在导入设备报表时出现图中的提示,请问是什么原因?谢谢。
请将报表上传以便测试,另外使用的是哪个版本的BRCM,可以在帮助-关于BRCM中进行查看。
您好,文件上传了,请查看测试,BRCM版本:V8i(SELECTseries 2)—08.11.09.28(另:电脑系统为Windows 10)
3580.EquipmentMap.xls
<?xml version="1.0"?> <!-- substr(<variable for result>, <absolute/relative start position>) substr(<variable for result>, <absolute/relative start position>, absolute/relative end position/additional substring length) absolute position: 0, 5,... relative position: 1x'.'+1 = first occurance of '.' plus one char 2x' - '+3 = second occurance of ' - ' plus three chars r1x'-'-1 = first '-' backwards (last '-') minus one char additional substring length: +0 = no additional length = just the char at the start position +3 = start position plus three chars = length 4 sbustr with only two parameters retrieves substring from start position until and including last character format_xtr (extraction format): sbustring or absolute value format_pub (publish format) : [prefix]($<result variable of format_xtr>)[suffix] mandatory: <1||yes||true||on> || <0||no||false||off> --> <XLImportSheet version="0.1" created_by="oh" company="ABB_CH"> <Sheets> <Sheet number="1" name="" line_start="2" line_stop="500" col_start="A" col_end="Z"/> </Sheets> <Values name="2level"> <!-- TARGET ID must be imported FIRST --> <Value xl_col="B" tree="1" h_level="1" tag="ID" mandatory="1" format_xtr="X" format_pub="($X)"/> <Value xl_col="A" tree="1" h_level="1" tag="NODE" mandatory="0" format_xtr="X" format_pub="($X)"/> <Value xl_col="C" tree="1" h_level="1" tag="DIST" mandatory="0" format_xtr="X" format_pub="($X)"/> </Values> </XLImportSheet>
上个回复中已上传了excel文件,谢谢。
好的
您好,我这边测试了一下没有问题,这边请你详细叙述一下操作步骤或者帮你远程看一下吧。
您好,可否远程帮我看一下?
请将联系方式发到我邮箱:yuhui.Liu@bentley.com
Answer Verified By: CC Gong
