Hi
We have huge problems with correct activation of Bentley Map PowerView. We have allready discussed it with some Bentley employees (SR 7000582866), but they could not find a solution and told us to post it here.
We have huge problems activating Bentley Map PowerView (newest version 08.11.09.763). The program is installed and we can activate the program in the license manager, so we can see the green check mark beside the program name.
The strange thing is, that we get an error after 13 minutes of use saying that the program is not activated. See the attached image.
We have now set up licens debug mode inside the License Manager. We tested it again and I got this error in the licdebug-file:
"Error:LicenseClient_MarkFeature2 - The UsageId is null".
We do not having any problems running both MicroStation, Bentley Map Standalone, PowerCivil for Denmark etc. on the same machine. Here we do not get any errors.
Maybe I should upload the complete debug-file?
Hope you can help.
Best regards
Rune H. Christensen
I am unable to reproduce the activation timeouts or feature logging errors with Bentley Map PowerView V8i SS4 (08.11.09.763) in a Windows 10 test environment. I have examined all three logs you sent and see that no usage heartbeats are occurring, suggesting a possible installation issue. Please remove and reinstall PowerView as a troubleshooting measure. Then perform the following steps:
Please let us know what you find. Also, if running the product via an environment such as Citrix, try running the product directly to see if it logs usage using the steps above.
