Is there any specific documentation or training offered on best practices for the Connect environment, relating to user permissions and administration in a controlled IT environment. With the connect edition access to Bentley Portal this has opened up access and security issues that we need to understand before it can be deployed within the organization. I have spent a considerable amount of time trying to find answers to the following
In a controlled IT environment relating to the Connect editions and portal access
Periodic updates, how do we turn off the upgrade advisory for our staff?
What is recommended method of acquiring the upgrades for periodic deployment using SCCM? What would happen if a machine had missed a prior upgrade?
Bentley client personal portal access and passport usage? Costs? How can passport usage be denied, restricted or assigned?
Hi Michelle,
To add to the previous notes, here is an example of how to create a Deployment Image for use with SCCM: MicroStation CONNECT: How to create a Deployment Image
Marc
