Hello all,
I have been using my node locked MicroStation V8i for almost two years and now I have a problem with managing the license.
I use the Produce Activation Wizard with the non-Select node locked user -> I have activation key, use the server name and site activation key, enter my email address and so forth, then I get an error saying that I have no checkouts remaining for this product.
Indeed, in the License Checkout tab, there are no licenses available to be checked out.
But I am the only one ever using this computer and the software is not installed anywhere else, so I am scratching my head!
Any suggestions on how to fix this and what might be going wrong?
Thanks for your help!
Steve
Hi Joshua,
I wonder if you might be able to help me out again with a license checkout problem?
What I'm doing is getting all of my work and software transported to another computer and I checked in my MS license so I could check it out on my new computer. But now although I seem to successfully activate MS I can't check out the license.
If I send you my activation key again can you see what the problem is?
many thanks
