如图,电缆清册导入的时候,安装教学视频,也检查过了。但是每次都没有这两列信息。电缆清册也是老师给的模板。之后检查差异性的时候也是一样
没有显示差异,也不能更新进行下一步
cable list.xls
<?xml version="1.0" encoding="utf-8"?> <XLImportSheet> <Sheets> <Sheet number="1" name="" line_start="2" line_stop="100" col_start="A" col_end="Z" /> </Sheets> <condition name="voltage_level" xl_col="F" format_xtr="X" format_pub="($X)"> <variable name="tree_id" condition_value="LV" value="0001"></variable> <variable name="tree_id" condition_value="MV" value="0002"></variable> <variable name="tree_id" condition_value="CTRL" value="0003"></variable> <variable name="tree_id" condition_value="IW" value="0004"></variable> <variable name="tree_id" condition_value="COM" value="0005"></variable> </condition> <Values name="2level"> <condition name="voltage_level"> <condition_value value="LV"></condition_value> <condition_value value="MV"></condition_value> <condition_value value="CTRL"></condition_value> <condition_value value="IW"></condition_value> <condition_value value="COM"></condition_value> </condition> <Value xl_col="A" tree="1" h_level="1" tag="Name" mandatory="1" format_xtr="substr(X, 0, 1x'-' - 1)" format_pub="($X)" /> <Value xl_col="A" tree="1" h_level="1" tag="CablePref" mandatory="0" format_xtr="X" format_pub="($0,Name)" /> <Value xl_col="A" tree="1" h_level="2" tag="Name" mandatory="1" format_xtr="substr(X, 1x'-' + 1)" format_pub="($X)" /> <Value xl_col="A" tree="1" h_level="2" tag="CablePref" mandatory="0" format_xtr="X" format_pub="($0,Name)" /> <Value xl_col="E" tree="2" h_level="3" tag="Name" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="F" tree="2" h_level="3" tag="RoutingFilter" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="F" tree="2" h_level="3" tag="VoltageLevel" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="G" tree="2" h_level="3" tag="CableType" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="A" tree="2" h_level="3" tag="PreDefSourceID" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="B" tree="2" h_level="3" tag="ObjectFromLoc" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="C" tree="2" h_level="3" tag="PreDefTargetID" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="D" tree="2" h_level="3" tag="ObjectToLoc" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="H" tree="2" h_level="3" tag="CableLookup" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="I" tree="2" h_level="3" tag="Load" mandatory="1" format_xtr="X" format_pub="($X)" /> </Values> </XLImportSheet>
请问问题解决的了吗?我也有类似的问题,这是有问题吗?
我这边老师沟通搞定了,是自己制作的表格列表没有映射值。用了老师给的文件就好啦。
链接: pan.baidu.com/.../1wdERfpOkwWVNv72s-3lePQ 提取码: b91z
好的,那我也试一下,十分感谢
