<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Non-Select Licensing Problem</title><link>https://communities.bentley.com/communities/other_communities/licensing_cloud_and_web_services/f/forum/110847/non-select-licensing-problem</link><description>This is in regards to the Problem with our License of the STAAD Pro. V8i,
 As we are a Non-Select license user since last 2 years, Since the period of time we haven’t face any problem nether on application part nor the licensing
 but since last 2-3</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Non-Select Licensing Problem</title><link>https://communities.bentley.com/thread/337830?ContentTypeID=1</link><pubDate>Wed, 09 Sep 2015 21:41:16 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:17d8a6b6-9cea-4744-880e-e5f2662e2da9</guid><dc:creator>Jeremy Hoesly</dc:creator><description>&lt;p&gt;The SELECTserver administration site is not intended for non-SELECT users, hence the error. I see that STAAD licenses are currently available for checkout&amp;nbsp;on your site. To check out licenses, please use either the &lt;a href="/products/licensing/w/licensing__wiki/6013.client-check-in-and-out-instructions-for-xm-and-higher-tn" target="_blank"&gt;License Management Tool&lt;/a&gt; or the &lt;a href="/products/licensing/w/licensing__wiki/5278.activating-as-a-non-select-or-node-locked-user-tn" target="_blank"&gt;Product Activation Wizard&lt;/a&gt;. The License Management Tool is accessible by selecting from the Windows Start menu:&lt;br /&gt;All Programs -&amp;gt; Bentley -&amp;gt; Engineering -&amp;gt; STAAD.Pro -&amp;gt; SELECT License Tools -&amp;gt; Bentley SELECT XM License Management Tool&lt;/p&gt;
&lt;p&gt;Please note that non-SELECT licenses can be used on only one computer per day. So if a license is checked in from one computer, it cannot be checked out on a different computer until the following day. The following &lt;a href="/products/licensing/w/licensing__wiki/21655.why-do-i-encounter-an-error-when-moving-a-license-to-another-computer" target="_blank"&gt;support solution&lt;/a&gt; provides more detail. Pooled licensing is a benefit of SELECT.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
