一个深邃系统中两个竖井对应的模型应该采用调压井还是水箱还是水库来模拟呢?How to simulate the model of two shafts in a deep system (use surge tank or reservoir or water tank?)
我在用bentley hammer软件模拟我们单位在深圳做的一个泵站项目,这个项目是一个深埋隧洞输水泵站,特点和常规的泵站不一样,从水库取水,经过两个很深的竖井和深埋隧洞才把水送到取水泵站(主要是避开很多深埋的地铁线)。我在建模时就遇到个问题,就是这两个竖井(见下图中两个深90m的深井)到底选什么样的类型。如果说选“调压井”的话,进、出水管口的高程完全不一样;如果选“水库”的话,又无法输入这个竖井的直径;如果选“水箱”,好像也无法区分进水口和出水口的高程差别很大这一情况,所以想请教一下建模时用哪种比较准确??
I am using Bentley Hammer software to simulate a pumping station project that our unit is doing in Shenzhen. This project is a deep-buried tunnel pumping station, that is different from conventional pumping stations, it takes two deep shafts and a deep tunnel to get the water to the pumping station (mostly to avoid many deep subway lines) . One of the problems I had with modeling was the type of shaft (see the two 90m deep shafts in the image below) . If we choose "surge tank" , the height of the inlet and outlet pipe is completely different; if we choose "reservoir" , we can not input the diameter of the shaft; if we choose "water tank" , ? It seems that there is no way to tell the difference between the height of the water inlet and the water outlet, so I would like to ask which is more accurate in modeling?
