该邮件从移动设备发送
I have split your question to a new thread for better tracking.
You can use the orifice equation to estimate the "typical flow" corresponding to an estimated "typical pressure drop" (pressure at the upstream side of the atmospheric discharge). See item #2 in the section "Common applications of the D2A acting as an Orifice" in this article: Modeling Reference - Discharge To Atmosphere
为了更好地跟踪,我已将您的问题分拆到一个新的主题中。
您可以使用孔板方程来估算与估算的 "典型压降"(大气排放口上游侧的压力)相对应的 "典型流量"。请参见本文 "Common applications of the D2A acting as an Orifice "一节中的第 2 项:Modeling Reference - Discharge To Atmosphere
