Has Bentley thought about using an online licence management model?
With lots of people and I assume companies bring unhappy with the present licence model is this likely to be re-evaluated and possible changed further down the line?
A possible change would be to set up online licences so that when a program is started it first checks with Bentley's servers to see if there is a licence available. If there is then the program starts, if not it doesn't. This works very well with other software vendors programs (eg The NBS) and would solve a lot of the ongoing issues and bad feeling that there is at the moment.
Any thoughts Bentley/anyone?
  • I'm a little confused by this, Bentley has offered hosted (on-line) licensing longer than most vendors. In fact we've pushed other vendors to follow a similar strategy. Our Bentley users can connect to SELECTserver anywhere in the world as long as they have an active internet connection. With the trusted licensing model they can even go for 30 days without connecting to a license manager. Is it that your company has just not decided to have a SELECT contract with Bentley?
    Perhaps I didn't phrase the question correctly. What i am suggesting is an online licence restriction tool, so that (as you have stated) wherever you are you can grab a licence or not if one isn't available.
    We have had SELECT from when it was first brought out!
  • 1. Are you wanting to restrict license counts?
    2. Access to specific products?
    3. Restricting access to certain individuals?
    Option 1 currently isn't possible because it's trust licensing. Basically I'll let you use the product now but you'll have to check in within 30 days to make sure you have a valid license.
    2 and 3 are very possible with Custom Activation Groups and Client Access Restrictions.
  • +1
    I have wished the same thing since the previous licence server consept was dumped few years ago. I hate the the currect way where there is no proper way to control over usage of the licences. It is a pain for small companies like us.
