有电缆沟和桥架的工程,在画好电缆沟和桥架,并且连接好虚拟连接线,而且所有路径都已经建立好连接,并用敷设路径检查命令检查完毕,电缆敷设时找不到桥架路径,而把电缆沟改成桥架后,电缆可以正常敷设。或者用桥架重新搭起一条路径,代替电缆沟的路径,电缆均能正常敷设,就是有电缆沟的就显示“未找到桥架路径”不知道什么原因?
18号转载站配电电缆表.xls
<?xml version="1.0" encoding="utf-8"?> <XLImportSheet> <Sheets> <Sheet number="1" name="" line_start="3" line_stop="500" col_start="A" col_end="Z" /> </Sheets> <condition name="voltage_level" xl_col="H" format_xtr="X" format_pub="($X)"> <variable name="tree_id" condition_value="LV" value="0001"></variable> <variable name="tree_id" condition_value="MV" value="0002"></variable> <variable name="tree_id" condition_value="CTRL" value="0003"></variable> <variable name="tree_id" condition_value="IW" value="0004"></variable> <variable name="tree_id" condition_value="COM" value="0005"></variable> </condition> <Values name="2level"> <condition name="voltage_level"> <condition_value value="LV"></condition_value> <condition_value value="MV"></condition_value> <condition_value value="CTRL"></condition_value> <condition_value value="IW"></condition_value> <condition_value value="COM"></condition_value> </condition> <Value xl_col="B" tree="1" h_level="1" tag="Name" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="B" tree="1" h_level="1" tag="CablePref" mandatory="0" format_xtr="NOP" format_pub="($0,Name)" /> <Value xl_col="B" tree="1" h_level="2" tag="Name" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="B" tree="1" h_level="2" tag="CablePref" mandatory="0" format_xtr="NOP" format_pub="($0,Name)" /> <Value xl_col="G" tree="2" h_level="3" tag="Name" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="H" tree="2" h_level="3" tag="RoutingFilter" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="H" tree="2" h_level="3" tag="VoltageLevel" mandatory="0" format_xtr="X" format_pub="($X)" /> <Value xl_col="I" tree="2" h_level="3" tag="CableType" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="B" tree="2" h_level="3" tag="PreDefSourceID" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="C" tree="2" h_level="3" tag="ObjectFromLoc" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="D" tree="2" h_level="3" tag="PreDefTargetID" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="E" tree="2" h_level="3" tag="ObjectToLoc" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="M" tree="2" h_level="3" tag="CableLookup" mandatory="1" format_xtr="X" format_pub="($X)" /> <Value xl_col="M" tree="2" h_level="3" tag="Load" mandatory="1" format_xtr="X" format_pub="($X)" /> </Values> </XLImportSheet>
这一部分的电缆沟没有桥架路径:
Answer Verified By: 丽微 何
那部分电缆沟是因为之前是完整的电缆沟,都建立了连接后电缆敷设找不到桥架路径,在寻找解决方法时发现是因为有电缆沟路段,才出现这个现场,用桥架建立旁路连通之后,电缆能够正常敷设,现在是有电缆沟和桥架连接的路段,敷设就不成功。
只有电缆沟没有旁路的工程如下https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/343617/1362._3A6735755F00_18_23006C8F7D8FD97A5F004D913575_.dgn
