能否在CivilStorm 或者 SewerGEMS中模拟(model)管道淤积(Pipeline siltation or Pipeline silting)的情况呢?如果可以实现 应该如何操作呢?按什么步骤执行?(how can I make it?)
谷歌翻译
你好农民,
以下是有关在SewerGEMS中对管道/导管中过多淤泥进行建模的可能方法的信息,请仔细阅读。
模拟导管或出口结构中的障碍物,堵塞物或过多的沉积物
Sushma Choure
Bentley Technical Suppport
Thanks a lot
I will read this massage
Specify a conduit start or stop control structure and model it as an orifice (to use the orifice equation to model the restriction)
I do not understand this
where should I put the control structure?
Hello Farmer,
In the conduit properties, there is an option to add start or stop control structure to the conduit. Click True for say has stop control structure as shown below, under stop control structure, click on edit control structure to set up the orifice control structure.
Conduit start/stop control structures
Answer Verified By: farmer
Hi Farmer, if you are comfortable with English, you can post to the main OpenFlows forum for future questions.
