicesAddIn AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: iTwinServicesAddIn AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: iTwinServicesAddIn AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: SpcCatalog AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: SpcCatalog AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: SpcCatalog AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: SpcServer AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: SpcServer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: SpcServer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StaadProLanguagePack AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: StaadProLanguagePack AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: StaadProLanguagePack AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: RCDC AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: RCDC AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: RCDC AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: BuildingPlanner AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: BuildingPlanner AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: BuildingPlanner AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: VC10RedistX86 AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: VC10RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: VC10RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: StructuralSynchronizer AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: StructuralSynchronizer AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: StructuralSynchronizer AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:2E24][2021-10-07T10:23:34]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: LaunchAction=Modify [3694:2E24][2021-10-07T10:23:34]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:2E24][2021-10-07T10:23:34]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair"' evaluates to true. [3694:3698][2021-10-07T10:23:35]e000: WaitForProxyAuthentication: Waiting for proxy authentication [3694:3698][2021-10-07T10:23:35]i000: Fetch BUDDI Key, RetryCount = 0 [3694:3698][2021-10-07T10:23:35]e000: SetHeaders (): Added bootstrapper id in header, {00f500fd-c51a-4c91-949c-13fef54210c8} [3694:3698][2021-10-07T10:23:35]i000: Resolving Buddi Key. Attempt: 1 [3694:2E24][2021-10-07T10:23:44]i000: WixInstallBA::Plan [3694:2E24][2021-10-07T10:23:44]i000: WixInstallBA::SetupModel Plan [3694:2E24][2021-10-07T10:23:44]i000: SetupModel::Before Plan [3694:4564][2021-10-07T10:23:44]i000: Before Plan Async [3694:4564][2021-10-07T10:23:44]i000: SetupViewModel::Before Plan [3694:3698][2021-10-07T10:23:45]i000: BeSkipKBCheck : [3694:3698][2021-10-07T10:23:45]i000: Setting string variable 'BePlannedAction' to value 'Unknown' [3694:3698][2021-10-07T10:23:45]i000: DotNet462Full AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: DotNet462Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: DotNet462Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: VC14RedistX64 AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: VC14RedistX64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: VC14RedistX64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: VC14RedistX86 AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: VC14RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: VC14RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: iTwinServicesAddIn AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: iTwinServicesAddIn AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: iTwinServicesAddIn AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: SpcCatalog AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: SpcCatalog AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: SpcCatalog AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: SpcServer AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: SpcServer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: SpcServer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StaadProLanguagePack AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: StaadProLanguagePack AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: StaadProLanguagePack AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: RCDC AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: RCDC AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: RCDC AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: BuildingPlanner AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: BuildingPlanner AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: BuildingPlanner AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: VC10RedistX86 AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: VC10RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: VC10RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: StructuralSynchronizer AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: StructuralSynchronizer AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: StructuralSynchronizer AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=True [3694:3698][2021-10-07T10:23:45]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: LaunchAction=Unknown [3694:3698][2021-10-07T10:23:45]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False [3694:3698][2021-10-07T10:23:45]i000: Detection complete planned action: Unknown [3694:3698][2021-10-07T10:23:45]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle [3694:3698][2021-10-07T10:23:45]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0 [3694:3698][2021-10-07T10:23:45]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles [3694:3698][2021-10-07T10:23:45]i000: WixInstallBA::SilentPlan [3694:3698][2021-10-07T10:23:45]i000: [3694:3698][2021-10-07T10:23:45]i199: Detect complete, result: 0x0 [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: PlannedAction Unknown [3694:4564][2021-10-07T10:23:45]i000: WixInstallBA::Before Plan Complete [3694:4564][2021-10-07T10:23:45]i000: WixInstallBA::Engine Plan [3694:3698][2021-10-07T10:23:45]i200: Plan begin, 16 packages, action: Unknown [3694:3698][2021-10-07T10:23:45]i000: PlanRelatedBundle (): Command line Action for Planning, Id={aace989c-fbb7-41c9-9096-95d5e0ccfe3c}, Action=Install [3694:3698][2021-10-07T10:23:45]e000: Error 0x80070057: Invalid action state. [3694:3698][2021-10-07T10:23:45]e000: Error 0x80070057: Failed to get default request state for action. [3694:3698][2021-10-07T10:23:45]e000: Error 0x80070057: Failed to set default package state. [3694:3698][2021-10-07T10:23:45]e000: Error 0x80070057: Failed to process package. [3694:3698][2021-10-07T10:23:45]e000: Error 0x80070057: Failed to plan packages. [3694:3698][2021-10-07T10:23:45]i000: validateInstallSize (): Result=True [3694:3698][2021-10-07T10:23:45]i000: Installation failed to Plan with error code -2147024809 [3694:3698][2021-10-07T10:23:45]i299: Plan complete, result: 0x80070057 [3694:2E24][2021-10-07T10:23:45]i000: ErrorPage Code: -2147024809
您好!由于假期回复的晚了,实在抱歉,您的这个问题可以看下这个帖子:
安装Structural synchronizer失败,错误代码为0x80070642 - 技术资料库 - Bentley 中国优先社区 - Bentley Communitieshttps://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/52828/structural-synchronizer-0x80070642
完整的12.00.01.019 ISM下载您再这里可以获得:
链接:https://pan.baidu.com/s/1z5_7_Ftv_cCkMxReqVP8jA提取码:fepf (如果我的回复对您有所帮助,请帮忙点击“验证答案”(点击More,再点击验证答案),非常感谢您对我们工作的支持。)
Answer Verified By: netsonic
