I have just downloaded Bentley View V8i software that is stated to be "free for use".
After the installation process, Activation Wizard appeared that says to choose an approach to Bentley Licensing: SELECT Server, NOT-SELECT user (it wants some XML or plaintext key when selected), or the only option that allows me to use the SW: Only trial version, without the license.
Is this software really free for use? If so, where could I download any license key, please?
Or, where should I register to obtain the SELECT license?
Thank you for your help
Hi Jan, From where did you download the free software? Bentley view can be downloaded using this link www.bentley.com/.../bentley-view You do not need any activation key for this product, it is free. As far as I know you will be asked just to register. Can you provide any screen shot from License Management tool showing actual status and the product that needs activation?
Regards Maria
Answer Verified By: Jan Botorek
