translate.google.it
good morning
My company owns 4 licenses microstation,
in the office we have 6 computers with the software installed.
Often it happens to use more than 4 licenses unintentionally.
and promptly get the invoice from Bentley than 2000 euroto overuse
Is there a way to block the use of the fifth license? I tried to set restrictions but does not work.
thanks in advance
HelloI do not think it's the right solutionbecause if having 4 licenses and if a fifth person uses microstationIt is not blocked
communities.bentley.com/.../81970
As mentioned in the forum post you referenced, SELECTserver is primarily a usage reporting tool, not a license enforcement tool. In the forum thread, I mention strategies for limiting usage that may provide what you seek.
Answer Verified By: Massimo Callegher
