Errors when installing MS SS4 and CONNECT update 2
Hi All,
I just bought a brand new laptop, an ASUS VivoBook Pro N752VX, Below the specs sheet:
When  I install MS SS4 and CONNECT update 2 I get installation errors on connection client, even when run as Administrator and the firewall turned off.
Below the errors and the logfile. What could be the reason why I cannot install MicroStation?
Asus Vivobook Pro N752VX
Screen 17.3 inch, 3840 x 2160 px resolution, matte, IPS, non-touch
Processor Intel Skylake Core i7-6700HQ CPU, quad-core 2.6 GHz (3.5 GHz TBoost)
Video Intel HD 530 + Nvidia GTX 950M 4GB
Memory 32 GB DDR4 2133Mhz (2xDIMMs)
Storage 256 GB SSD (M.2 NVMe) + 1 TB 2.5″ HDD
Connectivity Wireless AC Intel Tri-Band 8260 , Gigabit LAN, Intel Bluetooth 4.0
Ports 3x USB 3.0, 1x USB 3.1 (5 Gbps), HDMI, miniDP, mic/earphone, SD card reader, LAN, Kensington Lock
Baterry 48 Wh
Operating system Windows 10
[13DC:1614][2016-08-11T11:18:49]i001: Burn v3.10.2.2516, Windows v10.0 (Build 10586: Service Pack 0), path: C:\Users\CADman\AppData\Local\Temp\{B7D46D79-ECA2-4B3C-92D1-E055D1DAC838}\.cr\ms10020039en_updt2.exe
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeExeName' to value 'Microstation'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]MicroStation\ActivationWizard.exe'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeInstallFolderSuffix' to value ' 10.02.00.039'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\MicroStation CONNECT Edition Update 2\'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;OrganizationDirectory;WorkSpacesDirectory;WorkSpacesLabel'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;OrganizationDirectory;WorkSpacesDirectory'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{DB956E9F-5699-40DE-BA52-0985F8B2505A}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeBundleCulture' to value 'en'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeBuildType' to value 'Release'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeBundleShortName' to value 'MicroStation'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_MicroStation_en.zip'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{A20CFB71-57E7-3FB0-82E7-2A8DEF897524}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{D161FFBC-F480-4FC4-9600-BAEAF8DE6F71}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_MicroStationDocumentation' to value '{7DDEE7EE-1C92-34D6-AF6A-EC8F923400A6}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_DgnPreviewHandler' to value '{264B522D-1B7F-4AAF-A32B-55A6BF5679F2}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx64' to value '{C16149AD-0C5C-37C1-AA8D-D30D8734B580}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_DgnODBCDriverx86' to value '{442AD689-1CA6-3B2E-9685-F2E1414FE728}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{F1E16B38-FE6A-487C-8117-0D6B72F92445}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_VisualizationContent' to value '{F2DB3FB2-E97C-31D4-B5D7-4CD5D839717F}'
[13DC:1614][2016-08-11T11:18:49]i000: Initializing string variable 'BeVarProductCode_MetroStationWorkSets' to value '{D5F0E86A-8893-3A53-9859-F91AE5C1CF01}'
[13DC:1614][2016-08-11T11:18:49]i009: Command Line: '-burn.clean.room=C:\BentleyDownloads\ms10020039en_updt2.exe'
[13DC:1614][2016-08-11T11:18:49]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\BentleyDownloads\ms10020039en_updt2.exe'
[13DC:1614][2016-08-11T11:18:49]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\BentleyDownloads\'
[13DC:1614][2016-08-11T11:18:49]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849.log'
[13DC:1614][2016-08-11T11:18:49]i052: Condition 'VersionNT64 > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
[13DC:1614][2016-08-11T11:18:49]i000: Setting string variable 'WixBundleName' to value 'MicroStation CONNECT Edition Update 2'
[13DC:1614][2016-08-11T11:18:49]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[13DC:1614][2016-08-11T11:18:49]i000: Loading managed bootstrapper application.
[13DC:1614][2016-08-11T11:18:49]i000: Creating BA thread to run asynchronously.
[13DC:1888][2016-08-11T11:18:50]i000: BentleyBundle Version 10.01.00.13
[13DC:1888][2016-08-11T11:18:50]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\CADman\AppData\Local\Temp\{2F10ECC3-F1F8-477F-AFD8-5F83DEFA5084}\.ba'
[13DC:1888][2016-08-11T11:18:50]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\CADman\AppData\Local\Temp\{B7D46D79-ECA2-4B3C-92D1-E055D1DAC838}\.cr'
[13DC:1888][2016-08-11T11:18:50]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\'
[13DC:1888][2016-08-11T11:18:50]e000: Using Layout File : C:\Users\CADman\AppData\Local\Temp\{2F10ECC3-F1F8-477F-AFD8-5F83DEFA5084}\.ba\Setup.lyt
[13DC:1888][2016-08-11T11:18:50]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\BentleyDownloads\MicroStation CONNECT Edition Update 2\'
[13DC:1888][2016-08-11T11:18:50]i000: Setting VisualBasicCore InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting VisualBasicLang InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting DotNet451Full InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting BentleyConnectClient InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting PowerProductPackage InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,RFAGenerateAccessFAToken,RMeshGenerateAccessFAToken,Configuration,FileAssociationFeature'
[13DC:1888][2016-08-11T11:18:50]i000: Setting PointTools32Extx86 InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting MicroStationDocumentation InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting DgnIFilterSetUpx64 InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting DgnIndexer InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting DgnPreviewHandler InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting DgnThumbnailProvier InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting HDRPreviewExtension_x64 InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting DgnODBCDriverx64 InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting DgnODBCDriverx86 InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting ItgDgnDbImporter InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting VisualizationContent InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting MetroStationWorkSets InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: Setting UserAddedPackagesInstaller InstallLevel to 1
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicCoreStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicLangStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]e000: Failed for Package Id: VisualBasicLang2
Bootstrapper Application Data is not found for the Feature: VisualBasicLang2
[13DC:1888][2016-08-11T11:18:50]i000: DotNet451FullStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: BentleyConnectClientStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackageStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_FileAssociationFeatureStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RFAGenerateAccessFATokenStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RFAGenerateAccessFATokenAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RFAGenerateAccessFAToken RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RFAGenerateAccessFAToken RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RMeshGenerateAccessFATokenStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RMeshGenerateAccessFATokenAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RMeshGenerateAccessFAToken RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_RMeshGenerateAccessFAToken RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_ConfigurationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1888][2016-08-11T11:18:50]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1888][2016-08-11T11:18:50]i000: VisualizationContentStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: MetroStationWorkSetsStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PointTools32Extx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: MicroStationDocumentationStoreFeatureState: Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnIFilterSetUpx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnIndexerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnPreviewHandlerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnThumbnailProvierStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: HDRPreviewExtension_x64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx64StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx86StoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: ItgDgnDbImporterStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]e000: Failed for Package Id: PowerProductLanguagePack
Bootstrapper Application Data is not found for the Feature: PowerProductLanguagePack
[13DC:1888][2016-08-11T11:18:50]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:50]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Unknown
[13DC:1888][2016-08-11T11:18:50]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
[13DC:1888][2016-08-11T11:18:50]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[13DC:1888][2016-08-11T11:18:50]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1888][2016-08-11T11:18:52]i000: Display is set to Full
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeDialogInstallUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]i000: Register callbak=ProxySettingsPage
[13DC:1888][2016-08-11T11:18:53]i000: Display Page=ProxySettingsPage
[13DC:1888][2016-08-11T11:18:53]i000: Cannot Display Page=ProxySettingsPage
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[13DC:1888][2016-08-11T11:18:53]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
[13DC:1614][2016-08-11T11:18:55]i100: Detect begin, 18 packages
[13DC:1614][2016-08-11T11:18:55]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent
[13DC:1614][2016-08-11T11:18:55]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
[13DC:1614][2016-08-11T11:18:55]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
[13DC:1614][2016-08-11T11:18:55]i000: DetectBegin: Installed State of Package DetectedAbsent
[13DC:1614][2016-08-11T11:18:55]i000: Registry key not found. Key = 'SOFTWARE\Bentley\BentleyDesktopClient\Install'
[13DC:1614][2016-08-11T11:18:55]i000: Setting string variable 'NetFramework45Version' to value '394254'
[13DC:1614][2016-08-11T11:18:55]i000: ReferenceId 63645=63645
[13DC:1614][2016-08-11T11:18:55]i000: ReferenceId [VBA_LANGUAGE_PRGID_1033]=63644
[13DC:1614][2016-08-11T11:18:55]i052: Condition '(NetFramework45Version >= 378758 AND VersionNT < v6.3) OR (NetFramework45Version >= 378675 AND VersionNT >= v6.3)' evaluates to true.
[13DC:1614][2016-08-11T11:18:55]i000: ReferenceId 64771=64771
[13DC:1614][2016-08-11T11:18:55]w120: Detected partially cached package: BentleyConnectClient, invalid payload: BentleyConnectClient, reason: 0x80070002
[13DC:1614][2016-08-11T11:18:55]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.4.24' evaluates to false.
[13DC:1614][2016-08-11T11:18:55]w120: Detected partially cached package: PowerProductPackage, invalid payload: PowerProductPackage, reason: 0x80070570
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: VisualBasicCore, state: Present, cached: None
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: VisualBasicLang, state: Present, cached: None
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: DotNet451Full, state: Present, cached: None
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: BentleyConnectClient, state: Absent, cached: Partial
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: PowerProductPackage, state: Absent, cached: Partial
[13DC:1614][2016-08-11T11:18:55]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent
[13DC:1614][2016-08-11T11:18:55]i104: Detected package: PowerProductPackage, feature: RFAGenerateAccessFAToken, state: Absent
[13DC:1614][2016-08-11T11:18:55]i104: Detected package: PowerProductPackage, feature: RMeshGenerateAccessFAToken, state: Absent
[13DC:1614][2016-08-11T11:18:55]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent
[13DC:1614][2016-08-11T11:18:55]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: PointTools32Extx86, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: MicroStationDocumentation, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: DgnIFilterSetUpx64, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: DgnIndexer, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: DgnPreviewHandler, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: DgnThumbnailProvier, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: HDRPreviewExtension_x64, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: DgnODBCDriverx64, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: DgnODBCDriverx86, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: ItgDgnDbImporter, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: VisualizationContent, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: MetroStationWorkSets, state: Absent, cached: Complete
[13DC:1614][2016-08-11T11:18:55]i101: Detected package: UserAddedPackagesInstaller, state: Absent, cached: None
[13DC:1614][2016-08-11T11:18:55]i000: Setting string variable 'BePlannedAction' to value 'Install'
[13DC:1614][2016-08-11T11:18:55]i000: VisualBasicCoreAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: VisualBasicCore RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: VisualBasicCore RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: VisualBasicLangAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: VisualBasicLang RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: VisualBasicLang RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: VisualBasicLang2AnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DotNet451FullAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DotNet451Full RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DotNet451Full RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: BentleyConnectClientAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: BentleyConnectClient RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: BentleyConnectClient RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackageAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_FileAssociationFeatureAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_FileAssociationFeature RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_RFAGenerateAccessFATokenAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_RFAGenerateAccessFAToken RestoreFeatureState: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_RFAGenerateAccessFAToken RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_RMeshGenerateAccessFATokenAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_RMeshGenerateAccessFAToken RestoreFeatureState: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_RMeshGenerateAccessFAToken RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_WinTabFeatureAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_ConfigurationAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_Configuration RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductPackage_Configuration RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[13DC:1614][2016-08-11T11:18:55]i000: VisualizationContentAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: VisualizationContent RestoreFeatureState: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: VisualizationContent RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: MetroStationWorkSetsAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: MetroStationWorkSets RestoreFeatureState: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: MetroStationWorkSets RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PointTools32Extx86AnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: PointTools32Extx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PointTools32Extx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: MicroStationDocumentationAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: MicroStationDocumentation RestoreFeatureState: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: MicroStationDocumentation RestoreFeatureState: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnIFilterSetUpx64AnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DgnIFilterSetUpx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnIFilterSetUpx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnIndexerAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DgnIndexer RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnIndexer RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnPreviewHandlerAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DgnPreviewHandler RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnPreviewHandler RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnThumbnailProvierAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DgnThumbnailProvier RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnThumbnailProvier RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: HDRPreviewExtension_x64AnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: HDRPreviewExtension_x64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: HDRPreviewExtension_x64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnODBCDriverx64AnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DgnODBCDriverx64 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnODBCDriverx64 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnODBCDriverx86AnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: DgnODBCDriverx86 RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DgnODBCDriverx86 RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: ItgDgnDbImporterAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: ItgDgnDbImporter RestoreFeatureState: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: ItgDgnDbImporter RestoreFeatureState: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: PowerProductLanguagePackAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: LaunchAction=Install
[13DC:1614][2016-08-11T11:18:55]i000: UserAddedPackagesInstallerAnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout"
[13DC:1614][2016-08-11T11:18:55]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[13DC:1614][2016-08-11T11:18:55]i000: UserAddedPackagesInstallerStoreFeatureState: Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: UserAddedPackagesInstallerCompletelyDisableFeatureFromAnyService: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[13DC:1614][2016-08-11T11:18:55]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
[13DC:1614][2016-08-11T11:18:55]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[13DC:1614][2016-08-11T11:18:55]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles
[13DC:1614][2016-08-11T11:18:55]i000: SessionMutex: Creating new SessionMutex
[13DC:1614][2016-08-11T11:18:55]i000: SessionMutex: Creating Mutex with Name={1e6ab482-488a-4e72-9371-8eeda4fc7f3e}-InstallMutex
[13DC:1614][2016-08-11T11:18:55]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
[13DC:1614][2016-08-11T11:18:55]i000: WixInstallBA::SilentPlan
[13DC:1614][2016-08-11T11:18:55]i000: Cannot find Directory C:\ProgramData\Bentley\CONNECT Edition\
[13DC:1614][2016-08-11T11:18:55]i000: AutoCad Civil 3D ObjectEnabler:Searching
[13DC:1614][2016-08-11T11:18:55]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
[13DC:1614][2016-08-11T11:18:55]i199: Detect complete, result: 0x0
[13DC:1888][2016-08-11T11:18:55]i052: Condition 'NOT BeUpgradingProductCodes' evaluates to true.
[13DC:1888][2016-08-11T11:19:00]i000: Setting string variable 'InstallDesktopShortcut' to value '1'
[13DC:1888][2016-08-11T11:19:09]i052: Condition 'BeUpgradingProductCodes' evaluates to false.
[13DC:1888][2016-08-11T11:19:09]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair" AND NOT BeSkipFeatureConfigDialog' evaluates to true.
[13DC:1888][2016-08-11T11:19:12]i000: WixInstallBA::Plan
[13DC:1888][2016-08-11T11:19:12]i000: WixInstallBA::SetupModel Plan
[13DC:1888][2016-08-11T11:19:12]i000: SetupModel::Before Plan
[13DC:226C][2016-08-11T11:19:12]i000: Before Plan Async
[13DC:226C][2016-08-11T11:19:12]i000: SetupViewModel::Before Plan
[13DC:226C][2016-08-11T11:19:12]i000: WixInstallBA::Before Plan Complete
[13DC:226C][2016-08-11T11:19:12]i000: WixInstallBA::Engine Plan
[13DC:1614][2016-08-11T11:19:12]i200: Plan begin, 18 packages, action: Install
[13DC:1614][2016-08-11T11:19:12]w321: Skipping dependency registration on package with no dependency providers: DotNet451Full
[13DC:1614][2016-08-11T11:19:12]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClient
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_BentleyConnectClient' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_000_BentleyConnectClient.log'
[13DC:1614][2016-08-11T11:19:12]i204: Plan 5 msi features for package: PowerProductPackage
[13DC:1614][2016-08-11T11:19:12]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[13DC:1614][2016-08-11T11:19:12]i203: Planned feature: RFAGenerateAccessFAToken, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[13DC:1614][2016-08-11T11:19:12]i203: Planned feature: RMeshGenerateAccessFAToken, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[13DC:1614][2016-08-11T11:19:12]i203: Planned feature: Configuration, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[13DC:1614][2016-08-11T11:19:12]i203: Planned feature: FileAssociationFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleRollbackLog_PowerProductPackage' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_001_PowerProductPackage_rollback.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_PowerProductPackage' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_001_PowerProductPackage.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleRollbackLog_PointTools32Extx86' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_002_PointTools32Extx86_rollback.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_PointTools32Extx86' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_002_PointTools32Extx86.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleRollbackLog_MicroStationDocumentation' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_003_MicroStationDocumentation_rollback.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_MicroStationDocumentation' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_003_MicroStationDocumentation.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_DgnIFilterSetUpx64' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_004_DgnIFilterSetUpx64.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_DgnIndexer' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_005_DgnIndexer.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_DgnPreviewHandler' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_006_DgnPreviewHandler.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_DgnThumbnailProvier' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_007_DgnThumbnailProvier.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_HDRPreviewExtension_x64' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_008_HDRPreviewExtension_x64.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_DgnODBCDriverx64' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_009_DgnODBCDriverx64.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_DgnODBCDriverx86' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_010_DgnODBCDriverx86.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_ItgDgnDbImporter' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_011_ItgDgnDbImporter.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_VisualizationContent' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_012_VisualizationContent.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleRollbackLog_MetroStationWorkSets' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_013_MetroStationWorkSets_rollback.log'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'WixBundleLog_MetroStationWorkSets' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_013_MetroStationWorkSets.log'
[13DC:1614][2016-08-11T11:19:12]w321: Skipping dependency registration on package with no dependency providers: UserAddedPackagesInstaller
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: VisualBasicCore, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: VisualBasicLang, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: DotNet451Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: BentleyConnectClient, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: PowerProductPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: PointTools32Extx86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: MicroStationDocumentation, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: DgnIFilterSetUpx64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: DgnIndexer, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: DgnPreviewHandler, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: DgnThumbnailProvier, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: HDRPreviewExtension_x64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: DgnODBCDriverx64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: DgnODBCDriverx86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: ItgDgnDbImporter, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: VisualizationContent, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: MetroStationWorkSets, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[13DC:1614][2016-08-11T11:19:12]i201: Planned package: UserAddedPackagesInstaller, state: Absent, default requested: Present, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[13DC:1614][2016-08-11T11:19:12]i000: GetWindowsRootDriveName (): winRoot=C:\
[13DC:1614][2016-08-11T11:19:12]i000: IsPathRooted (C:\): true
[13DC:1614][2016-08-11T11:19:12]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=1784368728, FileName=C:\BentleyDownloads\ms10020039en_updt2.exe
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64). Next
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64) English. Next
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.5.1. Next
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1784368728
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=48019712, NewSize=1832388440
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1832388440
[13DC:1614][2016-08-11T11:19:12]i000: GetDriveName (C:\): DriveInfo.Name=C:\
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): DriveName=C:\, Path=C:\Program Files\Bentley\MicroStation CONNECT Edition Update 2\
[13DC:1614][2016-08-11T11:19:12]i000: Warning : Install root drive C:\ is same as windows root drive C:\. Only C:\ will be check for available disk space.
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=1816834578, NewSize=3649223018
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Feature is not a package = File association. Next
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Feature is not a package = RFA Support Tech Preview. Next
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Feature is not a package = Reality Mesh Classifier tools Tech Preview. Next
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Feature is not a package = Configurations. Next
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3649223018
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=360890382, NewSize=4010113400
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4010113400
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=241565765, NewSize=4251679165
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4251679165
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=2347865, NewSize=4254027030
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4254027030
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=188561935, NewSize=4442588965
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4442588965
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=9035152, NewSize=4451624117
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4451624117
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=345795304, NewSize=4797419421
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4797419421
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=158043076, NewSize=4955462497
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4955462497
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=307561, NewSize=4955770058
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4955770058
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=2883136, NewSize=4958653194
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=4958653194
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=113738508, NewSize=5072391702
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=5072391702
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=97768210, NewSize=5170159912
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=5170159912
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=364031625, NewSize=5534191537
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=5534191537
[13DC:1614][2016-08-11T11:19:12]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=0, NewSize=5534191537
[13DC:1614][2016-08-11T11:19:12]i000: checkInstallSize (): Checking for drive C:\
[13DC:1614][2016-08-11T11:19:12]i000: checkInstallSize (): Requested Drive-List contains drive C:\
[13DC:1614][2016-08-11T11:19:12]i000: checkInstallSize (): Checking for drive D:\
[13DC:1614][2016-08-11T11:19:12]i000: checkInstallSize (): Checking for drive E:\
[13DC:1614][2016-08-11T11:19:12]i000: validateInstallSize (): Result=True
[13DC:1614][2016-08-11T11:19:12]i000: PlanComplete: Called
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'VisualBasicCore_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'VisualBasicLang_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'DotNet451Full_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'BentleyConnectClient_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'PowerProductPackage_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'PowerProductPackage_FileAssociationFeature_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'PowerProductPackage_RFAGenerateAccessFAToken_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'PowerProductPackage_RMeshGenerateAccessFAToken_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'PowerProductPackage_Configuration_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'VisualizationContent_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'MetroStationWorkSets_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'PointTools32Extx86_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'MicroStationDocumentation_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'DgnIFilterSetUpx64_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'DgnIndexer_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'DgnPreviewHandler_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'DgnThumbnailProvier_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'HDRPreviewExtension_x64_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'DgnODBCDriverx64_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'DgnODBCDriverx86_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: Setting string variable 'ItgDgnDbImporter_RequestedState' to value '1'
[13DC:1614][2016-08-11T11:19:12]i000: WixInstallBA::Apply
[13DC:1614][2016-08-11T11:19:12]i000: WixInstallBA::Engine Apply
[13DC:1614][2016-08-11T11:19:12]i299: Plan complete, result: 0x0
[13DC:1614][2016-08-11T11:19:12]i300: Apply begin
[13DC:1614][2016-08-11T11:19:12]i000: DisplayMessage (Installing MicroStation CONNECT Edition Update 2)
[13DC:1614][2016-08-11T11:19:12]i010: Launching elevated engine process.
[13DC:1614][2016-08-11T11:19:12]i011: Launched elevated engine process.
[13DC:1614][2016-08-11T11:19:13]i012: Connected to elevated engine.
[0B14:237C][2016-08-11T11:19:13]i358: Pausing automatic updates.
[0B14:237C][2016-08-11T11:19:13]i359: Paused automatic updates.
[0B14:237C][2016-08-11T11:19:13]i360: Creating a system restore point.
[0B14:237C][2016-08-11T11:19:13]i361: Created a system restore point.
[0B14:237C][2016-08-11T11:19:13]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1e6ab482-488a-4e72-9371-8eeda4fc7f3e}, options: 0x7, disable resume: No
[0B14:237C][2016-08-11T11:19:13]i000: Caching bundle from: 'C:\Users\CADman\AppData\Local\Temp\{2F10ECC3-F1F8-477F-AFD8-5F83DEFA5084}\.be\Setup_MicroStationx64_10.02.00.039.exe' to: 'C:\ProgramData\Package Cache\{1e6ab482-488a-4e72-9371-8eeda4fc7f3e}\Setup_MicroStationx64_10.02.00.039.exe'
[0B14:237C][2016-08-11T11:19:13]i320: Registering bundle dependency provider: {1e6ab482-488a-4e72-9371-8eeda4fc7f3e}, version: 10.2.0.39
[0B14:237C][2016-08-11T11:19:13]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1e6ab482-488a-4e72-9371-8eeda4fc7f3e}, resume: Active, restart initiated: No, disable resume: No
[13DC:1614][2016-08-11T11:19:13]i000: Installation chain initiated package from
[0B14:237C][2016-08-11T11:19:13]i323: Registering package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, version: 7.1.00.00, package: VisualBasicCore
[0B14:237C][2016-08-11T11:19:13]i325: Registering dependency: {1e6ab482-488a-4e72-9371-8eeda4fc7f3e} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore
[0B14:237C][2016-08-11T11:19:13]i323: Registering package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, version: 7.1.0.0, package: VisualBasicLang
[0B14:237C][2016-08-11T11:19:13]i325: Registering dependency: {1e6ab482-488a-4e72-9371-8eeda4fc7f3e} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang
[13DC:1B4C][2016-08-11T11:19:13]i336: Acquiring container: WixAttachedContainer, copy from: C:\BentleyDownloads\ms10020039en_updt2.exe
[13DC:1B4C][2016-08-11T11:19:17]i000: Setting string variable 'WixBundleLastUsedSource' to value 'C:\BentleyDownloads\'
[0B14:23C0][2016-08-11T11:19:22]i305: Verified acquired payload: BentleyConnectClient at path: C:\ProgramData\Package Cache\.unverified\BentleyConnectClient, moving to: C:\ProgramData\Package Cache\0537E06BF5557FCBE6E530F2E1ACE6666A92A18D\Setup_CONNECTIONclientx64_10.00.04.024.exe.
[13DC:1614][2016-08-11T11:19:22]i000: Installing BentleyConnectClient
[13DC:1614][2016-08-11T11:19:22]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;bentleyconnectclient'
[0B14:237C][2016-08-11T11:19:22]i301: Applying execute package: BentleyConnectClient, action: Install, path: C:\ProgramData\Package Cache\0537E06BF5557FCBE6E530F2E1ACE6666A92A18D\Setup_CONNECTIONclientx64_10.00.04.024.exe, arguments: '"C:\ProgramData\Package Cache\0537E06BF5557FCBE6E530F2E1ACE6666A92A18D\Setup_CONNECTIONclientx64_10.00.04.024.exe" /log C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849_000_BentleyConnectClient.log -burn.ancestors={1e6ab482-488a-4e72-9371-8eeda4fc7f3e}'
[0B14:23C0][2016-08-11T11:19:25]i304: Verified existing payload: PowerProductPackage at path: C:\ProgramData\Package Cache\{A20CFB71-57E7-3FB0-82E7-2A8DEF897524}v10.02.00.039\MicroStationx64.msi.
[0B14:23C0][2016-08-11T11:19:25]i304: Verified existing payload: PointTools32Extx86 at path: C:\ProgramData\Package Cache\{D161FFBC-F480-4FC4-9600-BAEAF8DE6F71}v01.00.00.013\Pointools32Extx86.msi.
[0B14:23C0][2016-08-11T11:19:26]i304: Verified existing payload: MicroStationDocumentation at path: C:\ProgramData\Package Cache\{7DDEE7EE-1C92-34D6-AF6A-EC8F923400A6}v10.02.00.040\MicroStationDocumentationProductx64.msi.
[0B14:23C0][2016-08-11T11:19:26]i304: Verified existing payload: DgnIFilterSetUpx64 at path: C:\ProgramData\Package Cache\{2E873893-A883-4C06-8308-7B491D58F3D6}v1.0.1.11\DgnIFilterSetUpx64.msi.
[0B14:23C0][2016-08-11T11:19:27]i304: Verified existing payload: DgnIndexer at path: C:\ProgramData\Package Cache\{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}v10.00.00.012\DgnIndexer.msi.
[0B14:23C0][2016-08-11T11:19:27]i304: Verified existing payload: DgnPreviewHandler at path: C:\ProgramData\Package Cache\{264B522D-1B7F-4AAF-A32B-55A6BF5679F2}v8.11.8004\DgnPreviewHandler.msi.
[0B14:23C0][2016-08-11T11:19:27]i304: Verified existing payload: DgnThumbnailProvier at path: C:\ProgramData\Package Cache\{74A8C1AF-75E5-4653-95AF-222725B7D877}v8.11.7.413\DgnThumbnailProviderx64.msi.
[0B14:23C0][2016-08-11T11:19:27]i304: Verified existing payload: HDRPreviewExtension_x64 at path: C:\ProgramData\Package Cache\{9F7815C9-A323-4215-905C-73137D21BCC0}v1.0.0.2\HDRPreviewExtension_x64.msi.
[0B14:23C0][2016-08-11T11:19:27]i304: Verified existing payload: DgnODBCDriverx64 at path: C:\ProgramData\Package Cache\{C16149AD-0C5C-37C1-AA8D-D30D8734B580}v01.03.01.031\DgnODBCDriverx64.msi.
[0B14:23C0][2016-08-11T11:19:27]i304: Verified existing payload: DgnODBCDriverx86 at path: C:\ProgramData\Package Cache\{442AD689-1CA6-3B2E-9685-F2E1414FE728}v01.03.01.031\DgnODBCDriverx86.msi.
[0B14:23C0][2016-08-11T11:19:28]i304: Verified existing payload: ItgDgnDbImporter at path: C:\ProgramData\Package Cache\{F1E16B38-FE6A-487C-8117-0D6B72F92445}v01.05.07007.0\ItgDgnDbImporter_x64.msi.
[0B14:23C0][2016-08-11T11:19:30]i304: Verified existing payload: VisualizationContent at path: C:\ProgramData\Package Cache\{F2DB3FB2-E97C-31D4-B5D7-4CD5D839717F}v08.21.05.005\ConnectSharedContentx86.msi.
[0B14:23C0][2016-08-11T11:19:31]i304: Verified existing payload: MetroStationWorkSets at path: C:\ProgramData\Package Cache\{D5F0E86A-8893-3A53-9859-F91AE5C1CF01}v08.21.05.019\MetroStationWorksetsx86.msi.
[0B14:237C][2016-08-11T11:19:34]e000: Error 0x80070643: Process returned error: 0x80070643
[0B14:237C][2016-08-11T11:19:34]e000: Error 0x80070643: Failed to execute EXE package.
[13DC:1614][2016-08-11T11:19:34]e000: Error 0x80070643: Failed to configure per-machine EXE package.
[13DC:1614][2016-08-11T11:19:34]i000: Installed package BentleyConnectClient
[13DC:1614][2016-08-11T11:19:34]i000: DisplayMessage (Installation failed with error code 0x80070643.)
[13DC:1614][2016-08-11T11:19:34]i000: DisplayMessage (Failed to install CONNECTION client with error code 0x80070643. Onherstelbare fout bij installatie)
[13DC:1614][2016-08-11T11:19:34]i319: Applied execute package: BentleyConnectClient, result: 0x80070643, restart: None
[13DC:1614][2016-08-11T11:19:34]e000: Error 0x80070643: Failed to execute EXE package.
[0B14:237C][2016-08-11T11:19:34]i351: Removing cached package: BentleyConnectClient, from path: C:\ProgramData\Package Cache\0537E06BF5557FCBE6E530F2E1ACE6666A92A18D\
[0B14:237C][2016-08-11T11:19:34]i326: Removed dependency: {1e6ab482-488a-4e72-9371-8eeda4fc7f3e} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package VisualBasicLang
[0B14:237C][2016-08-11T11:19:34]i329: Removed package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang
[0B14:237C][2016-08-11T11:19:34]i326: Removed dependency: {1e6ab482-488a-4e72-9371-8eeda4fc7f3e} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package VisualBasicCore
[0B14:237C][2016-08-11T11:19:34]i329: Removed package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore
[13DC:1614][2016-08-11T11:19:34]i000: Installation chain finished package from
[0B14:237C][2016-08-11T11:19:34]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1e6ab482-488a-4e72-9371-8eeda4fc7f3e}, resume: None, restart: None, disable resume: No
[0B14:237C][2016-08-11T11:19:34]i330: Removed bundle dependency provider: {1e6ab482-488a-4e72-9371-8eeda4fc7f3e}
[0B14:237C][2016-08-11T11:19:34]i352: Removing cached bundle: {1e6ab482-488a-4e72-9371-8eeda4fc7f3e}, from path: C:\ProgramData\Package Cache\{1e6ab482-488a-4e72-9371-8eeda4fc7f3e}\
[0B14:237C][2016-08-11T11:19:34]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1e6ab482-488a-4e72-9371-8eeda4fc7f3e}, resume: None, restart initiated: No, disable resume: No
[13DC:1614][2016-08-11T11:19:34]i000: C:\Program Files\Bentley\MicroStation CONNECT Edition Update 2\MicroStation\ActivationWizard.exe application is set for launch after installation
[13DC:1614][2016-08-11T11:19:34]i000: application not found to launch after installation
[13DC:1614][2016-08-11T11:19:34]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\CADman\AppData\Local\Temp\MicroStation_CONNECT_Edition_Update_2_20160811111849.zip'
[13DC:1614][2016-08-11T11:19:35]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
  • Mark, there should be a CONNECTION Client installation log file as well.
    Check the Programs and Features list if there is any version of CONNECTION Client already installed?
    Have you tried to reboot machine and run the installation again?
    You may try download CONNECTION Client (version 10.00.06.34) as separate installation pack and install it before MircroStation.
    Are you trying to install both MS SS4 + MS CONNECT Edition update 2 or the same machine?
    Darius
    Answer Verified By: Mark Stals
Reply
    Darius
