The Licensing and Activation Community has merged with the Cloud and Web Services Community. Read more here.
I am trying to create a new computer image for our company. We are currently on V8i SS3 - 8.11.8.151. The problem is with the new build and V8i - SS7 - 8.11.12.235, the Bentley Connection Client keeps popping up when logging into the machine not the software the machine, can this be turned off?
When it asks me to login . I tried my Bentley website login but it does not work. I don't want to have all our users to have to create a Bentley login just to get.
Please let me know thanks
Actually, you should be able to disable the auto-start feature by deleting the MySELECT.exe value in the registry from HKCU\Software\Microsoft\Windows\CurrentVersion\Run. The following can be executed from the Command Prompt: reg delete HKCU\Software\Microsoft\Windows\CurrentVersion\Run /v MySELECT.exe /f
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Hello Mike,
The CONNECTION Client has settings to prevent it from starting (see CONNECTION Client Preferences) however some of the applications (in your case MicroStation) start the CONNECTION Client so those settings are overridden. The only version of MicroStation that I'm aware of that overrides the CONNECTION Client settings is MicroStation V8i (SELECTseries 4).
Tamicca SellarsSupport Engineer
