I have installed Microstation CONNECT and saved a 3D-Model as a imodel (also published to Personal Share)
Afterwords I installed Navigator on my Ipad and I used the same login as I use for microstation CONNECT.
My imodel is not listed in Navigator? What do I wrong? When I try to start a new Project, a window popup like showing above...
Best regards
Arjan Molenaar
Tamicca SellarsMicroStation Product Manager
Additionally you may look at Navigator CONNECT Edition getting started support solutions: http://communities.bentley.com/products/projectwise/project_review/w/wiki/23510.3-opening-an-i-model
In Navigator CONNECT Edition you can open *imodel from "Personal Share", "Project Share", "Local drive". You have published *.imodel from MicroStation to "Personal Share" so in Navigator "Open" view select "Browse" button and then select "Personal Share":
Regards,Darius
Answer Verified By: Tamicca Sellars
