Just read this in Help:
*Please note that turning off the automatic launch and sign-in setting does not prevent the CONNECTION Client from starting when you start MicroStation CONNECT Edition. You’re not required to sign-in, however if you chose not to sign-in to your CONNECTED Project you will not have up to date information such as Project Name, Asset Industry, Asset Type, Location etc, nor will you have access to other CONNECT Services.
This is not true as I have started CONNECT and the Connection Client doesn't start. I have to start it manually Why?
Tamicca SellarsProduct Manager I
connection client is not working, as in this picture. What is the problem?
See communities.bentley.com/.../unable-to-sign-in-to-the-connection-client---it-shows-a-blank-screen
OK thanks for that. Another question if I may.
When completing the bulk user registration CSV can I use England as the country?
