在使用的版本是10.03.00.69 中文版
控制中添加合成条件是,点击...选择简单条件后,不能添加或确认,应该是窗口显示的问题。已经确认过分辨率,同时重启过电脑及软件,均无法解决。
是否可以查找下原因,提供一个小版本修复该问题?
谢谢
Hi Meng,
您好,可能是软件显示适应性的问题,试着把系统字体DPI调整小一点,或者将系统地区设置为“中国”看一下。如果还没有解决,请继续跟进问题回复。
Answer Verified By: MENG ZHANG
I noticed that you communicated in English in the OpenFlows Forum. If you are OK with doing so, you can post future questions there.
Here is my response to this post, in English:
Most likely the problem is due to the computer’s font setting, display scale or DPI scaling. See related articles (in English):
Dropdown selection box cut off or button not visible
Check boxes do not appear in tables such as Control Sets dialog
List of scenarios not appearing directly below the Scenario dropdown
Jesse,
Thanks for the answer. I tried all three solution and the DPI helps, though I don't have a multi-monitor.
The only thing may worth bringing up is that I actually need to adjust the DPI to a higher number (from 100% to 105%), which makes all fonts larger on the screen.
Hope the next version may adress it.
Best,
Meng
