专家好,我在使用BRCM导入电缆清册时,选择好excel表和XML文件后导入,弹出服务器出现意外情况。
我是用的为OFFICE2013版本,不管是用V8I还是CE版本的BRCM软件均出现同样问题,请问怎么解决呢
点击一下“更新数据库”命令查看是否正常,然后尝试重启软件或计算机,如果仍然无效,请将电缆清册和xml文件上传,我们会进行进一步测试。
数据库没有问题,也点过更新数据库没有异常,之前也多次使用过。
后来出现了这个问题后,我甚至重装过系统,还是不行。
电缆清册我使用的就是V8I或者CE自带的示例项目的cablelist的excel表和xml文件,我这里也上传一个。
<?xml version="1.0" encoding="utf-8"?> <!-- substr(<variable for result>, <absolute/relative start position>) substr(<variable for result>, <absolute/relative start position>, absolute/relative end position/additional substring length) absolute position: 0, 5,... relative position: 1x'.'+1 = first occurance of '.' plus one char 2x' - '+3 = second occurance of ' - ' plus three chars r1x'-'-1 = first '-' backwards (last '-') minus one char additional substring length: +0 = no additional length = just the char at the start position +3 = start position plus three chars = length 4 sbustr with only two parameters retrieves substring from start position until and including last character format_xtr (extraction format): sbustring or absolute value format_pub (publish format) : [prefix]($<result variable of format_xtr>)[suffix] mandatory: <1||yes||true||on> || <0||no||false||off> --> <XLImportSheet version="0.1" created_by="oh" company="HASOFT"> <Sheets> <Sheet number="1" name="" line_start="2" line_stop="500" col_start="A" col_end="Z" /> </Sheets> <condition name="voltage_level" xl_col="F" format_xtr="X" format_pub="($X)"> <variable name="tree_id" condition_value="LV" value="0001" /> <variable name="tree_id" condition_value="MV" value="0002" /> <variable name="tree_id" condition_value="CTRL" value="0003" /> <variable name="tree_id" condition_value="IW" value="0004" /> </condition> <Values name="2level"> <condition name="voltage_level"> <condition_value value="LV" /> <condition_value value="MV" /> <condition_value value="CTRL" /> <condition_value value="IW" /> </condition> <Value xl_col="A" tree="1" h_level="1" tag="Name" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="A" tree="1" h_level="1" tag="CablePref" mandatory="0" format_xtr="NOP" format_pub="($0,Name)" /> <Value xl_col="A" tree="1" h_level="2" tag="Name" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="A" tree="1" h_level="2" tag="CablePref" mandatory="0" format_xtr="NOP" format_pub="($0,Name)" /> <Value xl_col="E" tree="2" h_level="3" tag="Name" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="F" tree="2" h_level="3" tag="RoutingFilter" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="G" tree="2" h_level="3" tag="CableType" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="A" tree="2" h_level="3" tag="PreDefSourceID" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="B" tree="2" h_level="3" tag="ObjectFromLoc" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="C" tree="2" h_level="3" tag="PreDefTargetID" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="D" tree="2" h_level="3" tag="ObjectToLoc" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="H" tree="2" h_level="3" tag="CableLookup" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="I" tree="2" h_level="3" tag="Load" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="J" tree="2" h_level="3" tag="CableAddLength1" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="K" tree="2" h_level="3" tag="CableAddLength2" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="L" tree="2" h_level="3" tag="SpareCore" mandatory="1" format_xtr="X" format_pub="($X)" /> <!-- <Value xl_col="F" tree="2" h_level="3" tag="CableDescr" mandatory="1" format_xtr="X" format_pub="($X)"/> <Value xl_col="H" tree="2" h_level="3" tag="CableLookup" mandatory="1" format_xtr="X" format_pub="($X)"/> <Value xl_col="I" tree="2" h_level="3" tag="Load" mandatory="1" format_xtr="X" format_pub="($X)"/> --> </Values> </XLImportSheet>
我这边测试导入正常,请参考这个帖子重置软件用户设置一下:
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/40979/2---abd
Answer Verified By: Zhong Ling 钟凌
您好,按照操作我分别初始化了V8I和CE版本的BRCM,其中CE版本的问题得到了解决
但是V8I版本的可以进行导入的前几部操作后还是有有报错,截图如下,烦请看下是否有解决方案。
之前也有遇到过这样的情况,一般可以通过重新安装软件解决,或者更新到CE版本,新的版本的出问题的概率要小得多;
重新安装可以参考这个帖子,删除软件
communities.bentley.com/.../brcm
在删除软件并关闭所有国产杀毒软件后, 重新安装软件。
(如果觉得我们的回答对您有所帮助,请在更多中帮我们点击verify answer~)
