这是什么情况?怎么解决?
可先用一个最简单模型测试一下您软件的这个功能。如果也有问题,那就是软件的问题,如果能通过,可能是您当前的模型太复杂所致。需要提供您的模型供我们分析。
简单模型测试没问题 我的模型是通发到那个邮件账号去 还是发到这来
您好!
Bentley国外专家也注意到了您的提问。他建议如下:
1. 点击出错对话框左下角按钮查看/发送错误消息;
2. 压缩您模型文件(.STSW和.SQLITE),按如下英文网页说明发送给我们:
https://communities.bentley.com/help/w/be_communities_help/32255/sharing-hydraulic-model-files-on-the-openflows-hydraulics-hydrology-forum
20190426(体育场海绵城市).zip
通过谷歌翻译从英语翻译的中文(简体)回复。
你好,
我检查了你的模型,发现了一些错误/警告,你应该在分析nework之前纠正它们;
1.有很多低影响开发区域是活跃的,但没有连接到任何“活跃”的父集水区。通过使这些集水区“活动”,使LID区域“无效”或将它们连接到父集水区。
2.活动集水区没有任何流出节点。第一个场景中有两个活动集水区,但它们都没有任何活动的外流节点。
但是,在我的情况下,软件没有崩溃。尝试纠正上述问题,看看这是否有帮助。
问候,Yashodhan JoshiBentley技术支持
_______________
(Response in English)
I checked your model and found some errors / warnings which you should correc before analyzing the nework;
1. There are a lot of Low Impact Development areas which are active but not connected to any "active" parent catchment. Either make the LID areas "inactive" or connect them to parent catchments by making these catchments "active".
2. The active catchments are not having any outflow node. There are two active catchments in the first scenario but both of them do not have any active outflow node.
However, the software didn't crash in my case. Try correcting the issues above and see if this helps.
Regards,Yashodhan JoshiBentley Technical Support
Yashodhan Joshi
